Is a 35 sidewall profile tire ok???
Ok how? What size wheels did you get? If you are still on 20"s there will be a little more fender gap, unless you are squeezing a slightly wider tire on it in which case the profile may be similar. The 35 ratio tires will likely ride a bit stiffer and I would really avoid potholes!
You're replacing a 29" tire with a 27" tire.
Your wheel gap will look worse and your speedometer will be off by 7%. (Indicated 60 mph will actually be 55 mph).
Is it too late to change to 255/45/20?
The following 2 users liked this post by catbert430:
Leaf 68 (08-08-2024),
supafamous (08-05-2024)
