Taillight issue 2014 MDX
Old 02-24-2019, 06:41 PM
4th Gear
tiwale's Avatar
how to change tail light? replaced both bulbs, still no light. water entered and messed up light
Old 02-25-2019, 10:39 AM
neoshi's Avatar
Just the same way you changed the bulb, through that access panel in the trunk area, there is (I think) 1 bolt holding the tail light to the body. After you get that out, you should be able to pull the tail light toward you and it should slide out. OH but remember to take off the black cover surrounding the trunk opening (this is what should have prevented the water from intruding into the tail light).
Old 02-25-2019, 10:51 AM
4th Gear
tiwale's Avatar
Thank you for your reply Neoshi. I did that, but there were only 2 bulbs which I replaced. The 1 bolt you said to remove, is that part of the assembly or is it somewhere else ?
Old 02-25-2019, 12:28 PM
neoshi's Avatar
Here you go, found a video:
It's actually two bolts on the outside once you remove the cover and the inside is just guide pins.
I would check the harness to make sure there's no water damage. But also check the fuse box. It may have popped from the circuit being submerged.
Old 02-25-2019, 12:38 PM
4th Gear
tiwale's Avatar
I saw that video too and did replace the turn signal and brake light. My problem is when the light is on, the rear tail light is not working and I do not know where/how to replace it. All these videos are for the brake and turn signal lights. I think there may be a bulb with the assembly.
Old 02-25-2019, 02:01 PM
2016 Acura TLX
honda_nut's Avatar
I think you are talking about the led strip judging from the picture that you provided. There is no replaceable bulb for that and you will need to replace that entire taillight. If you do replace it, make sure that there is no way water can get into it again as that will ruin the light.
Here is the part that you can buy online: https://www.oemacuraparts.com/oem-pa...QtYXV0b21hdGlj
Or check on ebay for used versions.
Old 02-25-2019, 02:35 PM
neoshi's Avatar
Yep, sorry. I thought you knew you had to replace the entire assembly for the LED strip. It's not replaceable. You'll need a whole new unit but they're cheap used on ebay.
skinnyboy09
3G RDX (2019+)
14
03-04-2020 08:30 AM
bmtrbz2002
3G MDX (2014-2020)
02-16-2019 04:27 PM
Nates NJTL
3G MDX (2014-2020)
02-16-2019 03:24 PM
juanrl
1/2G MDX (2001-2013)
02-15-2019 05:55 AM
mxd04
01-28-2019 09:38 AM
Quick Reply: Taillight issue 2014 MDX
