2020 Acura RDX Technical Service Bulletins
Forum Contributor
Received 1,392 Likes
2020 Acura RDX Technical Service Bulletins:
TSB 19-023 - 2020 RDX: TQI Information
Applies To: 2020 RDX (2WD, AWD) - Base, Technology Package, A-Spec Package, Advance Package
http://www.urvi.net/forumfiles/SB/B19-023.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-023.PDF
TSB 19-024 - 2020 RDX: TQI of the Navigation System
Applies To: 2020 RDX - ALL With Navigation
http://www.urvi.net/forumfiles/SB/B19-024.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-024.PDF
TSB 19-014 - Whistling from Center Dash Area
Applies To: 2019 RDX - 2WD - ALL
2019 RDX - AWD - ALL
2020 RDX - AWD - From VIN 5J8TC2...LL000001 thru 5J8TC2...LL000240
http://www.urvi.net/forumfiles/SB/B19-014.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-014.PDF
TSB 19-050 - Product Update: Display Audio Clock Off by 1 Hour
Applies To: 2019-20 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-050.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-050.PDF
TSB 19-053 - RDX Front and/or Rear Brakes Squeal When Applied at Low Speeds
Applies To: 2019-23 RDX - ALL - ALL
2024 RDX - ALL - From VIN 5J8TC2...RL000001 thru 5J8TC2...RL000060
http://www.urvi.net/forumfiles/SB/B19-053.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-053.PDF
TSB 19-062 - Service Manual Update: MOST Bus Network Failure Log
Applies To: 2019-20 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B19-062.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-062.PDF
TSB 19-068 - MIL Comes On with DTC P0460
Applies To: 2020 RDX - 2WD - From VIN 5J8TC1...LL000001 thru 5J8TC1...LL008164
2020 RDX - SH-AWD - From VIN 5J8TC2...LL000001 thru 5J8TC2...LL018506
http://www.urvi.net/forumfiles/SB/B19-068.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-068.PDF
TSB 20-004 - Ticking/Clicking from Front Passenger Seat Bottom When Turning
Applies To: 2019 RDX - ALL - ALL
2020 RDX - 2WD Base - From VIN 5J8TC1H3.LL000001 thru 5J8TC1H3.LL005925
2020 RDX - 2WD Tech - From VIN 5J8TC1H5.LL000001 thru 5J8TC1H5.LL005937
2020 RDX - 2WD A-Spec - From VIN 5J8TC1H6.LL000001 thru 5J8TC1H6.LL005938
2020 RDX - 2WD Advance - From VIN 5J8TC1H7.LL000001 thru 5J8TC1H7.LL005659
2020 RDX - AWD Base - From VIN 5J8TC2H3.LL000001 thru 5J8TC2H3.LL009843
2020 RDX - AWD Tech - From VIN 5J8TC2H5.LL000001 thru 5J8TC2H5.LL010352
2020 RDX - AWD A-Spec - From VIN 5J8TC2H6.LL000001 thru 5J8TC2H6.LL010172
2020 RDX - AWD Advance - From VIN 5J8TC2H7.LL000001 thru 5J8TC2H7.LL010232
http://www.urvi.net/forumfiles/SB/B20-004.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-004.PDF
TSB 20-025 - Squeaking or Creaking from Front of Vehicle Going over Bumps
2020 RDX - 2WD - From VIN 5J8TC1...LL000001 thru 5J8TC1...LL017952
2020 RDX - AWD - From VIN 5J8TC2...LL000001 thru 5J8TC2...LL035514
http://www.urvi.net/forumfiles/SB/B20-025.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-025.PDF
TSB 20-032 - AWD Indicator Comes On with DTC C1843-62 or C1844-62
Applies To: 2019-20 RDX - All with AWD - ALL
2021 RDX - All with AWD - From VIN 5J8TC2...ML000001 to 5J8TC2...ML011452
http://www.urvi.net/forumfiles/SB/B20-032.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-032.PDF
TSB 20-046 - Head Up Display Image Is Blurry or Distorted
Applies To: 2019-20 RDX - Advance - ALL
http://www.urvi.net/forumfiles/SB/B20-046.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-046.PDF
TSB 20-053 - MIL is Flashing with Loss of Power
2021 RDX - 2WD - From VIN 5J8TC1...ML000001 thru 5J8TC1...ML012182
2021 RDX - SH-AWD - From VIN 5J8TC2...ML000001 thru 5J8TC2...ML024481
2021 RDX - SH-AWD (PMC) - From VIN 5J8TC2...MY000001 thru 5J8TC2...MY000192
http://www.urvi.net/forumfiles/SB/B20-053.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-053.PDF
http://techinfo.honda.com/rjanisis/p...-053 Rev03.PDF (Link works, but is wrong) Version 3
TSB 21-009 - Warranty Extension: 2019-20 RDX MOST Bus Network Connectors
