Notices
odd noise after turning off engine
Old 05-13-2019, 07:41 PM
Registered Member
getakey's Avatar
Today, I turned off the engine and opened driver door probably a little quicker than normal. I hear a sound coming from rear area live an electric motor - similar to sound of outside mirrors folding (but they weren't).
Do the electric dampers adjust after turning off engine? It may be there all the time, but first time I've noticed?
getakey is offline
Old 05-14-2019, 06:57 PM
Registered Member
Parking brake?
pcloadletter is offline
Old 05-14-2019, 07:45 PM
Registered Member
jdpdata's Avatar
Yup it's the electronic parking brake engaging. Totally normal. I hear on our '17 Sport Hybrid too.
jdpdata is offline
Old 05-14-2019, 08:03 PM
Registered Member
getakey's Avatar
does it automatically engage? I did not turn it on
getakey is offline
Old 05-16-2019, 02:26 PM
Registered Member
I can't say for sure as I haven't fully tested out this theory. I believe if you have the auto brake engaged, the parking brake will auto engage also when you put the car in park and shut it off.
lausy is offline
Old 05-16-2019, 03:08 PM
Registered Member
getakey's Avatar
Its for sure the parking brake as I turned it on with the button and heard the noise.
By auto brake, do you mean Brake Hold? I do not have that engaged. Maybe it is in one of the settings
getakey is offline
Old 05-16-2019, 04:03 PM
Registered Member
According to manual the parking brake auto engages when:
In the following situations, the parking brake automatically operates.
標hen the vehicle stops more than 10 minutes while ACC with LSF is activated.
標hen the driver痴 seat belt is unfastened while your vehicle is stopped automatically by ACC with LSF.
標hen the engine is turned off, except by Auto Idle Stop system, while ACC with LSF is activated.
標hen the vehicle stops with the automatic brake hold system activated for more than 10 minutes.
標hen the driver痴 seat belt is unfastened while your vehicle is stopped and automatic brake hold is applied.
標hen the engine is turned off, except by Auto Idle Stop system, while automatic brake hold is applied.
標hen there is a problem with the Automatic Brake Hold System while automatic brake hold is applied.
bobby2478 is offline
lausy (05-21-2019)
Old 05-16-2019, 04:32 PM
Registered Member
getakey's Avatar
thanks
That said I don't think I was in one of those scenarios. I did not have Brake Hold on nor was ACC or SF engaged
I'll chalk it up to an anomaly
getakey is offline
Ugpo
Third Generation RLX (2013+)
09-05-2016 12:01 PM
KidK
08-21-2013 09:37 PM
bubolrdx
Second Generation RDX (2013-2018)
06-25-2013 12:44 AM
evan03CL
Second Generation CL Discussion (2000-2003)
10-24-2009 06:36 PM
atsioukl
04-05-2009 06:10 AM
Quick Reply: odd noise after turning off engine
