Does the PMC models need a break in?
Old Sep 22, 2021 | 07:09 PM
khuang94's Avatar
Question Does the PMC models need a break in?
Hey All,
I am trying to get a PMC model for the '22 and was wondering does the PMC model's engines come broken in like the NSX when you get it brand new? Would love to see the manual of those that own a PMC as well
Thanks!
Old Sep 23, 2021 | 09:12 AM
NvmMyY2's Avatar
when I bought my PMC Rdx I asked them about that and the dealer told me PMC facility does break in the engines in like the nsx, but just in case I took it easy with mine.
Old Sep 23, 2021 | 10:00 AM
dopeboy1's Avatar
The inconvenient truth
Isn't it the exact same engine and drivetrain as every 3g RDX?
So the break in would be no different than any 3g RDX which makes it sound strange that the pmc facility would break it in for you....
Old Sep 23, 2021 | 10:47 AM
I think you're spot on the money.
every publication, every article states the same engine is used, meaning no one at the PM Center hand builds the engine.
the PMC edition does get dyno-ran before delivery tho. (this tells us a lot!!!! this tells us that they did a high RPM run, meaning a gentle break-in isnt necessary.)
Old Sep 25, 2021 | 11:07 PM
hans471's Avatar
In my years working for an OEM I spent a lot of time in production plants. Every one of them at the end of the assembly line plugged them into their computer and then ran the finished car on a short dyno run to confirm engine, transmission, drive train and brake operation. It was a quick run up to insure everything worked as it should but was not intended to be a "break in" for the engine. BTW: If there were any mechanic problems or body/interior imperfections, etc. they were pulled off the line and sent to a repair line for correcting the deficiencies before being shipped out.
Old Sep 26, 2021 | 04:06 PM
khuang94's Avatar
Thanks everyone for their responses! If i can get one, ill do a light break in like most people have said and take it easy for the first 500 miles.
Old Sep 28, 2021 | 03:23 PM
Baldeagle's Avatar
Quick read about Porsche’s 2,000 mile break in recommendation and dyno testing at their factory. Take it for what you want….
https://pcaucr.org/12409/
As the story goes… when the test was completed during a factory visit, a Porsche engineer came over to review the results. I couldn’t resist asking the question that I had been searching to find an answer to for all these years. I asked “why does Porsche feel it is safe for a new engine to run at nearly full throttle in the factory, while the customer must keep the engine speed to no more than 4,000 RPM for a 2,000 mile (3,200 km) break-in period?” I thought that was a logical question and if I do say so myself-well stated!
The engineer replied, “Herr Koop, you do not understand (that I already knew). When we do our engine test, the metals inside the engine never reach the temperatures they would when driven on the street since the test session is fairly short. In other words, the bearings, pistons and cylinders never get a chance to thermally expand to their maximum. Therefore, there is little wear on the moving components. But when you drive a car on the street, the engine parts expand considerably more because of the heat being generated from the engine running for an extended period of time. No matter how tight the tolerances are, there is always a slight amount of expansion in the material. The moving parts can wear quickly if exposed to excessive heat and not always in a uniform way. We also constantly vary the speed and allow the engine to run at both high and low RPM’s”.”
Old Sep 28, 2021 | 11:10 PM
hans471's Avatar
The Porsche engineer explained it well. The engine is "cold". Of course cold in this context means room temperature, not -20 F, so oil would flow properly so lubrication was not an issue. ( I have fixed more than one engine with thick, straight weight oil, that was started in twenty degrees below zero weather and then held wide open....no oil flow and the bearings welded to the crank and spun in the block. I love that 0W-20 oil in cold weather!).
Parts do expand a lot when heated. A cold piston isn't even round nor are its sides parallel. Its designed to expand to full size, be round and be straight on the sides, when the engine is up to normal operating temperatures.Same for piston rings. We have to allow quite a gap on their ends when cold (about .004" gap for each inch of bore as a general rule). When the engine warms up they expand and the ends nearly touch.
Old Sep 29, 2021 | 01:01 PM
Baldeagle's Avatar
Ideally, you want each heat/expansion cycle to be just a little bit more than the last. That way you gradually form fit all the metal-on-metal moving parts. Also, it’s important to remember that piston rings spin around the piston much like a wedding ring can spin around your finger. That spinning process happens more readily as the rpm (cylinder pressure) change. Ideally, you want all 360° of the piston ring to form fit to all 360° of the cylinder wall. That takes time. At constant rpm, the piston rings don’t spin much. That is one of the main reasons manufacturers recommend you avoid highway driving early in the break-in process. Fortunately the break-in process is much less important now than it was decades ago. But if done prudently, breaking in an engine can still eek-out marginally better efficiency. It certainly can’t hurt anything.
Old Sep 30, 2021 | 01:56 PM
Legend2TL's Avatar
AZ Community Team
The main reason to avoid constant RPM is developing a piston ring ridge on the cylinder bore when the piston starts/stops at the top of it's stroke. Varying the RPM causes slight differences as to how high the ring will go in the cylinder bore. Constant RPM promotes a ridge which can potentially break the upper ring
https://en.wikipedia.org/wiki/Break-...hanical_run-in)
Old Sep 30, 2021 | 05:14 PM
khuang94's Avatar
This was a very interesting read! I know others have posted that in Acura's manual they say that the break in is 600 miles. Thus I will check the manual as well if i am able to get a pmc and break it in
Old Sep 30, 2021 | 05:58 PM
Madd Dog's Avatar
Too, brakes and tires need to break in.
acshirains
ILX
Jul 16, 2012 12:35 PM
Eggplant-EX
Technology
Nov 24, 2005 02:29 PM
njtls
Oct 20, 2005 05:09 AM
gavriil
Jul 22, 2005 01:19 PM
Mr Zipps
Nov 30, 2003 08:40 PM
