Spare tire for FWD advance
Old 10-25-2018, 06:46 PM
krisk's Avatar
Looking for information on what part numbers are required to make the rdx complete with a spare tire and what the price would run.
Old 10-25-2018, 06:55 PM
subin's Avatar
Below is the answer from "Curry Acura Parts" and they have good price on the Acura accessories.
Acura offers a spare tire kit for the 2019 RDX. Part number 06421-TJB-A50 for the spare tire kit which includes the tools to lift the vehicle, the hoist to secure the spare to the underside of the vehicle, and the rim. You will also require p/n 42751-ken-001 which is the rubber portion of the tire, p/n83307-tjb-a00za and 83305-tjb-a00za will also be required. Tire will need to be installed on rim at a shop that has access to a tire machine.
Here is the thread to installation procedures for the accessories. https://acurazine.com/forums/third-g...ctions-969946/
Go down the list to find the one for spare tire.
The following 3 users liked this post by subin:
JDMaccord3.5 (12-17-2019), Padre Dave (10-30-2019), tobey457 (10-28-2018)
Old 10-25-2018, 07:02 PM
krisk's Avatar
So the -A50 is for the Aspec with 20" wheels as the -A00 is for the 19" versions. Just want to make sure I get it right.
Old 10-25-2018, 07:20 PM
subin's Avatar
That is what I read also, as I have not made the purchase. You can confirm with www.curryacuraparts.com , on the site, they do list two different kits, one for A-spec and the other for all non-A-spec.
Old 10-25-2018, 07:36 PM
krisk's Avatar
I just picked the kit up for 258 shipped using that 10% off coupon on ebay. Now I just gotta finda that t155/90D17 tire at a decent price.
Old 10-31-2018, 02:30 PM
subin's Avatar
Let us know how hard it is to install the kit. According to the instruction, it does not look too bad. Thanks!
Old 10-31-2018, 06:34 PM
krisk's Avatar
I got the kit yesterday. It was simple to swap out and install. Probably 15 minutes worth of install time. I got a tire on order right now to install on the rim. it's not the kenda 155/90/17, but the kuhmo 155/90/17.
The company that I bought it from on ebay, said they didn't have it in stock and wasn't sure when it would ship. I did happen to find it on another website online for 212 shipped, so I went that route. I just checked their website to see if they changed the price and I see they have the part listed as discontinued.
subin (10-31-2018)
Old 10-31-2018, 06:51 PM
subin's Avatar
Thanks for the feedback.
I looked at description for both the 19" and 20" kits again and found they both listed the same size tire. I would believe that they are probably the same kit, but with different label stickers
Royki5cp (12-09-2019)
Old 10-31-2018, 07:00 PM
krisk's Avatar
If that is the case then look at acurapartswarehouse. They have the a50 kit for $212.
Old 10-31-2018, 07:06 PM
subin's Avatar
Thanks again
I am still thinking about this. I have not the chance to use the spare tire for the past 14 years and I have AAA roadside assistance, that is why I am undecided.
Old 11-03-2018, 12:49 AM
Dereileak's Avatar
So 100% that both kits are the same size and will fit the aspec?
I really would prefer a spare tire then this patch kit
Old 11-03-2018, 08:39 AM
subin's Avatar
Not 100% sure, but a good guess based on the tire size. I would just order the kit that is for A-Spec.
Old 12-11-2018, 04:10 PM
Dereileak's Avatar
so I still am not 100% sure, is this a full sized spare?
Old 12-11-2018, 05:00 PM
MI-RDX's Avatar
No, compact spare.
Compact Spare* Size T155/90D17 101M
Pressure psi 60 (kPa [kgf/cm2]) (420 [4.2])
Old 12-14-2018, 07:43 AM
Dereileak's Avatar
I am curious, from looking under the car I almost think a full sized spare would fit under there, anyone try this or see if it would fit? It’s pretty deep under there and seems like there is room, don’t want it sitting on the mufflers tho
russianDude (11-20-2019)
Old 12-14-2018, 10:54 AM
cm2021's Avatar
I used a tape measure to test and it seems putting a 235 tire down there would have it protruding fairly close to the ground, affecting the departure angles. Will see how things look after I install my temporary spare.
Old 12-16-2018, 11:09 PM
Dereileak's Avatar
could you get a pic of that when its installed and show how much gap there is from the mufflers and how much it hangs down?
Old 12-17-2018, 12:08 AM
cm2021's Avatar
Below are some pictures I snapped yesterday. The hoist is designed to work with only the spare tire, as marked on the adaptor that fits through the center of the wheel. It's too large to fit through the center of the standard wheel... I tried it out of curiosity.
