Fuse size
Fuse size
Hello,
I'm trying to hardwire a radar detector to the fuse box. I'm trying to buy a fuse tap adapter. What type of fuse does the 2019 RDX use? I see different types such as micro, mini, mini low profile, etc. I wasnt sure which fuse tap adapter to buy. Any recommendations from Amazon would be helpful. Thank you.
8th Gear
Mini Fuse Works
Not sure of the proper terminology, but on my 2021 the fuses are the same blade configuration as a mini fuse but are only half the height (mini low profile?). I needed power for my trailer wiring power module and just used an Amazon mini fuse adapter. It sticks out of the fuse box more than the other fuses but with the additional fuses on the adapter it sticks out anyway. Seems to work just fine and now I have an extra 10 amp mini low profile fuse!
desibaba
01-08-2023 03:03 PM
eric25332
05-14-2010 04:27 PM
