Tire pressure
Tire pressure
Ok I know this is going to seem like a silly question but gonna ask anyway. So when I picked up my RDx a few weeks ago, brand new, I noticed the tire pressure was like 43-45. Thought that was high and according to the door it is. Max tire pressure according to sidewall is 51. I let some air out and now around 40-41. I know it is above the recommendation on the door jam but I love the ride. I was reading another thread, I think it was about the Acura Link App and somebody noticed the tire pressure and was also around 40-41 and made the comment that they were way over inflated. I was under the impression the door jamb pressures were for the best ride but as long as mine are under the actual tire limit, does it really matter??
thanks
thanks
thanks
thanks
thanks
thanks
Feel free to keep your tires at 40 PSI, but as has been mentioned by DJA123, this pressure may leave you with pressures over the max.
The following 2 users liked this post by EXCALIBUR1:
fogdoctor (06-26-2020),
grandicornis (06-25-2020)
Yes, much nicer ride and less road noise too. As mentioned above, mfg ships the cars with the tires really pumped up so they are less likely to get flat spots when parked on the lot for extended periods or maybe to help seat the beads. The dealer was supposed to adjust the pressure before you got the car but it seems they rarely do.
Go with the number indicated on the door post. ( or was that the gas door?? )
I tried 33, 34, 35, 36, 37psi because I could not help myself. When my wife drives it I set it to 33 because her commute runs on some pretty crappy roads. I have a most highway commute and 35 works great. Higher than that makes the ride not as smooth IMO. I did not bother going over 37psi because I did not like the ride.
I figured out why so many RDXs (and others) are delivered with over 40 PSI in the tires. See what I BOLDED below....
This is from the "TQI" (Total Quality Inspection) formerly known as PDI, or Pre Delivery Inspection...:
"To prevent flat spots during vehicle shipping and storage, the tires are inflated to over 40 psi. If the vehicle is going into dealer storage, leave the tire pressures at 40 psi until it is sold. When the vehicle is moved to the sales lot or is sold, adjust the tire pressures. Turn the ignition to ON. Set the pressure in each tire to the recommended value listed on the driver's doorjamb label, and check it with a hand-held gauge. If you are in a cold climate region, make sure the tires are at the same temperature as the outside air before adjusting the pressures, otherwise the Low Tire Pressure/TPMS indicator may come on in cold weather. Test-drive the vehicle for at least 1 minute above 22 mph. If the MID does not show the tire pressures, make sure you completed the test-drive as specified. Be sure to check the pressure in the spare tire (if equipped).
So, when they sell the vehicle, it gets a wash, and they are supposed to lower the tire pressures at that point. Yeah. NOW I know why so may new cars are delivered with over 40 PSI in the tires.
OH, also: " New Tire Pressure Sensors Beginning with the 2021 model year RDX, Base and Tech trim levels will come with rubber valve stem tire pressure sensors. Advanced and A-Spec trim levels will keep their metal valve stem tire pressure sensors."
"I'm looking at the new RDX and can't decide if I want the Tech or the Advance trim. Oh wait, the Advance has metal valve stems?! Sold!"
JB in AZ (06-28-2020)
Yeah.....I don't get it If they are saving a few cents per car, just put the rubber ones on all trims....
Just a note:
Tire pressure is a big issue, really. First of all, NEVER look at the pressure on the side of the tire. That is a MAXIMUM pressure the tire is rated to safely hold and has nothing to do with what your vehicle actually requires. As I told a class once, that size tire fits on a wide range of vehicles of different weights. How could the tire maker know the final application?.
Pressure that is too low or too high causes tire and handling problems. Too low and the tread buckles and rolls and you wear out the side of the tread. But worse than that it causes excessive flexing of the sidewall and this can cause the tire to run hotter and even fail. (Ask Ford and Firestone about this, they had this issue with Explorers and got some major law suits out of it).
Excessive tire pressure will cause the tire to lose some of its contact patch with the highway. While this may give you a tire that will run cooler and use less fuel the price you pay will be a tire that wears the center of the tread more and which will not grip the road nearly as well, especially under conditions like a wet surface.
Tire pressures are normally determined by testing to find the best balance between all these factors: Tire running temperatures, proper contact patch, economy (while working properly), and ride quality.
Always set tire pressures while the tires are at "ambient temperature of the surrounding air". (Or...what is refereed to as a "cold tire".) Tires will warm up and the pressures do increase. Don't set pressures while they are warm.
The sticker on the vehicle is required by Federal law. Its the best pressure to go by. Personally I have found that you can go a pound or two higher but not more. As you add weight to the vehicle you may want to increase the pressure. Whenever I am driving any distance with a loaded vehicle I will feel the tires while stopped to make sure they are not getting warm. Hot tires are a clear sign the pressure is lower than needed for the current weight. Lower pressures are never advised as they will cause these higher temperatures to develop and can result in premature tire failure in extreme cases. Some people think lower pressures give them a smoother ride, which it can, but again, the price is worse performance of the tires and possible tire failures.
has anyone set their tire pressure at the recommended rate prior to long drive? I set mines to 35 PSI cold and on a long trip they went up to 37-38 PSI.
