A 1 6 7 Service Cost
So my RDX 2019 at 12,500 miles, just popped up service reminder for A 1 6 7 service.
I am planning to get service done during next week and would like to know how much should I anticipate.
//Thanks
//Thanks
You can buy only individual services listed above to save money, do not go for so called “package”.
dealer prices are different, but expect to pay around $300 for rear diff and brake fluid, plus whatever they charge for oil change and another $20-30 for tire rotation.
I did oil change, and rear diff myself, super easy. Something to consider. For Brake fluid will go to dealer,
dont want to mess with brakes.
I guess it will all depend where you are located, but in Chicago area you can do these services under $400 at most dealers as they typicaly offer service coupons - oil change $50, tire rotation - $20, each fuild flush $130-160.
Stay Out Of the Left Lane
Received 1,241 Likes
You can also save some $$ by going to your local Honda dealer vs. your Acura dealer.
The following 2 users liked this post by russianDude:
catbert430 (12-17-2021),
NBPDC505 (12-17-2021)
Haven't taken the time to research the part numbers.
Acura rear diff for SH-AWD fluid might be the only unique fluid to Acura since SH-AWD is only built for Acura platform. Honda uses AWD without super-handling technology(SH), so these are different systems. I would imagine 2nd gen RDX would have same system as Honda, as it was not SH-AWD
I just had my rear diff fluid changed at Acura...whats listed is
Fluid $38.61
washer 20mm $1.44
washer 18MM $4.32
What I assume is labor...$65.58
also, the transfer assy fluid
Fluid $24.47
washer 20mm $1.44
and assume labor $82.80
And engine air filter $42.95 with labor
4 wheel align $99.95...labor
rear wiper $20.00 with labor
my last oil change was $60, my last brake fluid change was $130. I don't think I have ever paid for a tire rotate as they were just done for free (Discount tire)
This was on top of warranty replacement of new battery, new brakes and rotors, replace shift buttons that were 'peeling' off
Fluid $38.61
washer 20mm $1.44
washer 18MM $4.32
Fluid $24.47
washer 20mm $1.44
I am not convinced these are the same fluids until we see official documentation from Honda. The mechanics and parts department managers is not a great source of info.
Was thinking the same thing. If a tech and the parts department say it's the same - what is an owner to do?
I can't speak about the fluid itself but the AWD system in the Pilot/Passport is mechanically identical to SH-AWD. The only difference is the tuning - SH-AWD has more aggressive rear overdrive so you get more torque vectoring. There's no evidence beyond labelling on the fluid (the additional 'A' appears to be to just separate out the part for Acura) to say the Acura version is different than the Honda version and I don't there is a difference since the systems they are used in are identical. I don't think Honda would say it out loud so best bet is for those who visit joint Honda/Acura service shops to get answers on this.
Had this done in Canada (Vancouver) earlier this year and it ran me ~$450 at my Acura dealer.
With prior fluids, they are called same name, like DW1, one had Honda bottle and another had Acura bottle, which makes it obvious to be the same. The rear differential for Acura has a different name. Obviously Acura SH-AWD has many similarities with Honda AWD, its the same company, but supper handling (SH) feature is excuse to Acura platform. The two might be same fluids, but I did not see anything from Honda/Acura documents. I got Acura one online for $7-8 per qt, why do I need to look for Honda, is it $1 cheaper?
Received 1,026 Likes
Very different from SH-AWD.
Vince D (12-26-2021)
https://driving.ca/features/feature-...ra-awd-systems
More or less since 2016 the latest release of the SH-AWD diff made it pretty much the same as what the Focus RS does and the same system was implemented in the Pilot/Passport/Ridgeline during the next relevant update.
Ih8honda (12-29-2021)
