2020 RDX A-Spec Remote Start
Old Mar 29, 2022 | 04:18 PM
AC74's Avatar
4th Gear
Hi all,
1st post. My question is can I use a key fob instead of using the app?
Old Mar 30, 2022 | 10:09 AM
jcross1231's Avatar
Touring
Originally Posted by AC74
Hi all,
Apparently not unless you've got the 2022 model.
Old Mar 30, 2022 | 01:50 PM
arjaykay's Avatar
If you have remote start installed in your RDX, you should have received one or two fobs with the remote start on them. I only use my fob to remotely start my RDX (2019 Advanced).
Old Mar 30, 2022 | 01:57 PM
AC74's Avatar
4th Gear
I have a 2020 RDX ASpec and I can remote start it but I have to use the telephone app. The dealer gave me two keys but each fob does not have a remote start function on it.
Old Mar 30, 2022 | 03:31 PM
jcross1231's Avatar
Touring
Same here - 2021 Advance. Have to use the app, which there is a charge for after a few months.
Old Mar 30, 2022 | 06:32 PM
arjaykay's Avatar
Key fob for remote start.
https://www.oemacuraparts.com/oem-pa...al-72147tz6a71
Old Mar 31, 2022 | 11:03 AM
Claude.'s Avatar
The two remotes of my 2021 A-Spec do have the remote start (I'm in Canada if this matters).
Old Mar 31, 2022 | 12:25 PM
RDX-Rick's Avatar
Hi all,
I am also in Canada, and my 2020 Platinum Elite has the remote start on the FOB.
According to the owners manual (2020). the RDX has 2 types of FOB available. Only the 2-way remote has the the "Engine Hold" button, and the 3 indicator lights. To start the engine the "lock" button must be pressed momentarily, and then immediately press and hold the "Engine Hold" button for about 3 seconds.
If you don't have that button on your FOB, then you can't start your RDX using the FOB.
FYI The 2-way remote will flash a green light momentarily if the engine starts successfully. It will also flash the same green light if your attempt to lock the doors is successful. The "acknowledgment" indicator is handy because I can communicate over 1/2 kilometer with the FOB.
Old Mar 31, 2022 | 01:17 PM
AC74's Avatar
4th Gear
Thank you for the replies would anybody know if I purchase the two wake communication key fob which I do have on my 2020 MDX. If I purchased that key fob for the RDX would I have to get that programmed to control the remote start or would it work out of the box?
Old Mar 31, 2022 | 01:20 PM
arjaykay's Avatar
The dealer has to program the fobs in order for them to communicate with your vehicle.
Old Mar 31, 2022 | 02:02 PM
AC74's Avatar
4th Gear
Probably just easier having the phone and no key fob and pay 110 per year.
Old Mar 31, 2022 | 02:07 PM
jcross1231's Avatar
Touring
Another advantage is you can start the car from a farther distance away. Might also be cheaper over 2 or 3 years.
Old May 15, 2022 | 03:10 PM
RDX-Steve's Avatar
3rd Gear
Thank you for posting this!!! I may have overlooked this in the owner's manual and didn't ask for the full walk-around from the dealer to show all the features....but I knew my RDX had remote start due to the key fob.
gadgetfreak
3G RDX (2019+)
15
Mar 9, 2022 09:24 AM
Josh H
2G RDX Problems & Fixes
Jan 13, 2020 06:51 AM
clemsonsteve
2G RDX DIY & FAQ
Apr 30, 2017 10:46 PM
Type34
Jul 10, 2016 12:47 PM
PERDY
14
Apr 26, 2007 10:17 PM
