massive hesitation on acceleration after braking is driving me NUTS !!
#321
HATE the delay in acceleration
I bought a 2020 RDX Advance a few weeks ago and love it!... EXCEPT, when I brake and then punch the gas, there is a FULL 1.5 SECOND DELAY. Even in Sport+ there's way too much delay. It's soooo annoying. My 2016 Subaru Forester never had this issue. I hope Acura can fix it with an OTA update. Other than that, it's darn near perfect (besides needing ~70 more hp ![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Graphic-er (04-11-2020)
#322
Expanse me
1) ecu reset, search on this site for details
2) a hondata or ktuner tune, search on this site.
#1 is free and may really help a lot.
ie:
1. Depress the throttle pedal all the way in, with ignition/accessory off. Then, turn on the car to ignition mode. (Hit start twice without foot on brake)
2. Keep pedal down until the check engine light disappears. It took about 20 seconds.
3. Power down the car to off state. (Hit start button once)
4. Press brake pedal and start the car normally by pressing the engine-on button.
5. Procedure is completed,
Stormy21 (03-07-2020)
#323
Does Ktuner/Hondata really help with the hesitation delay? I’ve seen mixed responses from it being the same or making it slightly better?
I will try ecu reset you mentioned
Oil Stain (03-18-2020)
#325
Expanse me
ok,
just for a test, I removed the ktuner tune and burned the stock profile.
I found that the throttle delay is there for sure.
I did the ecu reset, and I found that upon light touch, it was responsive. but upon a punch of the throttle, the delay was definitely there.
So I cannot say that the ecu reset will solve the delay issue with stock.
With the previous Ktune Stage 2, I felt no delay at all, under any conditions.
I will be burning back to stage 2 in a week or so, so can test again then.
#326
ok,
#327
If delay can be fixed with software, why no update from Acura? Is it some government mandated feature to save gas or the software is protecting transmission from sudden torque?
#329
I'd guess emissions, fuel economy, AND protecting the transmission. If Acura did anything to compromise the first two after sale, the proverbial $hit would hit the fan.
#330
suggestion,
ie:
ie:
#332
Had this same thing with my 13 TL, I called it the rolling the stop sign fail made by Acura. Every time you slow it has to downshift from 3rd to 2nd at the time (6 Spd AT). Good to learn it exists in the RDX.
#333
I believe this problem began when "traditional" 4, 5, 6-speed transmissions were cast aside in favor of new, more efficient, logic controlled CVT/high gear count automatics. Instead of straightforward load, rpm, throttle position shift parameters, we now add decision-making and ratio options that are a magnitude beyond 6 speeds. Real-time PCM analysis manages every action in a modern transmission. That logic is hamstrung by prioritizing fuel efficiency, plus the extreme complexity of managing all those "gears" in real world driving.
The focus of this thread could easily be the CVT in my wife's Subaru. The hesitation from that demon spawn - when forward movement is a safety requirement - is without question the worst of its many faults. Hesitation when moving into faster moving traffic is not just annoying, it's dangerous. It just seems there are too many factors to be analyzed when a basic function of an automobile is requested by the driver. This problem is certainly not unique to this vehicle. But regardless of the technology, or brand or class of vehicle, hesitation is undoubtedly causing harm. Damn the fuel economy if people are being creamed while holding their foot to the floor.
#334
https://www.carcomplaints.com/news/2...-lawsuit.shtml
ACURA MDX AND RDX ACCELERATION PROBLEMS CAUSE LAWSUIT
Class action says Acura MDX and RDX vehicles hesitate, shift into NEUTRAL and stall.
#335
#336
Summer is Coming
Classic Acura.... 'nothing wrong here, nope, never seen that before, the car was designed to do that' Acura has given themselves a very bad reputation. Just fix your damn cars Acura! While you still have people willing to buy them.
#338
Anyway, I think the lawsuit touched on hesitation during acceleration AND "limp mode" situations. But it's pretty darn light on detail.
Maybe the lawyer(s) are sourcing it from the experts at AcuraZine?
![facepalm](https://acurazine.com/forums/images/smilies/facepalm.gif)
#340
no, not aware. Acura would not necessarily tell us if they changed/redesigned some electronics to address the issue. Especially if there is a lawsuit now, you won’t hear anything from them
#342
That's pretty much exactly what they did with 3rd-gen Pilot at mid-cycle, after similar drivability issues which AFAIK remain unresolved for previous model year vehicles. Like the one I traded for 2019 RDX, expecting a vastly improved driving experience.
#343
Hi all, new to the forum. Just got my first rdx last week (actually it's my first Acura). Love the car, but I definitely don't love this issue. I noticed it the other day when I was changing lanes. I slowed down quite a bit (but did not come to a full stop) while waiting for space to open up in the lane. I thought I had enough room to change, but also saw there was a car trying to speed up from behind in that lane (gotta love nyc). I went for it anyway, thought it was enough space and time. Jerk kept speeding up as I was mid lane change. I tried to accelerate in order to complete the change asap, but it took forever!! When the car finally accelerated, it basically just jerked forward. Luckily I made it in time, but this should not have happened in the first place. I was driving in comfort mode. Does this happen in sport mode as well? I remembered reading that it didn't, but not too sure
#344
There is no way to get rid of this problem other than to drive a little more gently. In other words, don't attempt any close call type maneuvers that require sudden acceleration. ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
I have literally skipped lane changes and done u-turns just because I know what kind of feeling arises within me especially if the person in the other lane isn't being accommodating. When trying to change lanes, I turn on my indicator. If the person in the other lane looks like they are going faster than me and doesn't slow down, I patiently wait for them to pass rather than trying to speed up and get in.
