Notices
Aftermarket Cross Bar Install
Old 04-15-2019, 04:39 PM
AcuraEnthusiast
gtinmia's Avatar
Liked 12 Times in 11 Posts
Aftermarket Cross Bar Install '14
I installed these aftermarket cross bars on my '14 MDX today. I didn't like the look of the OEM black ones and the price was a bit much. I was able to get these for $175 and couldn't be happier with the look.
Tools I used:
T25 Torx Bit
5/32 Allen Wench Hex Bit
WD40
Microfiber towels
This was a pretty straight forward install, except for adjusting the bars so they are flush against the roof rails. The best way for me was to tighten one end of the cross bar with the T25 Torx bit and connect it to the roof rail with the 5/32 allen wrench. I didn't tighten bolts to the roof rail too much. I just put it in enough so I can maneuver the opposite end up and down. On the other side, I lifted up the cross bar and adjusted the width to fit and then tightened it to the corner bracket. Once that was done, I tightened it to the roof rail, and then went back and tightened the first side. I sprayed WD40 in the holes of the roof rails and also on the bolts it came with before the install.
These things are heavy. Each weighs about 6 pounds. I primarily got these as I plan on taking a road trip and installing the Thule 614 Pulse. I will try to tackle that next and post pictures. I will report back on wind noise before I install the cargo box. Overall it took about 45 minutes to install. What do you think? How does it look?
This will be going on there soon.
gtinmia is offline
Old Yesterday, 10:04 AM
Registered Member
Liked 9 Times in 4 Posts
Nice clean install! Personally I prefer the black crossbars, but itís nice to see there are other options.
That strip of chrome along the bottom of the front bumper lip, is that something you added or did it come with it?
Mdx-4me is offline
DeathtoToasters
143
07-31-2017 01:38 PM
Colt45
1G TL Tires, Wheels & Suspension
09-27-2012 03:48 AM
switchfootvz
09-15-2010 01:15 AM
MMsTSX
20
10-08-2008 02:53 PM
djbarber
1G RDX Problems & Fixes
02-25-2007 08:49 AM
Quick Reply: Aftermarket Cross Bar Install
