2022 Acura RDX Technical Service Bulletins
Forum Contributor
Received 1,392 Likes
2022 Acura RDX Technical Service Bulletins:
TSB 21-033 - 2022 RDX: TQI Information
Applies To: 2022 RDX (2WD, AWD) - Base, Technology Package, A-Spec Package, Advance Package, Advance Package with A-Spec, PMC Edition
http://www.urvi.net/forumfiles/SB/B21-033.PDF
http://techinfo.honda.com/rjanisis/p...nu/B21-033.PDF
TSB 21-034 - 2022 RDX: TQI of the Navigation System
Applies To: 2022 RDX - ALL With Navigation
http://www.urvi.net/forumfiles/SB/B21-034.PDF
http://techinfo.honda.com/rjanisis/p...nu/B21-034.PDF
TSB 19-053 - RDX Front and/or Rear Brakes Squeal When Applied at Low Speeds
Applies To: 2019-23 RDX - ALL - ALL
2024 RDX - ALL - From VIN 5J8TC2...RL000001 thru 5J8TC2...RL000060
http://www.urvi.net/forumfiles/SB/B19-053.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-053.PDF
TSB 23-004 - Panoramic Glass Roof has a Pop Noise
http://www.urvi.net/forumfiles/SB/B23-004.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-004.PDF
TSB 23-010 - Software Update DTC P0300, P0301, P0302, P0303, P0304, or P0172
Applies To: 2019-2023 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B23-010.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-010.PDF
TSB 23-013 - RDX/MDX Sunroof and Sunshade Function Loss
http://www.urvi.net/forumfiles/SB/B23-013.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-013.PDF
TSB 24-004 - Popping/Crackling from the Speakers; Display Blank
This bulletin has been replaced by 24-045 Warranty Extension: 2022–24 RDX Popping/Crackling from the Speakers; Display Blank, dated July 30, 2024. This service bulletin will expire August 29, 2024.
http://www.urvi.net/forumfiles/SB/B24-004.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-004.PDF
TSB 24-015 - Safety Recall: 2020–22 RDX Seat Weight Sensor (DTC U3000-49)
Applies To: 2020-22 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B24-015.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-015.PDF
TSB 24-021 - Safety Recall: 2020–22 Multi-Model Seat Weight Sensor Stop Sale
http://www.urvi.net/forumfiles/SB/B24-021.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-021.PDF
TSB 24-023 - Safety Recall: 2020–22 Multi-Model Seat Weight Sensor Campaign Notice
Replaces the campaign notice dated February 27th.
NOTE: This notice is to keep all dealers with the most up-to-date information for this safety recall. Dealers will be notified when this notice is revised.
http://www.urvi.net/forumfiles/SB/B24-023.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-023.PDF
TSB 24-045 - Warranty Extension: 2022–24 RDX Popping/Crackling from the Speakers; Display Blank
Applies To: 2022-24 RDX - ALL - Check iN for VIN eligibility
http://www.urvi.net/forumfiles/SB/B24-045.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-045.PDF
Last edited by EE4Life; 07-30-2024 at 11:50 AM. Reason: TSB 24-004 was revised. Added TSB 24-045
