Small screw on my tire
Wash the car this morning to find out that my front right tire there's small screw on my tire, bit on outer side, according to ppl cannot be fix, need new tire , I just left it there incase, I am thinking bringing it to my dealer, do you think they would replace me with new tire with a discount price since the car is new?
Originally Posted by Yotrek
(Post 16325720)
...I am thinking bringing it to my dealer, do you think they would replace me with new tire with a discount price since the car is new?
If anything I'd check to see if there might be road hazard coverage from the tire manufacturer (probably not but it wouldn't hurt to check). |
Originally Posted by MI-RDX
(Post 16325726)
If they do you have a very good dealer. Why should they take any responsibility for something that happens to the vehicle after you drive it off? My last vehicle I got a rock chip in the windshield a week after I got it - would never even consider asking the dealer to do something for me because it was new.
Don't buy the tire at the dealer. Go to like Discount tire and see if they can fix it. Then only replace the 1 tire.
(Post 16325728)
Exactly, the manager told me that I have road hazzard coverage when I pick the car up..will see
So... You should remember if you paid for that (the manager shouldn't have to tell you whether you have that coverage or not). Does your contract show a line item for Road Hazard and the amount you paid for it? I paid $490 extra for that. |
To add (which I'm sure is the reason there would be doubt the RDX's basic tire warranty would cover running over a screw):
Tire warranties that come with cars cover manufacturing defects, not randomly running over a tack on some random road in some random place (this falls under the category of "road hazard," which like I said, is extra coverage that you pay for). That's truly not Conti's nor Goodyear's nor Michelin's, etc., fault (liability) that that happened. Here's the page that discusses tire warranties in the PDF in the Warranty tab in owners.acura.com: https://cimg6.ibsrv.net/gimg/acurazi...f087460efe.png |
Originally Posted by birdonamission
(Post 16325810)
(Post 16325824)
Thanks for the info |
Is this can still be plug?
https://cimg8.ibsrv.net/gimg/acurazi...dad0716c53.jpg |
(Post 16325831)
Is this can still be plug?...
Yeah, Discount will more than likely remove that screw for free
(Post 16325831)
Don't take it to a chain place - they will claim liability blah blah blah and will try to sell you a new tire. |
Thanks all for the input, Costco told me can’t be repair, need new tire because close to the side, I kind of don’t believe them too.. |
Discount won't repair it if it is within 1" (I believe) of the sidewall of the tire. I went through this on my 2G RDX. Your screw appears to be pretty close to the no fix zone. My discount had a sample tire on the showroom floor that had been painted up showing the area they won't touch. They will tell you right away if they can fix it. If you are very lucky it is a short screw that didn't penetrate through the tire.
It can definitely be plugged but you might not find reputable tire shop (Discount, Costco etc.) to do it due to the liability involved. |
(Post 16325888)
Thanks all for the input, Costco told me can’t be repair, need new tire because close to the side, I kind of don’t believe them too.. Take it to an independent tire shop and see if they'll do it then. Costco is just CYA: Covering Your (their) Asses. They don't want the liability if their repair fails since it's so close to the sidewall. I had a similarly place screw near a sidewall and a shop was also able to repair it. Not sure why you think someone would give you a discount for a new tire though.. :squint: |
(Post 16325831)
https://cimg8.ibsrv.net/gimg/acurazi...dad0716c53.jpg Something like this: https://www.fleetfarm.com/detail/cam...hoCMCYQAvD_BwE its a patch with the plug attached to it, but the patch part is important |
^^^^ This. The patch with plug installed with the tire off and the proper application of "vulcanizing glue" will help prevent the leakage of water that can rust the steel belts which can cause failure of the tire. A patch only can let water in from the tread side, a plug only may allow stress cracks to radiate from the repaired hole.
Originally Posted by Jim7707
(Post 16325952)
(Post 16325952)
I drop off the car yesterday at my dealer to have them look at it, first thing I ask if there's warranty on the new tire if it need to be replace, after checking on the warranty that come with my purchase, he told me yes, it's under warranty, but turn out when they take the screw off the tire, it actually just small and short screw, so didn't penetrate, and its all good they said...FYI
Originally Posted by subin
(Post 16326989)
I recently had a 3/4" screw on the tire on the BRZ, but did not penetrate it and no leak thus far. I am a little worry about driving hard would put stress on the spot and somehow tears that now thinner spot. Please tell me I think too much...
(Post 16327025)
(Post 16326989)
(Post 16327380)
Don't worry about it. In the past I've put 40,000 miles on a tire with 2 plugs in it. Nothing bad happened. Is it possible? Yeah, anything is possible but in this case not likely.
Originally Posted by ednigma
(Post 16327363)
So did you pay for road hazard warranty - was it slipped into the price of the car? Or was it provided pro bono. As discussed, usually road hazard warranty is always extra cost up front.
Wow, none of the official paperwork I have from Acura indicates that at all...I have what Birdonamission shared earlier. |
Originally Posted by Master47
(Post 16327754)
Wow, none of the official paperwork I have from Acura indicates that at all...I have what Birdonamission shared earlier. I paid ~$500 extra for Road Hazard coverage and this guy just walks in and gets waved in like it was no skin off anybody’s back. I don’t know if that service department is clueless or generous, handling out freebies (treats, not tricks) like that. |
