E15
#41
go ahead and google, I am not going to be citing links
#42
[QUOTE=russianDude;16829336]the studies show that MPG drops when using e10 and even more with e15 fuels. Some reporting drops up to 20% with e85.
go ahead and google, I am not going to be citing links.
Here you go.
[/https://www.greencarcongress.com/2007/12/study-finds-cer.html
Here you go.
#43
Greenhouse my a**, here is official government site
https://fueleconomy.gov/feg/ethanol.shtml
Ethanol contains about one-third less energy than gasoline. So, vehicles will typically go 3% to 4% fewer miles per gallon on E10 and 4% to 5% fewer on E15 than on 100% gasoline
#44
Back when there was a blender tax credit most companies did a similar thing. Charging more for the ethanol blend than regular even though it was cheaper for them but it was higher octane so they charged more. In the midwest we have a convenience store chain called Casey’s, they were somewhat ethical and charged the same for 89 and 87. That tax credit went away with the reformulated fuel standard many years ago. There are no subsidies anymore the price is based on supply and demand.
#45
Higher ethanol blends are great for making power (if tuned for it), but simply using a fuel with increased ethanol at the same price with the same octane rating as other fuels is a waste.
Also, ethanol is hygroscopic so the more you have in your fuel blend, the more likely you are to have moisture build-up if the vehicle sits for longer periods.
If fueling stations weren't so sparse, I'd definitely do E85. With a tune, you'd be making Type-S power ... and the hit in gas mileage would be a wash seeing as the price of E85 is much lower. With all comparisons being equal, right now, E85 would make far more power than even 93 while still being more economical than even 87.
