2020 RDX A-Spec bluetooth issue
Has anyone else noticed that when they get into their car, the infotainment system automatically starts steaming music from their phone via bluetooth? I have an iphone XS Max and have had this happen several times. I need to use the APP button on the steering wheel, choose Sirius XM and switch it from streaming to satellite.
Any ideas why this is happening and how to disable it? I am not plugged in via USB cable at all.
Also, probably 50% of the time I am in the car, using the left roller wheel on the steering wheel to change favorites doesn't work. Says system error. I have to power off the system using the steering wheel power button and then turn on which fixes it. Thought ver 1.1.1.4 would fix this but it didn't.
I haven't experienced (or perhaps noticed) the bluetooth overriding last source issue, but I have experienced the steering wheel thing 3-4 times. You may have noticed, but if the steering wheel favorites control isn't working, it's because the favorites have failed to populate (you can see this on the Sat radio screen itself - the list of favs isn't there). One thing I have noticed is that if I navigate to the Sat radio screen (or stay on it) and wait for the list to populate, I won't have the issue. For some reason, if the button is hit prior to loading, I need to restart the infotainment system to get that list to populate. I have not had the issue since the update, but it happens so infrequently to me that doesn't really mean anything.
Cant switch favorites on my steering wheel control for my SiriusXM.
Received 1,026 Likes
I have that also on my Accord if I had been streaming BT when I turned it off, even if I shut down the music app on my phone. I think that it is something with the way the phone (Apple for me) handles the music. If music was streaming, then it starts streaming again.
Found this: https://www.imore.com/how-stop-music...aying-your-car
What I recall working for me on the Accord was to switch to FM before I turned the car off, so that BT music as a source was not active.
How to stop your iPhone from autoplaying music in the car
Does your music library inundate you with music, podcasts, or audiobooks when you get into your car? Here's the fix.Last edited by Madd Dog; 10-02-2019 at 10:11 AM.
Has anyone else noticed that when they get into their car, the infotainment system automatically starts steaming music from their phone via bluetooth? I have an iphone XS Max and have had this happen several times. I need to use the APP button on the steering wheel, choose Sirius XM and switch it from streaming to satellite..
The first situation is certainly abnormal. The second situation is normal for me with my Android phone.
My RDX always starts up with the last audio source I was listening to when I last shut it down.
If I had been listening to FM radio, then my RDX will automatically start playing the last FM station I had been listening to.
I frequently listen to Podcasts when I drive. Each time I start the car, the podcast will resume from where it was when I last shut the car down. I consider this the perfect way to operate. If I have Bluetooth selected as the audio source, then that is want I want to hear.
If you last played a podcast on your Iphone, would the car startup playing the Podcast or would it still stream music?. I would bet that it would play the last thing you were listening to.
JAB00 (10-05-2019)
This happens to me as well and I have an android phone. Not a big deal for me since I stream spotify through bluetooth. Do you typically stream music through your phone or do you use it just for calling?
I've narrowed down the problem some more. It seems when I use the speech-to-text function to send a text message, as soon as I am done speaking and the text sends, the infotainment system starts to Bluetooth stream music from my iphone. Somehow using speech-to-text on my iphone causes the bluetooth the start streaming music.
I suppose I could turn off the bluetooth function on my phone but then the handfree calling won't work
Any thoughts?
Any thoughts?
Any thoughts?
Any thoughts?
markewallace
01-07-2020 01:54 PM
SamCarLegion
3G MDX (2014-2020)
09-19-2019 01:55 PM
