Stage 3 Phearable Tune Reliable for Daily RDX?
Hey, just looking for input on experience with Stage 3 on a RDX used, obviously, as a daily driver. I hear some people say about other car brands that running a tune on a daily because the normal use can lead to issues when components are getting pushed. I'm slightly worried I'd blow the turbo or something.
I'd like to flash a phearable tune on an otherwise stock 2020 RDX Aspec.
Any reliability issues or repairs needed that anyone has experienced with a stage 1, 2, or 3 tune? What mileage and use history?
Maverick1125 (04-01-2022)
These are OTS tunes. They still are well within the OEM parameters of operations. Once you start putting bigger turbo's and messing around with pushing the boundaries you might start seeing failures.
no issues other than traction!
I don’t think any OTS tune will hurt it at all
tsloan71 (05-02-2022)
Maintenance is key to everything. Do your scheduled maintenance and every once in a while lift your hood check your oil. Top off if needed clean the engine bay and look for obvious issues a lose hose clamp etc. It will go a long way and it will help you get familiar with your engine and parts locations.
I had a EVAP hose I completely forgot to slide the clip back over when I was changing a part. Drive fine for a week and the one day I get on it. It blew the hose off the intake cause it wasn't clipped got out and quick fix cause I knew where to look where I was working.
Get in the habit of every 2 weeks pop your hood and wipe the motor down. It will go along way in getting you to being able to visually see a possible issue.
ya seems they built these fairly durable. You don't see much for major issues unless people start pushing past the know FWD limit of 470whp or something custom no one has done before. the powertrain is pretty strong impressed really I would just go tiny early on scheduled maintenance as a best practice especially if you are going to beat on it daily.
Do these tunes cause any shifting abberances like BMW tunes can if you don't change the TCU?
What ends up happening is in the 1st 2 gears the transmission is desperately trying to shift but it can't, this results in popping or sputtering between gears.
If your in a more extreme climate its even possible the transmission temperature will cause some short shifting coming out of 4th and 5th gears, you can combat that by allowing the car to cool between runs and or install a transmission cooler.
If you had access to command shift points you may be able to work around this; however, any RDX I've seen making over 375 WHP+ will experience this problem.
Sure you can use manual mode in S and do the shifting; but in some way your going to piss off the TCM to some degree and there's no guarantee you'll have perfectly clean shift points.
If you go to the 2:10 mark in this video
Note: Video is from Mike at Axion who is great to work with for upgrading your RDX.
If the vehicle is full bolt on with a stage 2 turbo you will most certainly have some issues overloading the transmission software.
If you go to the 2:10 mark in this video https://youtu.be/Aj950-44ILk you will hear what I'm talking about, and as you add more power it only gets worse.
sonyfever (09-10-2022)
They also are capable of commanding shifts slightly faster then what we would see in 2019-2021 RDX's; however, the 22 RDX ASPEC's have revised TCM Software giving them faster shifts with no changes to the gear-set.
My guess it yes the Type S variants would be better suited to handle power in excess of 400 WHP / 500 TQ with reliability in mind.
In an Accord 10AT you are working with a significant difference in vehicle weight, but in the case of the much heavier RDX this will factor in to how quickly the TCM will put you back in the friend zone.
There really isn't much you can do other than turn it down a bit, otherwise you're not going to see repeatable reliability.
So with this said the RDX will be stuck in the mid 4's to 60 and 1/4 mile of mid to low 12's, with the transmission being the limiting factor.
sonyfever (10-31-2022)
