3G RDX OE Wheel Info
Part numbers and specs courtesy of contributor EE4Life:
2019 Acura RDX 19 Inch Aluminum Wheel
http://www.urvi.net/forumfiles/SB/BII07802-27.PDF
http://techinfo.honda.com/Rjanisis/p...II07802-27.PDF
2019 Acura RDX 20 Inch Aluminum Wheel
http://www.urvi.net/forumfiles/SB/BII07802-28.PDF
http://techinfo.honda.com/Rjanisis/p...II07802-28.PDF
Adding OEM tire info (https://www.acura.com/news-and-press...90-en#interior)
RDX and Advance Package
- 19 x 8-inch painted aluminum alloy wheels
- 235/55R19 101H Continental CrossContact LX Sport all-season tires
- 19 x 8-inch machined-face aluminum alloy wheels
- 20 x 8-inch Shark Grey aluminum alloy wheels
- 255/45R20 101V Goodyear Eagle RSA all-season tires
I think that Base, Tech, and Glint Black (accessory) are all the same basic 10-spoke Enkei wheel with different paint treatments.
The base wheel is painted glitter silver.
The Tech Wheel is painted gray and then, the face is machined.
The Glint Black wheel is painted metallic black.
All three are then clear-coated.
Charging an extra $2,000 for the black paint treatment is really greedy.
They probably still charge to install the accessory wheels.
Glitter Silver (RDX)
Pewter Gray (Tech)
Glint Black ($2,000 accessory)
Pewter Gray (Tech)
garunas (11-20-2018)
Anyone got the specs on the A-Spec wheel? The links above point to the Glint Black accessory wheel. Looking specifically for the weight on them as I'm likely to swap them out for something that's less of a boat anchor.
Sorry for the delay but here is the info. Weighed on my bathroom scale so it might be +/- a lb or two. I also took a pic of the back of the wheel showing the offset and dimensions.
supafamous (01-15-2019)
Do they sell the prototype wheels?
https://cdn.motor1.com/images/mgl/lv...-prototype.jpg
Styl1n
i got that advanti hybris for my Aspec TLX when i weighed the wheel it was actually 19 lbs Andy it made the world of difference on the car, felt like 500lbs was lifted off
supafamous (04-06-2019)
Lynda
11-10-2016 07:25 PM
Jeff Sloan
30
10-10-2009 08:58 AM
TLAwesome
08-07-2008 11:32 PM