The spare tire is barely visible from behind the vehicle. Any wider and it will protrude downward.
Spare tire stowed under the car
Spare tire hoist adaptor does not fit through the center hole of the regular wheel.
Old 12-17-2018, 12:12 AM
cm2021's Avatar
The "A50" kit
subin (12-17-2018)
Old 12-17-2018, 02:39 AM
Dereileak's Avatar
I can’t quite tell how close it is to the mufflers, if I went with a slightly wider tire it adds .7 inches in diameter, do you think it could fit that extra diameter under there? The tire I found that gets almost to stock within 1% is this size 165/90R17
also a trick that might get that through is before putting the holder in bend the wire and push it through then push the middle hoist adapter peice through so the wire is already on the other side, it might work
Old 12-18-2018, 07:38 PM
cm2021's Avatar
Dereileak, I saw in another thread that you ordered that 165/90/R17 tire. That's awesome that we saw there that it would fit under the car. I didn't think about that and there wasn't much info available, so I went with the factory fitment.
I did try to bend the wire, and I didn't want to force it and damage the wire or get the holder stuck. The regular spare wheel already required a bit of bending the wire, but with the regular wheel, moreso.
Old 12-18-2018, 07:59 PM
Dereileak's Avatar
I have a feeling the width of a full sized spare would sit pretty low anyways, honestly this spare will be pretty much the same size diameter except for it won’t be as wide, but the spare tire interestingly enough had a high weight limit at about 2800 lbs. I can wait to get this put in
Old 04-19-2019, 10:31 PM
6th Gear
m711's Avatar
They are the same. The only difference is the tire label they give you to affix on the driver's door jamb.
Old 12-03-2019, 11:50 PM
Carymark's Avatar
I ordered the 06421-TJB-A50 and when I got it everything was just thrown in one box and clanging and almost looked as if they had repacked it. I see you have two large boxes. Was there additional packing in yours so it was not clanging around?
Old 12-04-2019, 07:13 AM
6th Gear
m711's Avatar
Mine came in 1 box but was packed well.
Old 12-05-2019, 04:00 PM
Wander's Avatar
The hoist attachment is designed not to go through the full size aluminum wheel, for reasons that elude me, but whoever did it was dedicated and ingenious.
I'm usually pretty ingenious and damn stubborn, and I failed to defeat the design.
I only wish they had put that guy in charge of infotainment system development.
Old 12-14-2019, 01:08 AM
Padre Dave's Avatar
NO! The A-Spec has a different lug wrench with size for both the lug nuts and the hoist for the spare-tire, so look for that at the online Acura place in North Carolina. I now have an extra wrench for another Acura RDX if anyone in the Phoenix area wants it. Not sure what submodel it is for, as we have RDXs with 18”, 19” and 20” as OEM! Weird!
Old 11-12-2020, 01:26 PM
Tom Reynolds's Avatar
Full size spare, 2020 RDX tech.I just need a full size ugly spare.Is the hoist line long enough to go through a steel wheel hub. Would the 235/55/19 fit safely under the car even though the designed space maybe smaller? Might the tire be too close to the muffler or have a rub point?
Old 11-16-2020, 08:18 AM
TimmyB83's Avatar
Looking into a spare option for my 20’ ASpec as well, main question I was wondering is, if you have a compact spare on, do you have to also disable the traction control? I know some other vehicle’s computers freak out seeing different levels of traction and rotation rates etc on that one super undersized wheel, or it may think there’s a loss of traction when there’s not..
Old 04-03-2021, 06:47 PM
JR_Rider's Avatar
Did you figure out the correct part number for the A-Spec models?
Old 04-05-2021, 12:45 AM
Padre Dave's Avatar
Nah….That’s so long ago that I can hardly remember doing the ordering and finally getting the spare in…..and I haven’t thought about it since because I haven’t needed it. It is an ugly little thing and I pray it is enough to get me to a Discount Tire to get my Michelin PS3AT replaced. Sorry……
Old 01-03-2022, 11:41 AM
Automotive Enthusiast
Jeffola's Avatar
What are the parts "p/n83307-tjb-a00za and 83305-tjb-a00za" for? I ordered a kit and a tire, where do the parts you referenced go? Will this prevent me from doing the install?
Vegas RDX
3G RDX (2019+)
70
02-25-2023 02:51 PM
jhb31
30
04-23-2019 01:39 AM
TSX69
21
02-08-2018 02:18 PM
zootjeff
01-05-2012 10:52 AM
Acura604
1G RDX Tires, Wheels & Suspension
11-28-2011 08:39 PM
Quick Reply: Spare tire for FWD advance
