Audio, changing station error
Old 06-15-2018, 04:53 PM
2019 RDX Tech SH-AWD
stevesTL's Avatar
First glitch occurred today. I tried to change the preset Sirius radio station using the thumbwheel on the steering wheel. Got “system error, function unavailable”. After about 5 tries I changed the station using the touchpad. After that it started working again. Thought I’d note the issue here in case someone else has gets this error.
Old 06-16-2018, 09:24 PM
stevesTL's Avatar
Next software glitch. I transferred 3 Cds to a usb and tested in the car. No issue. I filled the USB drive with about 12 cds and took to the car. After inserting the usb drive it would not recognize the usb. I tried turning off/on audio, no luck. But turning off car and restarting cleared the issue. I am seeing software issues. Where were the testers on this basic stuff??
Old 06-16-2018, 10:54 PM
guytdt's Avatar
My experience is different. I once turned on engine and no sound. It’s loading for 5 minutes and I give up by clicking home, then select FM, then it works again.
Another hiccup is when I search for nearby airport, it gave me a list, I select one for routing and I see it loading then says cannot find the address???
Old 06-18-2018, 09:26 AM
Meto's Avatar
I have had this happen to me as well..
Old 06-18-2018, 10:10 PM
rek
rek's Avatar
Same problem happened to me yesterday. I also changed to a different channel using the touchpad, then the wheel started working again.
Old 06-19-2018, 05:30 PM
markm929's Avatar
Same thing happens for me. I usually just hit the apps button on the wheel and have sirius as the top app. Select that and then the thumbwheel works as intended. Definitely needs to be looked into by Acura.
Old 09-11-2019, 10:26 PM
Ily Sayarh's Avatar
Any updates on the error message that pops up when changing radio station via thumb wheel?
Old 09-12-2019, 07:47 AM
Meto's Avatar
Nope.. From what I have read it is still happening
Old 09-12-2019, 09:56 AM
MT-RDX's Avatar
The revision document issued with D.1.1.2 says it fixed that problem -- It didn't. It is still there after D.1.1.4.
The quick and easy work-around is to turn the audio OFF with the steering wheel button or the volume knob on the console, then turn it back on. Wait until the graphic reappears on the center display and then the thumb wheel works again.
MustBeTL
01-05-2012 09:54 AM
deepee5
07-13-2010 03:52 PM
pallen
07-03-2010 08:15 PM
ac-inblack
12-13-2009 07:20 PM
ityper
04-07-2008 10:37 AM
Quick Reply: Audio, changing station error
