Front Brake Pad and Rotor Change
Old 10-14-2017, 12:31 PM
NJ-RLX's Avatar
After 31,000 miles I need to change the front brake pads and rotors on my '14 P-AWS. I am starting to feel a vibration in the steering wheel while braking. Where do I locate the jack stands once the car is jacked up? Looks like I must remove several plastic cowlings from underneath the car to access the support points.
Old 10-14-2017, 12:41 PM
pgeorg's Avatar
HTH
NJ-RLX (10-14-2017)
Old 10-14-2017, 12:51 PM
NJ-RLX's Avatar
Perfect. Thanks, pgeorg.
Old 10-14-2017, 12:56 PM
pgeorg's Avatar
You're very welcome NJ-RLX! If you need anything else let me know, and I will post if I can.
Old 10-25-2017, 04:18 PM
pcloadletter's Avatar
Fun fact, the PAWS and SH front rotor and pads are different. I changed all 4 corners at 50,000 in the driveway. Plenty of pad life left, but at least one of the rotors was warped.
Old 10-25-2017, 04:33 PM
pgeorg's Avatar
Even the front calipers are different......dual piston on the SH, single piston on the P-AWS....
