Climate Control Heat
I live in a cold New England climate. I’ve always used the “auto” feature of climate control on all previous vehicles including my recently traded 2016 RDX. Generally when it’s cold some warm air comes out of the dash vents while the majority of heat comes from the floor vents. I always liked having that warm air come out of the dash vents during warm up. When my 2019 rdx is on auto in 20/30 degree weather nothing comes out of the dash, only the floor. I know I can take it off auto and use dash/floor, but that defeats the purpose of climate control. Is there a problem with my auto climate control or is that just how it is?
I notice that the "auto" mode doesn't keep the seats warm enough for me in this NY cold.
Originally Posted by beancount1
(Post 16345653)
My 2006 Accord was the first vehicle I owned that blew warm out of the side A/C vents, which I liked. I assumed Honda did it that way because there were no dedicated vents for defogging the side windows.
I noticed my RDX doesn't blow warm out the side A/C vents, but I also noticed that it has dedicated vents on the dash that blow warm air on the side windows. I do find it odd that the A/C vents on the rear of the center console blow warm air. None of the other Hondas I'e owned with rear A/C vents have ever done that. It's becomes an issue when it's cool outside and the system has reached setpoint at which time the rear floor vents will blow warm air and the rear A/C vents will blow cold air. |
My wife was complaining that cold air was coming from the dash in auto mode even though the climate control was set to a higher temp than what was in the cabin. I did not think was possible, but after hearing a few of the complaints in this thread, it now seems to be a "feature" of how this vehicle deals with air flow.
Does anyone on the forum have a definitive technical definition of how air flow is supposed to work in the auto mode? |
Originally Posted by Buit15
(Post 16345762)
My wife was complaining that cold air was coming from the dash in auto mode even though the climate control was set to a higher temp than what was in the cabin....
(Post 16345762)
Does anyone on the forum have a definitive technical definition of how air flow is supposed to work in the auto mode? The climate control in a new '99 Regal I bought worked very well except on sunny days when it was in the 50's°F after the cabin temperature approached setpoint. The fan speed slowed way down and the system would blow cold air out the defroster vents and warm air on the floor so my feet stayed warm, but my fingers and nose froze. During this specific condition, I'd override the system to discharge air only on the floor. |
(Post 16345762)
It seems Acura was not satisfied at all with the previous generation, and instead of building upon its positive features, it set about to overhaul just about everything. What we have is basically a new model with all the inherent flaws of a generation 1 release. I should have held my ground firmer and talked the wife into the RX350 Lexus we test drove just prior to going from a gen 2 to a gen 3 RDX. She wanted a bit of a more "road feel" that the Acura gave (Lexus definitely was in Comfort mode full time, but now she is making comments about the larger size just being a bit too large.
I have made about 7 posts so far and I cant find a positive thing to say about this RDX. My posting will end soon as I do not like being a full time forum complainer. |
(Post 16345931)
I was a Guinea pig in 2005 with the Honda Ridgeline. That truck had a forum with hundreds of members who all were in the same boat and worked together to force answers out of Honda. Dozens of recalls and redesigns followed. This truck needs a bit of that aggression from the owner community.
(Post 16345762)
...Does anyone on the forum have a definitive technical definition of how air flow is supposed to work in the auto mode?
... Technology, A-Spec and Advance packages add a GPS-link for still better control of individual settings. For the comfort of rear seat passengers, adjustable dual vents are provided in the rear of the center console. With its position-sensing ability, the GPS navigation system (RDX with Technology Package and higher) contributes to overall passenger comfort with a 3D solar sensing feature. Based on continuously updated vehicle position information, the navigation system determines the position of the sun relative to the driver and front passenger. Combining this information with input from a solar sensor located on top of the instrument panel, the climate control system automatically adjusts cooling/heating and airflow from side to side as needed to compensate for asymmetrical solar heating... |
Good find and interesting information. Thanks.
Yeah? If the car is so smart, why does it turn on the seat heaters if nobody is sitting in the passenger seat? |
Some of the smartest people have zero common sense, just like this truck.
Originally Posted by Madd Dog
(Post 16346482)
Yeah? If the car is so smart, why does it turn on the seat heaters if nobody is sitting in the passenger seat? Seriously, I think that's kind of dumb as well. |
Well, maybe they had oughta moved some of the dash lights. The yellow lights up to say the airbag won’t go off ‘cause there ain’t nobody sitting in the passenger seat, and right next to it the little LED lights glow red as if to say, what the heck, if I’m wrong about that, at least I’m heating up her butt. |
Originally Posted by MI-RDX
(Post 16346475)
No technical specifications but found this in the RDX press release (whether or not it was implemented this way is a different issue):
2019 Acura RDX Press Kit - Honda News |
(Post 16346628)
Then if it's a cloudy day (no solar effect), 18 degrees and the car has reached heating temperature, warm air should come out of the dash vents based on this specification.
(Post 16346640)
It doesn’t really say that last part. |
(Post 16346628)
Then if it's a cloudy day (no solar effect),...
I have a southern facing house and the thermostat happens to be in a room with southern exposure. On a sunny day in the winter it's not at all unusual to have to raise the temperature setting by as much as 3 or 4 degrees to get the furnace to kick on to warm the rest of the house. On cloudy days just a couple of degrees will suffice. (And, yes, the room with the thermostat is very warm as a result, even with the furnace vents closed.) I know it's solar effect because after sundown I have to return the setting to normal else it gets way to warm. |
(Post 16346482)
(Post 16346475)
(Post 16346493)
So when you remote start both seats will be warm in case you have a passenger? :dunno:
