Go Back  AcuraZine - Acura Enthusiast Community > Acura MDX Community > 3G MDX Discussion (2014+)
Reload this Page >
Slight Noise from Steering Wheel When Turning
Notices
Old 12-21-2018, 10:26 PM
Registered Member
MBP 03's Avatar
I would like to get some feedback from fellow 2017 & up owners about whether your steering wheel is perfectly silent or if you hear a slight noise coming from the clock spring / cable reel area when turning at low speeds.
My wife's 2017 Sport Hybrid with almost 19K miles on the odometer that we've owned since about 14K miles makes a little bit of noise that can only be heard when it's relatively quiet in the car and if you're listening for it . The best way to describe it is to compare it to the sound that a ball bearing makes. Since I don't do a lot of driving in this car, I can't put my finger on whether the steering wheel noise was there from day one or if it got worse since we had the car, but I did happen to hear it today and was curious about whether this is normal in the MDX or if it's something that needs to be addressed.
Thanks!
MBP 03 is offline
Old 12-24-2018, 09:06 AM
New Member
I bought a brand new 18' model recently and noticed the noise coming from the steering wheel when turning and driving over a manhole cover. Dealer replaced the cable reel and steering wheel assembly, no luck. After a couple more visits to the dealer for checkups, they found the 3 bolts to secure the suspension to the sub frame were not tightened properly, they were loosen. After re-tightened them, noise was gone.
Charlie_Brown is offline
Old 01-07-2019, 09:56 AM
New Member
Old 01-07-2019, 01:48 PM
Registered Member
andysinnh's Avatar
I will say that the steering in a vehicle with electronic power assist isn't as "silent" as a hydraulic unit is (at least at the steering shaft level). I first noticed it in my wife's '12 TL SH-AWD. It had this slight rubbing sound when turning her steering wheel at slow speeds without ambient car noise. I noticed it to a lesser extent in my '15 RDX, and somewhere in the middle with my '17 MDX. It's not a looseness, and it's not like something is rubbing or not lubed properly. It's just a "sound" that you get from the steering shaft. Your best bet is to see if you can drive another MDX the next time you're at the dealer to see if the sound is the same.....
andysinnh is offline
Old 01-09-2019, 04:31 PM
Registered Member
MBP 03's Avatar
Yes. That pretty much describes what I'm hearing on ours. It's very faint and can really only be heard when it's virtually silent in the car. Thanks!
MBP 03 is offline
Old 05-05-2019, 07:50 AM
New Member
My Ď18 Pilot Touring had the noise and itís identical in my Ď18 MDX Tech. The steering is accurate and tight. Iím of the opinion all is ok.
Boardmember is offline
Old 05-06-2019, 08:20 AM
Registered Member
I hear 2 noises:
1) Spring like noise from steering column when backing out of driveway and turning steering wheel while backing out at extremely slow speed. Has happened since I bought my 19 Advance. Hard to explain sound other than it sounds like a spring
2) When driving over rough road, if steering wheel is turned to the left I hear a rattle/knock sound coming from what appears to be steering column. Only happens when I turn to the left and only over rough roads. Doesn't make sound when going straight. I have the 19 advance with active dampers so suspension in general is much more quiet over rough roads then the suspension on the Tech.
bobby2478 is offline
Old 05-06-2019, 10:53 AM
Registered Member
I had a spring noise in mine while turning which was due to a faulty AirBag assembly which ended up being replaced.
undertaker2k8 is offline
Old 05-06-2019, 08:05 PM
Registered Member
MBP 03's Avatar
As an update, the noise seems to have gotten somewhat louder since my original post and now sounds more like a spring noise. My plan is to bring the car in to the dealer soon to get this taken care of along with the taillight recall and this way, I will kill two birds with one stone.
MBP 03 is offline
Old 05-13-2019, 02:36 PM
Registered Member
Did the sound go away after they replaced the airbag assembly? Mine is in the shop now and they are going to try replacing the cable reel, but per the other posts this isn't likely to address the problem. I also let them know about the airbag assembly in the event the cable reel doesn't address the spring sound (as I suspect it won't)
Fatfrii
07-18-2014 02:03 AM
guyenacurazine
Second Generation TL (1999-2003)
03-07-2009 01:06 PM
PenguinQX
12-18-2005 02:31 AM
sc354
12-20-2004 10:01 AM
1st timer
19
12-19-2004 12:19 PM
Quick Reply: Slight Noise from Steering Wheel When Turning