http://www.urvi.net/forumfiles/SB/B21-009.PDF
http://techinfo.honda.com/rjanisis/p...nu/B21-009.PDF
TSB 21-014 - Safety Recall: 2019-20 RDX Fuel Pump Motor
http://www.urvi.net/forumfiles/SB/B21-014.PDF
http://techinfo.honda.com/rjanisis/p...nu/B21-014.PDF
TSB 21-021 - MIL Comes On With DTC P0236
2021 RDX - 2WD - From VIN 5J8TC1...ML000001 thru 5J8TC1...ML011759
2021 RDX - SH-AWD - From VIN 5J8TC2...ML000001 thru 5J8TC2...ML023920
2021 RDX - SH-AWD (PMC) - From VIN 5J8TC2...MY000001 thru 5J8TC2...MY000174
http://www.urvi.net/forumfiles/SB/B21-021.PDF
http://techinfo.honda.com/rjanisis/p...nu/B21-021.PDF
TSB 21-027 - ACC Warning Lamp Is On With DTC P2583-76 In Low/Near Freezing Ambient Temperatures
2021 RDX - 2WD - From VIN 5J8TC1...ML000001 thru 5J8TC1...ML010642
2021 RDX - SH-AWD - From VIN 5J8TC2...ML000001 thru 5J8TC2...ML021431
http://www.urvi.net/forumfiles/SB/B21-027.PDF
http://techinfo.honda.com/rjanisis/p...nu/B21-027.PDF
TSB 21-028 - MIL Comes On With DTC P061B
Applies To: 2019-21 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B21-028.PDF
http://techinfo.honda.com/rjanisis/p...nu/B21-028.PDF
http://techinfo.honda.com/rjanisis/p...1-028 Ver4.PDF (Link works, but is wrong) Version 4
TSB 21-029 - Product Improvement Campaign: 3G TCU VoLTE OTA Update
http://www.urvi.net/forumfiles/SB/B21-029.PDF
http://techinfo.honda.com/rjanisis/p...nu/B21-029.PDF
TSB 22-014 - Rear Windshield Glass Shattering
2020 RDX - 2WD - From VIN 5J8TC1H...L000001 Thru 5J8TC1H...L020269
2020 RDX - AWD - From VIN 5J8TC2H..LL000001 Thru 5J8TC2H..LL039430
http://www.urvi.net/forumfiles/SB/B22-014.PDF
http://techinfo.honda.com/rjanisis/p...nu/B22-014.PDF
TSB 22-016 - Audio Sound Stops and "No Audio Connection" Message Appears
http://www.urvi.net/forumfiles/SB/B22-016.PDF
http://techinfo.honda.com/rjanisis/p...nu/B22-016.PDF
TSB 22-017 - RDX PGM-FI Idle Stop Software Update
Applies To: 2020-21 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B22-017.PDF
http://techinfo.honda.com/rjanisis/p...nu/B22-017.PDF
TSB 23-004 - Panoramic Glass Roof has a Pop Noise
http://www.urvi.net/forumfiles/SB/B23-004.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-004.PDF
TSB 23-005 - Safety Recall: 2019–20 RDX Front Seat Belt Buckle Repair
http://www.urvi.net/forumfiles/SB/B23-005.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-005.PDF
TSB 23-010 - Software Update DTC P0300, P0301, P0302, P0303, P0304, or P0172
Applies To: 2019-2023 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B23-010.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-010.PDF
TSB 23-013 - RDX/MDX Sunroof and Sunshade Function Loss
http://www.urvi.net/forumfiles/SB/B23-013.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-013.PDF
TSB 23-025 - Warranty Extension: Popping/Crackling from the Speakers; Display Blank
Applies To: 2019-21 RDX - ALL - Check iN for VIN eligibility
http://www.urvi.net/forumfiles/SB/B23-025.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-025.PDF
TSB 24-005 - Safety Recall: 2019–20 RDX Fuel Pump Motor
http://www.urvi.net/forumfiles/SB/B24-005.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-005.PDF
TSB 24-015 - Safety Recall: 2020–22 RDX Seat Weight Sensor (DTC U3000-49)
Applies To: 2020-22 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B24-015.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-015.PDF
TSB 24-021 - Safety Recall: 2020–22 Multi-Model Seat Weight Sensor Stop Sale
http://www.urvi.net/forumfiles/SB/B24-021.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-021.PDF
TSB 24-023 - Safety Recall: 2020–22 Multi-Model Seat Weight Sensor Campaign Notice
Replaces the campaign notice dated February 27th.
NOTE: This notice is to keep all dealers with the most up-to-date information for this safety recall. Dealers will be notified when this notice is revised.
http://www.urvi.net/forumfiles/SB/B24-023.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-023.PDF
