Back to Stock wheels?
I am think of going back to my stock wheels on the 2015 MDX. My Vossen VFS-2 are lovely although I do miss the acceleration with the stock wheels on. Where is a good place to get of OEM TPMS for the 2015 so I can mount 19 wheels back to my Original wheels? LOL.
An online search of OEM Acura parts will return you many viable online OEM part retailers. Most prices are in the same ballpark. The differentiator will be the shipping cost. Most, if not all of the sites are run by dealerships. You could price the parts online and contact your local dealer to see if they would match the prices. If they won't match, order them online. I have used several of the sites without issue.
Originally Posted by Apollo2TheMoon
(Post 16269396)
Edit: Out of curiosity I looked up the sensor assembly for my 2006 TL on both Tire Rack and Bernardi Parts, would you believe the TireRack unit is $44.00 while the OEM unit from Bernardi is only $33.32; yikes makes me look like a total chump! :tongue: |
(Post 16269690)
When it comes to wheels, apart from styling and offset, the most important is weight and strength of construction. That is key to better handling and better mileage. When I swapped out my wheels for the supra, I went from 23-26lbs per wheel to 17lbs per wheel from Wedssports Racing. thats ~30 lbs of rotational weight and supposedly in internet formulation, that is 30x6 = 180 lbs in stationary weight. It would be interesting to know what the OEM offset wheels are.
Originally Posted by shenofjo
(Post 16270807)
I think it does get more complicated though. you got to consider the weight of the tires as well with such different sizes. Weight of the wheels do tend to get heavier with bigger diameter too. Im no expert and so I'd keep it to apples to apples comparison of 20" stock vs 20" aftermarket if possible. Almost nobody went with oem 17" sizes in the Supra world and people were going 18", 19", even 20". I stuck with the 17" for lower overall weight vs larger wheels.
anyone has info on the OEM spec of the wheels? 20", offset and weight would be great for aftermarket comparisons. |
(Post 16269396)
https://www.ebay.com/itm/New-OEM-Gen....c100290.m3507 |
Hmm dang, the VFS2 + tires in 20s are that much heavier that you can really notice the change in accel eh? That's a shame, although not too surprising I guess, as Vossen's cast wheels are just about as heavy as any other aftermarket cast wheels of the same size (IIRC, these are about 30lbs each, but maybe Vossen can confirm). Now I wonder how much the OEM 5x120 20" MDX rims weigh..
Whoops said cast but meant that flow form thingy they do.
Originally Posted by neoshi
(Post 16271152)
(Post 16271224)
Matters not, a light 20" wheel will cause slower acceleration and braking than a "heavy" 17" wheel.
https://www.wedswheelsna.com/wedssport-ft117.html
they are expensive but just showing how much lighter they can get at less than 25lbs a piece at 20" and strong. so the sport hybrids are 5x120 eh? |
2017+ is all 5x120.
Originally Posted by nyczzzjohn
(Post 16271130)
Apollo2TheMoon - say it isn't so, you were my inspiration to get 20" vossens. These were the honda/acura oem tpms I purchased and put on my vossens:
(Post 16271152)
(Post 16271130)
It fit my 2014 mdx, so it should work on the 2015 - plug and play, no programming. 42753-TZ3-A51 |
I got my 2015 MDX back to stock wheels. The 19 X 8.5 in stock wheel weigh in at 60.9 lbs each, surprisingly the Vossen 20 X 10 in weigh in at 60.2 lbs. The Vossen flow form does make the wheel for sure lighter.
Perhaps weight is one thing but the wider contact patch made the bigger impact in terms of handling. What was it about the wider vossens that you didnt like in terms of driving dynamics? Steering, nimbleness, acceleration? |
