Notices
Spare Wheel/Tire for 20" Wheels?
Old 06-26-2019, 03:51 PM
Registered Member
I've asked this question once before but didn't get any answers...long story short is I have OEM 20" wheels on my MDX and have a 17" spare tire. The spare tire size is 165/80D17. I've always been under the impression that using a different sized wheel will mess up the transmission. My question is is there a spare tire that is designed for the OEM 20" wheel options?
I've found 06421-TZ5-A51which says it is a 20" spare tire kit, but after calling a few dealerships, they say that it's actually a 17" spare wheel. Out of the three dealerships I've called, two are saying that the 17" spare tire that I have is all that is made for the MDX and that since I should only be driving on it for a small amount of time no damage should occur. Also, I could get a full sized spare, but it likely won't fit in the spare tire compartment. I just want to make sure I'm not setting myself up for larger issues but using the 17" spare tire with three 20" wheels.
cougar hunter is offline
Old 06-27-2019, 11:56 AM
Registered Member
Measure the overall diameter of the two tires. You might find them nearly the same.
Donn0128 is offline
Old 06-28-2019, 09:22 AM
Registered Member
I did that already. The 20" wheel and tire is 29.6" while the 17" spare and tire is 27.4". A difference of 7.4%. That seems a little high IMO>.
Old 06-28-2019, 09:35 AM
Received 5,938 Likes on 4,760 Posts
But it's a spare, not intended to be used for a long period of time.
thoiboi is online now
Old 06-28-2019, 09:50 AM
Registered Member
Agreed, but I'd rather not put the differential at risk for damage by using an incorrect sized wheel.
Old 06-28-2019, 11:22 AM
Registered Member
Try buying a same sized OEM wheel from ebay. I bought one for my 2018 Hybrid Tech Package.
ShortKarateGi is offline
Old 06-28-2019, 12:08 PM
Registered Member
Does yours fit in the spare tire well?
Old 06-30-2019, 08:44 AM
mrgold35
mrgold35's Avatar
I did the same as ShortKarateGI for my MDX sport hybrid. The sport hybrid doesn't come with a spare tire, no tools to change a flat, or crank/cable to mount under the MDX. Found a black 20" Berlina rim and slightly used OEM Conti tire on eBay. I haven't mounted the spare yet because I just got everything in; but, had to go out of town for 2 weeks (took my 11 MDX with full size spare). I can be +500 miles from home and the speed limit is between 70-80 mph on the interstate hwys. Recommended of 70 miles max range at 50 mph max speed for a donut wouldn't work for me in the southwest.
mrgold35 is offline
08 NBP TL
Fourth Generation TL (2009-2014)
09-20-2018 09:01 PM
Skirmich
Second Generation TL (1999-2003)
41
09-12-2018 09:29 PM
08 NBP TL
09-27-2010 06:38 PM
sidemarker
2G CL Transmission Recall Q & A
19
01-27-2004 02:57 PM
TypeSKid
Second Generation CL Discussion (2000-2003)
06-27-2001 01:59 PM
Quick Reply: Spare Wheel/Tire for 20" Wheels?