I'm going for another long drive in 2 weeks, thinking of dropping them down to 33 PSI cold. so that when the tires heat up they wont get as high. anyone try this? I want to drive and preserve my tires for as long as possible, im rotating every oil change, but I've only had 1 change, m at 9500 miles, probably when I return from this trip I'm sure I'll need to change the oil and rear differential.
Another question: if the tire pressures are too high, is it possible to just let the air out and have the car indicate when the pressures are where they should be? Or do I need to get a tire pressure gauge and let some out and then recheck it, like with any other car?
https://owners.acura.com/utility/dow...ing_System.pdf
Right, but is "tire fill" just for when you are low and adding air? Or can I just let the air out and it will notify me when I get to the correct pressure? Like I don't want to be letting out air and then it's flat and I realize it never warned me.
maybe it would update if i waited long enough, but i didn't have the patience to find out.
OK, thanks, that's what I thought. I was hoping I could just let the air out and it would tell me when to stop.
You tires can safely operate at a much higher pressure than you might think. While this is not recommended it is a safety margin for tries that get a little hotter and drive up pressures. I like the dash display but the professional in me demands I always set pressures with my hand gauge. (For many years I have used my nice German Dräger <no longer available> unit whick I prefer to use just because I totally trust it and its easy to read).
JB in AZ (08-11-2020)
Thank you, yes I knew that. What I didn't know was that the dealer would sell me the car with such over inflated tires. Didn't know that was a thing, I assumed a brand new car was good to go the way it is when I drive it off the lot.
NOt surprising. I have found that happening with other car owners as well. I believe the cars come like that to the dealer. Unfortunately, good skilled trades are becoming extinct or hard to find.
Stop behaving like having tire pressure over what the door jamb states is going to be dangerous or cause an instant blow out. You're fine. Even the "Max" tire pressure on the sidewall by the tire manufacturer is conservative. As stated prior, the recommendation by the manufacturer on the door jamb takes into account ride, handling and gas mileage, among other things. Being 5-10psi over isn't going to hurt anything, except maybe your backside. As far as hot vs. cold, the most I have seen the tire pressure go up is 4psi while driving on hot summer roads, less in the winter time (usually no more than 3psi, usually only 2psi). If you're doing very spirited driving, probably a bit more. 40psi, you're fine if you enjoy the ride like that. You'll get slightly better gas mileage, I'd just keep on eye on the tread and make sure you're not wearing out the centerline of the tread more quickly. Again, I'd be flabbergasted if 40psi actually did that.
Just a story as an aside, if you're still with me, when I used to wrench on cars. Regular customer came in after working in the city and asked me to check to see if there was a leak in the tire because his TPMS had gone off. He filled the tire up that looked low after sitting all night at a gas station closer to his house until the light went off. Then went to work, came back and stopped at my shop ... nearly 100miles round trip. Very nice guy. Took the wheel off and found a screw, but it was basically at the cup of the tread and the sidewall, plus his tread was at the wear markers to begin with. Told him it wasn't safe to plug/patch it due to the location of the screw and told him a place he could get tires at a good price and quick service. I would have done it for him, but it would have taken a lot longer and probably been more expensive for him. He thanked me and asked if I could just check the tire to make sure it wasn't low. Of course. Bam. 80psi. On a passenger tire rated to only 40-something, driving on the highway, nearly 100miles, on an old worn tire. And this was after it had leaked out some, so he probably had close to 100psi in that sucker. I was shocked he didn't have a blowout. Told him, we laughed, took some air out so he could safely make it to the tire shop on the other side of town. Since then, I've realized that tires are way more resilient than people give them credit for. I'm not saying to go and do that, but these things are strong. You're more apt to destroy a tire by running it low on pressure than high.
Funz51 (08-13-2020)
you are right, they should have checked the pressure before you left the lot. They keep it high like that so when transporting and sitting, the car tires do not get flat spots. At least it lessens the possibility. I saw the same when I left the lot.
leomio85 (08-13-2020)
It's certainly not the same caliber vehicle, but I really enjoy this guy's videos. Unfortunately, it seems like Porsche is shutting him down from posting more videos:
Add me to the list. Picked up my 2021 Advance Saturday, never thought to check before leaving the dealer. At home (knowing) the pressure would be high from driving the pressure was 45. I let the tires cool down for the day and later reduced the pressure to 35 psi with my tire gauge. Same reading with the RDX.
I took this advice and you were correct EXCALIBUR1. At least I noticed a bit of improvement in the noise factor of my Conti's + a smoother feel overall even though the car had an exceptional ride already. It's the little details that matter in life. The Conti's were between 42-45. Anyway, thought I'd let you know. Thanks.
EXCALIBUR1 (09-05-2020)
I upgraded to 20" wheels and tires and applied the door jamb sticker for 20" wheels from the A-Spec.
The 19" tires have a manufacturer recommended pressure of 33 psi and the 20" tires are recommended to be 36 psi.
I run at 36 but, every time the dealer services the car, they reset them to 33 because it's a Tech model without looking at the placard.
I definitely lose 1.5 mpg running at 33 psi and have to go back to 36. 33 does not improve the ride at all.
