beeping when rear door closed
sometimes if I open the rear door first and then close it, I get multiple rapid beeps
I thought it might be because headlights turned on when I opened it, but tonight I opened rear first and closed it and only got 1 beep and headlights were on I know the door is closed completely - what is it trying to warn me of? |
Originally Posted by getakey
(Post 16108367)
I thought it might be because headlights turned on when I opened it, but tonight I opened rear first and closed it and only got 1 beep and headlights were on I know the door is closed completely - what is it trying to warn me of? Regards, Jim |
it does rapid beeps when I close the rear door, but only sometimes. Its acting like the door has not shut properly, but it has.
If it's repeatable - did you run it by the dealer?
not repeatable - random so far
I only get multiple beep when I open and close doors and don't have the key fob on me. With the key in my pocket, I get only one beep. Note that I have Walk Away Lock abled.
Is your engine on when this rapid beeping occurs? Usually the rapid beeping = key fob not detected while engine is running. I usually stop the car from making those beeps by keeping a door slightly ajar (just sitting on the striker). It overrides the beeping this way.
nope - engine off. It was when I unlocked car at rear door to put my computer bag in the back seat on the floor before I opened driver door. Closed rear door and got multiple beeps. The door completely closed.
It has only happened a couple times. I'm wondering if the strap from the bag was in the way of the door closing and just put the sensor slightly off |
