Question about 15 MDX
Hi All,
I was reviewing the Torque Converter TSB, and saw that warranty extended to 8yrs/80k miles, does it mean our tranny extended to 8 yrs now instead of 7? Also, for the payload, I saw a hitch cargo box was rated 200lbs, does it mean I got extra 200lbs on top of the 1173lb payload? Or the 200lbs is included in the 1173lbs? Thank you |
ask your dealer because the TSB may already be done on your MDX. As to the weight question, if you are measuring payload of the MDX then the tongue weight is part of the gross weight. If you are pulling the trailer and it weighs 3,000 pounds, then the 200 pounds is part of that 3000 pounds. So to state again - if the limit of payload weight in the MDX is appx 1400 pounds than you subtract the 200 from that so you have 1200 left.
