Go Back  AcuraZine - Acura Enthusiast Community > Acura MDX Community > 3G MDX Discussion (2014+)
Reload this Page >
3G MDX Technical Service Bulletins by Model Year (Links Inside)
Notices
Old 04-28-2015, 06:20 PM
  #41
Forum Contributor
EE4Life's Avatar
Received 1,112 Likes on 478 Posts
TSB 14-025 - Timing Belt Chirps in post #18 was revised to include the 2015 MDX - ALL.
EE4Life is offline
Old 05-13-2015, 07:06 PM
  #42
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 15-017 - AcuraLink System Status Indicator Is Red and DTC B1403 Will Not Clear
Applies To: 2014 MDX - ALL with navigation - ALL
2015 MDX - 2WD with navigation - From VIN 5FRYD3...FB000001 thru 5FRYD3...FB007880
2015 MDX - SH-AWD with navigation - From VIN 5FRYD4...FB000001 thru 5FRYD4...FB018838
http://www.urvi.net/forumfiles/SB/B15-017.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15-017.PDF
EE4Life is offline
Old 05-13-2015, 09:07 PM
  #43
Registered Member
jayth.lg's Avatar
Are these the latest?
jayth.lg is offline
Old 05-14-2015, 05:26 PM
  #44
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 15-029 - Safety Recall: MDX CMBS Error
Applies To: 2014–15 MDX - Advance and Advance SH-AWD - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B15-029.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15-029.PDF
EE4Life is offline
Old 05-17-2015, 10:32 PM
  #45
Registered Member
jayth.lg's Avatar
Originally Posted by EE4Life View Post
Adding new TSB.
LinkDeny
Thank you for the updates!
jayth.lg is offline
Old 05-23-2015, 09:16 AM
  #46
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 15-023 - HomeLink System Has Weak or Limited Range
Applies To: 2014–16 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B15-023.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15-023.PDF
EE4Life is offline
Old 05-29-2015, 10:51 PM
  #47
Registered Member
jayth.lg's Avatar
Adding new TSB.
Applies To: 2014 MDX – ALL
http://www.urvi.net/forumfiles/SB/B14-025.PDF
LinkDeny
Just had my vehicle serviced regarding the chirping sound.
jayth.lg is offline
Old 06-25-2015, 09:45 PM
  #48
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 15-037 - Safety Recall: A/C Compressor Clutch Bolt
Applies To: 2014–15 MDX - ALL with 2WD - Check the iN VIN status for eligibility
2014–15 - MDX - ALL with SH-AWD - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B15-037.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15-037.PDF
EE4Life is offline
Old 07-09-2015, 08:24 AM
  #49
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 15-034 - Product Update: Vehicle Shifts into Neutral and MIL Comes On with DTC P0657
Applies To: 2016 MDX - With 9-speed A/T - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B15-034.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15-034.PDF
EE4Life is offline
Old 07-09-2015, 12:00 PM
  #50
Registered Member
is it better now?
krazienluv10 is offline
Old 08-21-2015, 05:55 PM
  #51
Forum Contributor
EE4Life's Avatar
Adding new TSBs.
TSB 15-001 - Vehicles with Navigation: Audio Turns Off After Using HFL, No Sound/Static in Rear Headphones, and Other Listed Issues
Replaces S/B 14-014, Vehicles with Navigation: Audio Turns Off After Using HFL, No Sound/Static in Rear Headphones, and Other Listed Issues
http://www.urvi.net/forumfiles/SB/B15-001.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15-001.PDF
TSB 15-036 - HVAC Display Flashes or Flickers
Applies To: 2014–15 MDX - ALL with navigation - ALL
http://www.urvi.net/forumfiles/SB/B15-036.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15-036.PDF
EE4Life is offline
neoshi (09-18-2015)
Old 08-28-2015, 08:04 PM
  #52
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 15-039 - Transmission End Cover Leaks (9-Speed A/T)
Applies To: 2016 MDX - ALL with 9-speed A/T - ALL
http://www.urvi.net/forumfiles/SB/B15-039.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15-039.PDF
EE4Life is offline
neoshi (09-18-2015)
Old 09-18-2015, 10:33 PM
  #53