My driving fun karma for this lifetime ran out when my BMW E46 got old, but I had a lot of fun with that car.
#345
Long thread = much speculation/theory/opinion. Since most (all?) here are not Honda powertrain engineers, that's all we can do.
Just to pass the time in lockdown, do a Google search for "[Brand] acceleration hesitation". As you might expect, this not a problem unique to Honda/Acura. You will find significant discussions from across the industry. By scanning those threads, I found comments and speculation that could be a copy/paste from here. MBWorld thought it might be hill-holder function; AudiWorld thought it was ECU logic; Volvo Community thought is was a software issue, etc. Same stuff. I can also add my wife's Subaru to the discussion.
I'm also not a Honda engineer, so here's my speculation/theory/opinion: Newer, high gear count transmissions, under PCM control, have a LOT of things to consider at sudden power demands. Couple that with the mechanical requirements of dropping 3, 4, 5 gears, PLUS turbo lag in our case, and now we're surprised by a delay? I believe manufacturers HAVE to be aware of this and would eliminate it if possible. But the need to hit fuel economy numbers while making cars more powerful is a devil's bargain, and driveability is the sacrifice.
Carry on...
Carry on...
SpaceBot (04-30-2020)
#347
That is also the reason why I ask for an extended test drive.....take the car for an overnight and drive my daily (100 mile) commute. I don't go out of my way to beat on the car, but I drive it as I would everyday, and put it through how I might have to drive it.
I am sure test drive cars get plenty of non ideal break in mileage.
#349
Link here https://www.bmw.com/en/automotive-li...a-new-car.html
Looks like its updated recently too...
The right way to break in a new car
Many drivers wonder whether breaking in a new car is still necessary or if this practice has been superseded with the advances in technology. The answer? Yes and no...Doing an engine break-in used to be a standard procedure with new cars. And it’s still the case that you should avoid running the engine at high RPM for the first 1,300 miles. Experts recommend a maximum 3,500 rpm and 90 mph in diesel models and 4,500 rpm and 100 mph in gas models. This will give the engine and transmission sufficient time to adjust to each other. Once you’ve reached the 1,300-mile mark, you can gradually increase your speed and your engine’s RPM. In particular, avoid to put too much strain on a cold engine. However, that’s true not just when breaking in a new car but for the whole life cycle of your car. Likewise, never turn off an engine that has been running hard. Allow it to cool down by driving a few miles at a gentle pace.
#350
"During the first 600 miles (1,000 km) of operation, avoid sudden acceleration or full throttle operation so as not to damage the engine or powertrain.
Avoid hard braking for the first 200 miles (300 km). You should also follow this when the brake pads are replaced."
#351
This is from the RDX manual:
The throttle and transmission are more responsive in Sport IDS mode than in Comfort. And it seems to be best to really punch the accelerator when you need rapid acceleration, rather than gently depressing it. Otherwise it may pause, downshift, pause, downshift some more, OH CRAP! I recently found this to be especially true at high elevation, cuz you really need the turbo boost to make any power.
This may have something to do with the "adaptive" features of the transmission controller. If you drive like a granny, it will bias more toward smoothness of shifting rather than abruptness.
$0.02 based strictly upon seat-of-the-pants accelerometer. And occasional butt clenching!
![Yikes](https://acurazine.com/forums/images/smilies/yikes.gif)
#352
Carry on...
Carry on...
#353
Here is what it is. You are correct on the throttle lag. Manufacturer calls it torque on demand. But it is anything but. Hyundai, Acura, Kia, just to name a few all do it. If you hook up a scan tool to the vehicle and watch what happens its crazy. My wifes Santa Fe sport and I see Acura RDX do it. You will watch your throttle pedal percentage go up but nothing happens at the engine. Hyundai has a .6 to 1 sec delay before the engine does anything. With drive by wire they have screwed with the programming. Its way worse in the SUV for the same manufacturer than it is in the car of the same make with the same engine and transmission. They put it in the because these small 4 cylinder turbo can make peek torque as low as 1,600 rpm. So in a front wheel drive SUV it can be a lot easier to unload the inside front tire and get the wheel spinning. Taller heavier vehicle you can start to spin the tires. So I think for older folks or whoever they intended it for the vehicle will not let the engine come on at the same time with the pedal. I hate it.. Its bad between 5-20 mph. The Hyundai gets even worse if you are turning it senses the wheel and if you are turning on to a side street or a 90 degree turn its bad.
#354
Thats why the same engine and transmission thats in the Accord and in the RDX the car folks dont feel it that much or at all. Its not the transmission but programming to the engine and a big delay or very soft opening to the engine. You can watch it on a scan tool or with k-tuner. You can see what the pedal on the floor does and the engine is way behind.
#355
Pretty stupid if they are programming the same for FWD RDXs and SH-AWD equipped models.
markm929 (04-30-2020)
#356
Expanse me
samiam_68 (05-02-2020)
#359
Expanse me
I have always felt that the paddle gets the tranny’s attention so to say. It is just another input to the decision making of the ecu. You can also try that aforementioned throttle reset. Look for it earlier in this post.
#360
Get a car that's built for it, and you can whip it hard for a long long time. Get a rickety econobox and it will be whimpering at roadside in a month. ( Honda is a motor company first, and a car company second ).
But don't neglect basic maintenance! ( I'm looking at you, BMW! )
