Rattle Noise on Infotainment Monitor
has kept my car for 3 months and notices that there is a rattle noise out of the monitor when car runs on bumpy roads. Anyone has noticed the same issue here?
An example is I have/had a rattle in my RDX that sounded like it was coming from the passenger side dash vent. When I mentioned it to my wife she thought I was crazy because she was hearing it from somewhere behind my head near the seat belt height adjuster (in turn I thought she was crazy). After a bit a playing around I/we finally located the true source - it was a pair of spring loaded clip-on sunglasses in the overhead console, moved them and the rattle was gone. In other vehicles I've had rattles, once they were found, under the rear seat that sounded like they were coming from the top of the rear hatch.
catbert430 (09-13-2018)
The biggest problem with noises in any vehicle, but especially vans, SUVs and CUVs, is they 'telegraph' - meaning they sound like they're coming from somewhere other than where they actually originate.
Sent my car to dealership for regular service as well as checking the rattle. Service manager confirmed that there was a rattle noise coming from the top of the screen frame. Rattle went away if putting pressure at the top. Service guy tried to put foam in between dash and screen but did not work. They asked me to pick up the car and reschedule another time so they can have more time working on it. Manager mentioned they may have to order a new screen but they want to check if the rattle is from screen itself or because of the way it sits on the dash.
I am very sensitive to rattle noise in cabin in general. It really annoys me. I will keep everyone updated.
If you have a similar experience. Please share.
The following 2 users liked this post by joe424242:
romer (10-13-2018),
securityguy (09-28-2018)
I just noticed this for the first time once the morning temperature dropped into the 40's this week. Pushing on the screen made it stop for the day. I heard some other light rattle sound from the dash area. I expect we'll see more of these once it turns cold as parts shrink.
Anyone got any updates for this problem? I am receiving a rattle noise from the front cabin when going over any bumps. I checked and put some pressure on the monitor and, but that did not resolve the rattle noise.
Here are some updates:
1. I recorded the rattle noise before I sent my car to the dealer and confirmed with them.
2. I was able to show in front of the service manager that my car had rattle noise when i knocked the dash with my fist. And they confirmed that the rattle disappeared when i put pressure on the monitor.
2.5. I knocked the dash of another ADV trim in their showroom, and found no rattle.
3. Technician put some padded material in between the monitor and the dash behind of the monitor to see if it would damp the rattle but it did not work.
4. Technician said the only way they could figure out was to take dash apart and took the monitor off to see if the rattle was from the monitor itself or from the dash.
5. I was very concerned about taking dash apart for the car i just have owned for 4 months. It would give me more issues including rattling after they put them back in whole. So i cancelled the second service.
6. After I got home, i inserted more soft material to fill up the clearance in between the dash and the monitor. and rattle still existed when i knock the dash.
7. Interestingly, i have not heard any rattles while driving since that, but still can hear when i knock the dash. Just want to clarify that the rattle sounds different during driving and by knocking it.
8. I am okay with that for now, but it is definitely something to do with how the monitor sits on the dash. Hope it helps.
8.
8.
Thanks Joe for the information. I do not think the noise I am dealing with is coming from the infotainment monitor itself. The noise I am receiving, either going over bumps or uneven pavement, is a rattle noise near the driver side dash near the windshield. I'll ask the dealership during my next oil change.
quick updates:
the rattle noise has come back over the weekend. I am pretty positive now it is not exactly from the monitor. It is actually from the little plastic dash in front of the monitor where it sits. That's why the noise disappears when i press the monitor down.
I will seek for a solution myself if i could put some materials to damper the rattle.
quick updates:
i finally confirmed that the rattle was not from the monitor itself. It was actually from the center speaker cover behind the monitor which is the part of the dashboard. I believe something is rattling underneath the speaker cover. I filled some foam strip in the gap between speaker cover and the dash to stop the cover from touching dash when the car goes on bumpy road. It has been working so far and will see how it goes.
thanks,
thanks,
I had a lot of rattles in my dash for weeks! It was driving me crazy. I finally figured out that it was the trim near the windshield that was creaking like crazy when going on uneven roads. So I put some foam between the trim and the windshield (not too much because the defrost vents are there and I don't want to block them) and now it is sooooo silent, I can't believe how much creaking was coming from only this place. Here's 2 pictures of what I did (it is not very visible but I put a flash for one the photo to see it....)
With the flash to see the foam
oz13ms (11-01-2018)
i do have the same issue here too. I put some foam to press the trim down
AdvanceMDX
3G MDX (2014-2020)
21
04-04-2014 08:17 AM
db22
3G RLX Audio, Bluetooth, Electronics & Navigation
14
11-30-2013 10:25 PM
