A very simple fix for the gas fill door
Old 07-20-2018, 02:06 PM
wallyo's Avatar
As many have noticed, the rear end of the gas filler door sticks up above the body panel, and that misalignment has always bothered me. After months of thinking about it, the solution suddenly popped into my head. I put a small vinyl cap on the bolt (the bolt that retracts to open the door), and it is just thick enough to make the door perfectly level with the surrounding panel. I have a box of such vinyl "caps," (which are often used to protect the open end of bolts and screws) and the one I used has an inside diameter of 0.2435 inches (or 6.20 mm). It slides firmly onto the bolt with a little pushing, and you do want it snug. When you push it on, you'll feel the spring that locks the latch pushing against you, which is fine. Just keep pushing. In the image with the cap installed, you'll see that I applied a bit of grease to prevent wear and allow it to slide easily into the female section of the latch. I'm not sure the grease is really needed with a smooth vinyl cap, but it won't hurt. It took one minute to "install" this very appreciated fix.
You may have to experiment a bit to find a cap that is both snug on the bolt and small enough in the outside diameter to fit in the female part of the latch, but in my parts box of such things, I found several different ones that worked. You can find such caps on Amazon, for example here:
https://www.amazon.com/10-Pack-Flexible-Rubber-Protector/dp/B07611HTJX/ref=sr_1_1?ie=UTF8&qid=1532112924&sr=8-1&keywords=vinyl+caps+1%2F4 https://www.amazon.com/10-Pack-Flexible-Rubber-Protector/dp/B07611HTJX/ref=sr_1_1?ie=UTF8&qid=1532112924&sr=8-1&keywords=vinyl+caps+1%2F4
Gas door after fix, rear to the right
Assortment of caps
The cap installed on the bolt
37tzee (12-24-2018)
Old 07-20-2018, 02:12 PM
getakey's Avatar
nice
I think they call those hacks these days
Old 07-20-2018, 02:17 PM
wallyo's Avatar
Originally Posted by getakey
nice
They probably do, but I'm 71 years old and fairly stuck in my ways. Incidentally the angle of the photo gives an impression of variable clearances around the door, but it's actually almost perfect.
Old 09-02-2018, 12:53 PM
SoccerCat's Avatar
Can you put an after fixed photo up? Thinking about trying this. The dealer supposedly did a fix on mine. It doesn’t stick out from the body anymore but very crooked, almost touching on the lower right.
Old 09-02-2018, 01:15 PM
wallyo's Avatar
The picture after the "repair" is in my original post, and I mentioned that although the gaps with the surrounding panel look uneven, they are not. It was the camera angle because I had no room to get at a larger distance and the phone uses a wide-angle lens. And the lid itself is flush with the surrounding panel. Your lid should not be crooked, and I'm guessing that the dealer twisted the door hinge to make it lie flush. So my solution will probably not fix your problem at this point.
Old 12-20-2018, 07:30 AM
Forum Contributor
EE4Life's Avatar
Received 1,391 Likes on 643 Posts
See TSB 18-073 - Fuel Fill Door Rear Edge Does Not Line Up in the 2017-2019 TSB threads.
itsnickONG
05-02-2010 11:09 PM
tlaspecteinss
02-21-2010 10:41 AM
dm8701
11-05-2009 04:04 PM
ljmushock
10-20-2006 12:45 PM
Quick Reply: A very simple fix for the gas fill door