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 15-046 - Security System Sounds or May Not Set
Applies To: 2014–15 MDX - ALL - ALL
2016 MDX - ALL 2WD - From VIN 5FRYD3H..GB000001 to 5FRYD3H..GB007326
2016 MDX - ALL SH-AWD - From VIN 5FRYD4H..GB000001 to 5FRYD4H..GB029373
http://www.urvi.net/forumfiles/SB/B15-046.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15-046.PDF
EE4Life is offline
neoshi (09-18-2015)
Old 12-22-2015, 09:35 AM
  #54
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 15-053 - MIL Comes On with DTC P0430
Applies To: 2014-15 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B15-053.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15-053.PDF
EE4Life is offline
neoshi (12-22-2015)
Old 12-23-2015, 07:45 AM
  #55
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 15-054 - Transmission Function Improvements: Sensation of Surge While Braking, Slow Downshift Response at Low Engine Speeds and Other Listed Symptoms
Applies To: 2016 MDX - 2WD Base - From VIN 5FRYD3H2.GB000001 – 5FRYD3H2.GB012656
2016 MDX - 2WD Technology - From VIN 5FRYD3H4.GB000001 – 5FRYD3H4.GB012723
2016 MDX - 2WD Advance - From VIN 5FRYD3H9.GB000001 – 5FRYD3H9.GB012787
2016 MDX - AWD Base - From VIN 5FRYD4H2.GB000001 – 5FRYD4H2.GB039814
2016 MDX - AWD Technology - From VIN 5FRYD4H4.GB000001 – 5FRYD4H4.GB039727
2016 MDX - AWD Advance - From VIN 5FRYD4H9.GB000001 – 5FRYD4H9.GB039756
http://www.urvi.net/forumfiles/SB/B15-054.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15-054.PDF
EE4Life is offline
neoshi (12-23-2015)
Old 12-23-2015, 08:57 AM
  #56
Registered Member
Great News!!
Adding new TSB.
LinkDeny
This is Great News for all 2016 MDX owners! Way to go Honda America!!!
RSLTSX09XMNAVWX is offline
Old 01-12-2016, 06:45 PM
  #57
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 15-054 was revised today to add some trim levels and VINs.
Applies To: 2016 MDX - 2WD Base - From VIN 5FRYD3H2.GB000001 thru 5FRYD3H2.GB012656
2016 MDX - 2WD Technology - From VIN 5FRYD3H4.GB000001 thru 5FRYD3H4.GB012723
2016 MDX - 2WD Technology and Entertainment - From VIN 5FRYD3H6.GB000001 thru 5FRYD3H6.GB012711
2016 MDX - 2WD Advance - From VIN 5FRYD3H9.GB000001 thru 5FRYD3H9.GB012787
2016 MDX - AWD Base - From VIN 5FRYD4H2.GB000001 thru 5FRYD4H2.GB039814
2016 MDX - AWD Technology - From VIN 5FRYD4H4.GB000001 thru 5FRYD4H4.GB039727
2016 MDX - AWD Technology and Entertainment - From VIN 5FRYD4H6.GB000001 thru 5FRYD4H6.GB040204
2016 MDX - AWD Advance - From VIN 5FRYD4H9.GB000001 thru 5FRYD4H9.GB039756
EE4Life is offline
neoshi (01-12-2016)
Old 01-12-2016, 06:47 PM
  #58
Registered Member
neoshi's Avatar
TSB 15-054 was revised today to add some VINs.
LinkDeny
Ah ha! I knew it! I made a case with ACR because of missing VINs lol. My case manager still won't return my call
neoshi is offline
Old 01-20-2016, 07:23 PM
  #59
Forum Contributor
EE4Life's Avatar
Adding new TSB.
http://techinfo.honda.com/Rjanisis/p...nu/B14-025.PDF
TSB 14-025 was revised to include some 2016 MDX VINs.
2016 MDX - 2WD - From VIN 5FRYD3...GB000001 thru 5FRYD3...GB008556
2016 MDX - AWD - From VIN 5FRYD4...GB000001 thru 5FRYD4...GB032107
EE4Life is offline
neoshi (01-20-2016)
Old 01-26-2016, 04:44 PM
  #60
Registered Member
neoshi's Avatar
Gonna help ya out with one EE4Life lol
16-001 Remote Engine Start System Poor Range Performance
AFFECTED VEHICLES
2014–15
MDX
ALL
BACKGROUND
Both remote transmitters (or FOBs) may have poor range performance and/or intermittent remote engine starting operation due to radio frequency interference (RFI).
CORRECTIVE ACTION
Replace both remote transmitters and the transceiver unit.
File Type: pdf
neoshi is offline
Old 01-26-2016, 06:28 PM
  #61
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 16-001 - Remote Engine Start System Poor Range Performance
http://www.urvi.net/forumfiles/SB/B16-001.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16-001.PDF
EE4Life is offline
neoshi (06-08-2016)
Old 01-27-2016, 11:01 AM
  #62
Registered Member
Adding new TSB.
