Can you disable the parking brake to rotate a wheel when jacked off the ground?
I had a small nuisance leak in the right rear tire (about 3 psi in a month) and since there is a ton of new home construction around me, I suspected a nail. I jacked up that wheel and started to spin the tire by hand. Nope…. Then I remembered the “intelligent” electric parking brake. This is my first vehicle with that unfortunate feature. I couldn’t figure out any way to disable it so I could check the tread visually. So I dismounted the wheel and found a nail in the center tread. I got it repaired at the tire store.
Sure, with it on the ground, I could use a mirror and flashlight, then start the engine and drive it a few feet and repeat the process... But there must be a way for a tech to spin the wheels when doing brake and drivetrain inspections up in the air. Does the car “know” it is off the ground and turn it off?😳Any comments? Thanks.
John Davies
Spokane WA
John Davies
Spokane WA
leomio2.0 (08-05-2022)
John E Davies (08-05-2022)
EagleEye
07-23-2013 02:18 PM
