Spark plugs replacement
How often do we need to replace the plugs on 2018 RLX Sport Hybrid?
I went to the dealer today for safety inspection with 52K miles and I was told that it is recommended every 50K miles, is it true?
Whenever your Maintenance Minder gives a service number with a "4", you are due for new spark plugs. The other maintenance done when a "4" shows up in the Maintenance Minder are Timing belt change, inspect water pump and check valve clearance.
