All Windows Down?
All Windows Down?
While messing with the key FOB, I unintentionally put all the windows down and opened the sun roof, a feature to air out a hot car. Now I can not figure out what I pushed to do it?
If you unlock the car with the key fob and then click unlock a second time and hold the button down, everything opens
Billy
Billy
The feature is described in your Owner's Manual. http://techinfo.honda.com/rjanisis/p...BTJB1818OM.PDF
Pg. 177
Pg. 177
You can also roll all your windows back up. You need to use your physical key, put in the driver lock. Turn to lock it and hold it. It will roll up all your windows. I haven't found a way to do it with the key fob yet tho.
How about the auto-up(one touch) function? Some cars have a master auto up, most cars have auto up individually. Most of all, how does the RDX handle auto up after the car is shut off. Both of my cars, have auto up after shut off for a period of time and/or until the drivers door is opened. Over on the Audi forum, people were complaining that the auto up was disabled when the engine was shut off. When I tested the 2018 X3, I turned the car off and mistakenly opened the drivers door, and the auto up still worked, which I think is the best way. I'm always pulling into my garage, turning the car off and realizing the windows are still down.
I am pretty sure this hasn't changed since my car was made (2010). I believe it designed this way as a safety concern. By requiring to roll all windows up only with the key, you have to be physically at the car. This way, hopefully you can confirm there are no unintended fingers on the windows!
preludeshfan
08-20-2001 09:40 PM
