Aspec compressor mod
I recently installed the spare tire to my aspec so I had an extra compressor pump I no longer really needed except for the occasional car tire fill and bike tire fill up. But I hate the end that comes with the compressor as when you take it off you lose a ton of the air. I decided to remove the factory end and replace it with a 1/4 barb to 1/4 npt compressor fitting. You can pick one up for about $4 at Home Depot. Honestly the hose clamp isn’t probably even needed, as before installing it I tried as hard as I could to pull out the new fitting and it’s permanent.
now I can fill up my car and bike tires without losing any air, it’s quick and easy, and if I want I could put any 1/4 inch attachment on I want, longer hose, different air chuck, etc. easy cool mod that makes the compressor much more useable, and it’s cheap
the default factory end
