Blackout! Turning an Advanced into an A-Spec
#42
You'll Never Walk Alone
Thank you!
Those are RTX Envy, pretty much TSW Nurburgring replica. They are the same size as the A-spec rims.
It would be nice to remove the trim pieces but I didn't haha. I wasn't quite sure how they can be removed and I was worried about scratching/breaking something if I do try to remove.
#43
Did anyone try buying the Aspec trim accents from an online store and try replacing the chrome accent pieces with that? Please let me know if you did and how was that experience. I see that some of those trim pieces are available for purchase from an online store (Bernadi I guess), and I would be more comfortable doing that if those parts can be replaced without scratching the car.. Let me know guys..
BTW I ended up buying the Advance package (Black color) and trying to convert that to all black to match the aspec version.. I've grown to love the interior of the advance as well. Didnt think i would like the wood material on the inside, but it is growing on me.. love the car so far..
JB in AZ (05-08-2019)
#46
2019 BMW X3 M40i
#47
How do you feel about the headliner? The fact that I can't get a black headliner with Advanced is seriously making me consider going to the Germans. Petty, I know, just how I feel. Not that sold on the wood trim either, but I'm more interested in having an all black interior.
97ws6 (05-14-2019)
#49
2019 BMW X3 M40i
Dochorahan (10-19-2022)
#50
What turned me off on the Advanced was not the price difference. Smaller wheels, terrible looking rims and red interior. The looks is more important to me. If I could get A-Spec look and Advance features I would in a heart beat.
#51
I'm looking at doing some chrome delete on my AWD Tech, including the chrome up around the door windows and the piece that is above the rear most small windows. However, I can't find a good online parts diagram really anywhere that gives me the A-Spec part numbers for the black replacement pieces. Does anyone know what the two part numbers are for these? Also, is there an online OEM parts site that actually has full and zoomable parts diagrams? I'm also not sure where I am going to get these parts. It seems like the savings from the online parts places just get money back in shipping vs. dealing with a local dealer. Here is the part I'm looking for in black for the L and R sides:
#52
#54
Well, I've never messed with that, so probably will do a "partial" chrome delete. I am doing the front and the black sides with A-SPEC parts, but leaving above the windows. When I bought mine, it had the chrome roof rails, so I'm not going to physically replace those and there is also a touch of chrome still on the front badge and the rear badging. So, I guess my project, for now, will be a partial delete.
The following 2 users liked this post by chappyja:
19 RDX A-Spec (01-18-2021),
MrmissmyTLX (01-23-2020)
#58
I'm sure there are cheaper ways to go with wrap/vinyl, Plastidip, etc. but I chose to stick with the OEM Aspec replacement parts that I got from Curry. The part numbers for these parts are:
Garnish Assembly, L Front Door Middle *NH547* (Berlina Black) 72352tjba11za
Garnish Assembly, R Front Door Middle *NH547* (Berlina Black) 72312tjba11za
Garnish Assembly, L Rear Door Middle *NH547* (Berlina Black) 72852tjba11za
Garnish Assembly, R Rear Door Middle *NH547* (Berlina Black) 72812tjba11za
Those 4 parts delivered were just over $170, so again, not the cheap route. Also, when removing the chrome plastic off, since it is held on by about 8 clips and adhesive, there was almost no way to preserve the pieces. The good news is once off, the new part come with new adhesive and all new clips, so I was able to use a diluted alcohol spray to clean the area really good and then the new pieces popped right on.
I also got the Aspec parts for the front, but I haven't installed those yet. Since the entire front of my RDX is PPF'd, I'm having the parts done and then I need to carve out time to investigate what is involved with the grill trim and lower chrome swap entails. If anyone is close to Raleigh and knows how to do this sort of thing, PM me LOL.
TEAMSLO (12-30-2019)
#59
#60
These are the parts that I got for the front:
Molding, Front Grille Surround 71122tjba50
Garnish, L Front Bumper Trim 71109tjba50
Garnish, R Front Bumper Trim 71104tjba50
Again, not cheap - around $250 for these 3 pieces. I think the front bumper needs to be lowered or removed to get to the screws to the remove the grill bezel. The other interesting thing is that the black Aspec lower trim pieces to replace the chrome ones are a different shape all together. It appears that the honeycomb black plastic piece behind it is the same on the Aspec vs. the Tech, but I need more information to see how the new piece attaches. Here are the pics for the different pieces to compare.
#61
#62
#63
It first started with a call to my brother-in-law who is a higher up at a chain of collision places in SW Michigan to make sure I didn't screw something up I used a plastic trim removal tool to slowly work the end at the door opening side on the front doors, while the door was open. Once I got the trim started, I closed the door and I slowly worked it off to break the adhesive loose, which got me to each of the plastic clips. Some popped right out and some were not easy at all. I just slowly worked it down until the whole piece was off. Then I used a diluted rubbing alcohol spray on a micro fiber to clean that whole area really good. Then I aligned the new piece's clips, peeled the tape from the adhesive and the new piece popped back on. The entire job was about 30-45 minutes.
#64
#65
Well, I confirmed I need a few more parts but at least the bumper is the same. The honeycomb behind the chrome piece and above the fog lamps is a different piece.. more $$$$$. I know the parts to get but have to order them. Here is the difference in closer up pics.
RDX crew (01-16-2022)
#66
this forum is getting more and more interesting ... keep it up guys.. I am also tempted and will go with p-dip. But I don't want all chrome to black so trying to find the right balance.
Any RTP/Raleigh/Cary area guys want to meet-up ???
#67
#68
Yeah, I used my hands as best as I could to pop them out. I'd wear some rubber gloves or something because it can be pinchy, especially if you are trying to not damage the clips or the molding itself. Since I was replacing all of it with the new stuff, I used a bit more force than if I was trying to not damage the pieces.
#69
#70
What other parts are needed? Can you send full parts list for two front pieces?
#71
There was no glue left on the door panels. I just used the Alcohol spray to clean and wipe off the dirt, etc. that was behind the molding
#72
I don't want to post any more parts until I can confirm that what I ordered was correct - then I'll post all of these parts with pics in one posting with the costs, etc. and any "gotchas" to help people do it easier than what it took me to do it
#73
#75
Here is me: https://m.facebook.com/daniel.charles.733
#76
Sorry, I am not. I would love to help otherwise. I changed the SH-AWD and RDX logos to black chrome. I will be doing the two side chrome pieces to black tonight! I will send pictures soon!
#77
Ok, quick update on my end. Just finished the black chrome RDX and SH-AWD badges to replace the chrome from the factory. They definitely aren't "black" compared to the other black ASpec pieces. The part numbers are:
RDX Logo is: 08F20-TJB-200
SH-AWD Logo is: 08F20-TZ3-200A
Instructions are here from another link on the forum: http://www.urvi.net/forumfiles/SB/BII07802-03.PDF
Both parts shipped to me from Curry was just about $75.
Install was pretty easy as I'm not a seasoned mechanic. Maybe 45 mins total and I took my time not to make any mistakes. Printed out and read the instructions to make sure I had everything I needed. For the nylon string I used dental floss. Probably went through about 4 feet of it with the breaks, but once I got about 50% through the factory badging, I was able to do gently peel the rest off. Once it was entirely off, I gently removed the remaining glue/tape and then used a micro fiber towel with some diluted alcohol spray to clean the area really good. I am including a before, after and one that shows the difference when you literally hold the regular chrome next to the black chrome, so you can all see the difference for yourself.
The following 3 users liked this post by chappyja:
#78
chappyja (06-13-2019)
