mdx 2017 jewel headlights wiring.?
Old 02-21-2019, 08:21 AM
nickdavina's Avatar
Hey Acura people,
I bought myself a set of jewel eyes headlight units from a 2017-2018 Acura MDX.
Could anybody tell me what wires go in to the ballast of this light unit.?
I found the older models have a 6 pin connector and also found what wire is what.
Like ground is most left upper pin
Feed DRL
Feed low beam
Feed High beem.
Only the new type has a 12 pin connector on the ballast and cant find what pin is what.
If anyone of you have this info than please let me know.
Don’t want to blow the ballast by feeding 12 volts to the from pin.
Kind regards
Nick Davina.
Old 10-24-2019, 01:36 PM
Esteban Sandoval's Avatar
Please help
Hi man, did you got the 12pin plug pinout? Color code?
Old 10-24-2019, 07:48 PM
ceb
ceb's Avatar
Received 1,276 Likes on 951 Posts
Originally Posted by nickdavina
Hey Acura people,
Feed DRL
Feed low beam
Feed High beem.
Kind regards
Nick Davina.
Uhhhh....Acura LEDs have ballasts?
Old 10-25-2019, 10:09 AM
rsutoratosu's Avatar
Its something.. like a ballast, prob controller.. i can't find it in acura parts but its ACURA 33109TZ5A511
Ebay listing calls it ballast
https://www.ebay.com/itm/2017-2019-A...UAAOSwH9Jdpj2l
Old 10-25-2019, 10:12 AM
Check this out.. he made adapter for jewel into tsx.. you prob can reach out to them and see if they have one for your model
https://www.ebay.com/i/333152215414?...SABEgK6c_D_BwE
Old 02-05-2020, 03:04 PM
spacecoupe's Avatar
Hey Acura people,
Feed DRL
Feed low beam
Feed High beem.
Kind regards
Nick Davina.
I dont know if you got help or not. I was doing some research on the same lights but for another car. i went to Acura for the pigtails that go into that connecter but they "wouldnt find it" in the computer. Maybe it was because I was pretty clear about not having one at all just the lights. He probably thought I stole them lol i digress. I ended up going the more expensive route and sourced it from findpigtails.com. You wont find it under MDX but you can find it under TLX. They are the same igniter. Ill post a link underneath in case you or someone else needs it. I then went into the wiring diagram to figure out the pinout. After that I found a cheap HB4 & HB3 pigtails and spliced them together to be able to plug them into the originial wiring of my car. I suggest you do the same. You can look up the wire diagram with the VIN number of your car and be able to do the same i would assume. I hope its helpful.
Pinout:
2 Ground
7 high beam
12 low beam
11 Daytime Running lights
Pin12 Lowbeam + Pin 2grnd
Pin11 DRL + Pin 2grnd
Pin7 + Pin 2grnd
Pigtails - https://findpigtails.com/product/d21...2018-acura-tlx
Iceberg4577 (10-11-2020)
Old 05-25-2020, 09:56 AM
Carlos Morales's Avatar
Pinout:
2 Ground
7 high beam
12 low beam
Pin7 + Pin 2grnd
Did u know how to wire the turn signals? Also from 12 pin ballast
Old 10-11-2020, 12:43 PM
3rd Gear
Iceberg4577's Avatar
Trying to upgrade from 2014 MDX headlights to 2019 MDX headlights
Hi group, I am new to this group and was wondering if someone could help me with this upgrade. So I have a 2014 Acura MDX and wanted to upgrade the frond end to a 2019. I got lucky enough to buy it from someone who totaled their new MDX and sold me the hood, the fenders, bumper with grille and the headlights. I thought it was going to be plug and play for the headlights, but the plug on the 2019 has a 12 pin connector. Can anyone offer me any suggestions on how to proceed with successfully connecting the headlights?
Any help would be greatly appreciated.
Old 10-11-2020, 01:24 PM
Received 16,260 Likes on 11,971 Posts
perhaps you need the suggested pigtails in the thread is what you need?
Old 10-11-2020, 01:31 PM
3rd Gear
Justnspace, i think that you are right. I was hoping that someone else had done the upgrade and could guide me.
Thank you!
Old 10-11-2020, 01:35 PM
^well, yes.. look and read above.. looks like they bought the pigtails and got it wired.
Old 03-04-2021, 05:19 PM
peter6's Avatar
If anybody still searching for info and found this thread, take a look at
https://acurazine.com/forums/3g-mdx-...r-info-992850/
Edit: I just figured out that all of 2 threads that I found are in the same subforum. Sorry for digging all of them up!
Old 06-20-2021, 02:05 AM
Ashir Mahendra's Avatar
I was looking for this exact adapter, but the link does not seem to work. Is there any chance you might have the seller's store name?
skillman
1/2G MDX (2001-2013)
09-13-2016 12:02 AM
relaxed83
05-14-2014 11:44 PM
duran492
11-04-2010 04:22 PM
MrFluffy
03-11-2010 02:57 AM
jhochman
04-07-2009 05:07 PM
Quick Reply: mdx 2017 jewel headlights wiring.?
