2015 RLX AC Noise.
2015 RLX AC Noise.
Hi,
2015 RLX Adv......I have noticed in the last week or so, i hear a noise in the cabin when the AC is working. The noise stops if i turn off the AC only, not the fan or the whole HVAC system. I don't think it sounds like a moan......i think it sounds like a "deeper ringing", but i am not sure i am describing it correctly. I have read the TSB for the AC moan, but i wanted to see if anyone else has it......if you do can you please describe the noise, and if it stops when you turn off the AC (but not the HVAC system).
Thank you!
Thank you!
Hi,
Thank you!
Thank you!
I noticed just recently that my HVAC system started to make a noise too. Mine is a bit of a whirling sound - I would describe it as the sound a helicopter makes off in the distance. Mine however makes the sound even if the AC itself is not engaged. I took a video and showed it to my dealer but since it wasn't currently exhibiting it when I brought it in, they said there was nothing they could do about it. They seemed less than interested in even looking much at the video I took - but that's an entirely different issue I have with my soon to be ex-dealer.
pgeorg (05-20-2015)
I think a service department that dismisses their customers complaints, do not deserve a second chance......
pgeorg (05-20-2015)
Ventilated Seats
My 2014 does not make any odd noises, however, I do find that the ventilated seats make more noise than I think that they should. Since this is my 1st car with this feature, I assume that it is the normal sound of the air moving thru the cracks & crevices between your body & the leather seats ... ?
Other than that, no other odd noises with the exception of the passenger side fold-in mirrors: the motor is much louder than the driver side but the dealership told me it was normal.
pgeorg (05-21-2015)
Both folding mirrors on mine make the same amount of noise.....I doubt that your passenger's side mirror being louder is normal.....
Thank you.
Seems to me many of these noises are a result of the super quiet interior of the RLX.
In most cars some of these sounds probably exist but can't be noticed due to road noise. However, in some cases it may be a sign of a some problem that needs attention.
Either way, I guess it is a "high class" problem.....we all get a little spoiled by the RLX.
Hi,
Thank you!
Thank you!
This is one of the earliest known problems with the 2014 models.
1) I first reported this issue back in Sept 13' here:
https://acurazine.com/forums/problem...issues-895058/
See additional threads on this here:
https://acurazine.com/forums/problem...-026-a-908412/
2) There was a TSB released to address this for certain VINs on the 2014 model: TSB 13-026: A/C Moans From the Engine Area (2014 RLX). My VIN is an effected model. Although it appeared to have been resolved for the 1st week after having the TSB performed, the problem came back and has been that way since.
3) My RLX exhibits the noise in all various manners. From the "low groan" to a "high-pitched whine". The "low groan" is most prevalent when idle, while the "high-pitched whine" is most prevalent when moving at speeds of 40mph or higher.
4) This issue is not the result of the "super-quiet" cabin design. The noise can be heard when the car is idle stopped, which ANY car will be quiet under those conditions.
5) No other Acura I've driven including the ILX, TLX, TL, RDX, MDX exhibit this AC noise. Using those vehicles as a benchmark for Acura quality, this is not what I classify as a "high-class" problem.
pgeorg (05-22-2015)
Thank you holografique. The noise is constant for me, either idling or driving at any speed. It will only go away if i turn the AC off.
But just like you, it immediately goes away instantly upon shutting off the AC portion of the HVAC system. Meaning it is something specific to when the AC compressor is engaged.
That's exactly how it behaves for me, it just happens to change its tone based on speed for me. The best way I can explain it is soundling like two little RC race cars (one big one small) sitting somewhere behind the dashboard attempting to match the rev speed of the cars engine.
I did have the TSB done and it didnt fix it.
If you notice the TSB was only released for very specific VIN numbers of the 2014 PAWS model. The fact that you are seeing this with a 2015 model supports the fact the TSB doesnt work since its showing up in a newer year model.
I would still report it to your service center and make them aware of the TSB. It may prompt them to contact Acura support, which may further prompt them to look into the issue more closely. Who knows, we could see a revised TSB that actually fixes the problem. But we'll never know if we dont speak up.
All I know is the last time I brought it up a second time at the service center, I brought up with the Manager (who also drives an RLX) and he confirmed he also had the same noise and that they had received complaints from others, but that there was no known fix for it despite the attempts with the TSB.
pgeorg (05-22-2015)
2015 Acura RLX high pitched whistling sound when AC on
I also have a 2015 Acura RLX that makes a loud high pitched whistling sound when the AC is on and I accelerate the car. I brought it into the dealer several times. The mechanic acknowledged the problem and found if the air conditioner is off, there is no problem. The dealer tells me there is nothing they can do because the problem has not been widely reported, and work to replace the AC will use parts that have the same problem. The car will be two years old and it has about 12,500 miles. Does anyone have suggestions?
Read this thread, and you will be able to take care of the AC whistling and/or moaning. Credit goes to members KenRLX, and holografique.
Fix is on the second page:
https://acurazine.com/forums/third-g...ow-say-931367/
HTH
HTH
Audio Sample of AC noise
Hello Everyone,
Just joining this thread -- thank god other people are having this issue. I have a 2016 RLX (PAWS) and I have brought it in for this AC noise several times. I want to say the noise has been there as long as I had the car (which I purchased new). As most everyone else has experienced, the dealer could not find it - which I can't blame them.
I haven't seen anyone else post audio samples to compare my noise to, so I thought I would contribute. Mine sounds like a UFO.
Grandpa
Received 2,609 Likes
Hello Everyone,
Was that recording from inside the cabin, near the passenger front seat floorboard?
Fixed - For now!
It was from inside the center of the cabin with the microphone facing the windshield. I was able to show the service department this forum thread and they were able to fix the problem (for now) by replacing the AC evaporator line along with installing rubber dampers and different rubber washers. They had a mechanic do a ride-along and I was able to point out the noise quick enough so we never even had to leave the parking lot. For me, I could turn the temperature up and the noise would go away completely. Apparently Acura knows about this issue but it is not big enough to issue to a recall. I am so glad that I am able to sit in silence now!
- Best regards
George Knighton (02-06-2019)
Grandpa
Glad it worked out so well. :-)
Grandpa
IIDXholic
3G RLX (2013+)
23
10-19-2015 09:40 PM
4drviper
09-23-2015 09:00 PM
