GO HOME voice command
Wondering if anyone tried the voice GO HOME from any screen?? Mine only works is I go to menu first, if I try the command on the map , it goes to phone book list! I was reading the user manual and it says it should work from any screen?!
I just gave up. it is much quicker to just hit menu and and dial go home.
That command is more likely to put you in an accident than looking away from the road.
Well, just got back from the dealer , tech will call Acura on Monday to find out if there is a software update coming out soon. I did have a "home" contact on my iPhone , I deleted it and it worked fine for 1 day, if I turn off the Bluetooth on my cell it works fine from the map screen, BUT I found another issue , I am using the go home PIN, and when "go home" works from the map screen , after asking for the PIN it goes to the EDIT go home page instead!!! Crazy ! So if I go to Display menu first , all works fine including the Bluetooth on. SO only 5 steps.... 1- Display Menu , 2- Go home, 3- Pin, 4- OK, 5- set as destination.....until I finish all 5 I got home already!
I haven't done any exhaustive testing, but it's worked the few times I've used it.
I programmed HOME into the address book manually, and as far as I know don't have a "Home" entry in my iPhone, so can't address that.
