First Service (Oil Change)
What are all your thoughts on when to get the first service (oil change, brakes, etc)?
I'm at 60% oil life & 4,500 km (2,800 miles) My pas cars had early 1st service, including engine oil, transmission fluid, brake service,.... |
Your vehicle will tell you when it wants an Oil Change, it will show a Service Light Indicator, and I would go with that. My understanding is that the System to determine this is pretty sophisticated and takes into account Mileage, Heat, RPMs etc.
When the indicator gets to 15%, make your plans. |
I change mine every 5K miles regardless.
Follow the car, no need to change oil earlier. |
Don't change oil ahead of time, specially the first one. Cars comes with special oil to help engine break-in so don't rush for oil change.
Originally Posted by Coolguy
(Post 16321427)
(Post 16321427)
(Post 16321469)
they did that long time back, they dont use break in oil anymore. Its just there is no reason to change it before computer tells you |
(Post 16321469)
Originally Posted by securityguy
(Post 16321327)
Originally Posted by kingofire
(Post 16324178)
Honda still says to not change the oil early because the grease lube has high amounts of moly which help reduce friction and help with break-in. Plus it is also a micro-polishing agent so if there are any sharp metal parts it will polish and dull them.
is this in the manual? |
Originally Posted by Stew4HD
(Post 16324215)
Why not at 3k? :tomato:
(Post 16324285)
so when my first gen rdx came factory filled with mobil1 you think they added their own additives to mobil1 for break in? is this in the manual? https://en.wikipedia.org/wiki/Molybdenum_disulfide |
(Post 16324422)
Very simple math in 5K increments and I have been doing it this way for as long as I can remember:thumbsup:
its a lot easier when you simply follow what MID tells you based on your driving patterns. If you drive city, the oil change will come sooner vs highway driving. |
My first gen turbo took synthetic oil every 8000km at $200/service. Does this turbo require the same oil? I really enjoy the $70 service every 15,000km with the 2nd gens.
Originally Posted by Colin G
(Post 16324579)
(Post 16324579)
and yes, 3rd gen also requires synthetic |
(Post 16324285)
so when my first gen rdx came factory filled with mobil1 you think they added their own additives to mobil1 for break in? is this in the manual? |
(Post 16324648)
Like the other poster said its the assembly lube that is rich in moly mixes with the factory filled oil that they don't want you to dump early. It is in the manual and they specifically say that the factory fill should not be changed out early.
I bet you dont even need ramps or jack to change oil on rdx |
(Post 16324603)
first of all, I dont know who did you service, but I get my mobil1 oil for $25 at wallmart and change oil myself. Dealer charges $60-70 for synthetic oil change. and yes, 3rd gen also requires synthetic |
Even when I did more on my cars than cabin and air filters and wipers, I never thought that what I would save by messing with an oil change was worth it. |
Originally Posted by Madd Dog
(Post 16325367)
Based on the way the oil life indicator is going with mileage, it looks like service would be due every 5000 miles. Yeah, they have all these fancy indicators, but I'm not sure how sophisticated they are. My BMWs had them and all it did was indicate service due approximately every 15000 miles (with the 2003). They lowered it to 10000 miles in the 2nd or 3rd year of the turbo engines.
Originally Posted by anoop
(Post 16325385)
I run mobil1 oil filter, and change filter every other oil change. |
IMO the OCI analysis is pretty good. My '14 Cadillac had it and it would definitely incorporate a number of variables in determining oil life remaining. Summers I could easily go 9,000 miles before it would indicate a change was needed, while during the winter when I was doing more short trips and less highway it would indicate service was due between 5-6,000 miles.
