2020 RDX air filter installation
When removing old HONDA filter arrow were pointing down. On the plastic cover arrow indicates up. So what's the proper air flow: top to bottom or bottom to top?
Most of youtube videos indicates top to bottom should be right installation even thought plastic cover says something else.
Do you mean the cabin air filter?
Unless otherwise stated, the filter arrow should be pointing down. The arrows on the cover indicate which side is up for the cover so that it will be installed correctly.
GW208 (01-27-2023)