LinkDeny
Thanks for that!
I thought I was just nuts that the fob wouldn't work intermittently - go figure it's a documented issue.
My question (for you or anyone who can help) is how do I report this issue? Whenever it's an intermittent problem, it's nearly impossible to document, making it 'un-reproducible' at the dealer, thus something they tend to dismiss...
808tesh is offline
Old 02-12-2016, 05:01 PM
  #63
Registered Member
Originally Posted by 808tesh View Post
Thanks for that!
if you have the remote start mentioned in that TSB. Then you're affected by it.
manera is offline
Old 03-23-2016, 02:42 PM
  #64
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 16-008 - High Pressure Fuel Pump Chirps
Applies To: 2014-16 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B16-008.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16-008.PDF
EE4Life is offline
neoshi (03-23-2016)
Old 03-23-2016, 04:23 PM
  #65
Registered Member
Holy Fuel pump! Glad they put in that sound bite, that is EXACTLY what mine sounds like.
tman is offline
Old 03-24-2016, 09:04 PM
  #66
Registered Member
Sound Bite??
I opened both PDF's, but nothing happens when I try the sound bite??
Old 03-24-2016, 10:37 PM
  #67
Registered Member
neoshi's Avatar
There's like a super duper tiny play button so just click around in the sound bite area.
neoshi is offline
Old 03-25-2016, 12:25 AM
  #68
Registered Member
I can only open the one from urvi.ney and cant find the sound bite. Opening via samsung s6. Do i have to use a pc?
mondster is offline
Old 03-25-2016, 01:52 AM
  #69
Registered Member
neoshi's Avatar
Yeah pc is best. I've tried various android pdf readers and they can't seem to play the sound. Works in acrobat on the pc for sure.
neoshi is offline
Old 03-25-2016, 02:32 AM
  #70
Registered Member
Thanks! now i cant locate the damn play button. lol. im hoping this fixes the annoying chirp on my tlx and mdx.
mondster is offline
Old 03-25-2016, 10:28 AM
  #71
Registered Member
I had to download Adobe Acrobat reader and a few plug in's for my Windows 8.1 machine, then everything worked fine. I don't have the sound but at least now I know what to look for. 2015 MDX, 23,000 miles, 29.2 MPG on my return trip yesterday fro Las Vegas to San Diego!!
Old 06-04-2016, 08:25 AM
  #72
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 16-032 - Safety Recall: 2015–16 MDX Fuel Tank
Applies To: 2015-16 MDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B16-032.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16-032.PDF
EE4Life is offline
neoshi (06-08-2016)
Old 06-08-2016, 08:37 AM
  #73
Forum Contributor
EE4Life's Avatar
Adding new TSBs.
TSB 16-026 - 2017 MDX: TQI and New Model Service Information
Applies To: 2017 MDX - 2WD
2017 MDX - 2WD with Technology Package
2017 MDX - 2WD with Technology and Entertainment Packages
2017 MDX - 2WD with Advance Package
2017 MDX - 2WD with Advance and Entertainment Packages
2017 MDX - SH-AWD
2017 MDX - SH-AWD with Technology Package
2017 MDX - SH-AWD with Technology and Entertainment Packages
2017 MDX - SH-AWD with Advance Package
2017 MDX - SH-AWD with Advance and Entertainment Packages
http://www.urvi.net/forumfiles/SB/B16-026.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16-026.PDF
TSB 16-027 - 2017 MDX: TQI of the Navigation System
Applies To: 2017 MDX - All with Navigation
http://www.urvi.net/forumfiles/SB/B16-027.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16-027.PDF
EE4Life is offline
neoshi (06-08-2016)
Old 06-11-2016, 10:38 AM
  #74
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 16-031 - Power Tailgate Won’t Open from the Outside in Cold Weather
Applies To: 2015 MDX - ALL - ALL
2016 MDX - 2WD - From VIN 5FRYD3H..GB000001 thru 5FRYD3H..GB004424
2016 MDX - SH-AWD - From VIN 5FRYD4H..GB000001 thru 5FRYD4H..GB013891
http://www.urvi.net/forumfiles/SB/B16-031.PDF
http://techinfo.honda.com/Rjanisis/pubs/SB/AH/B16-031/enu/B16-031.PDF
EE4Life is offline
neoshi (06-13-2016)
Old 06-14-2016, 07:31 PM
  #75
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 14-031 - Steering Column Screeches When Moving
2016 MDX - ALL - From VIN 5FRYD4H..GB000001 thru 5FRYD4H..GB060678
http://www.urvi.net/forumfiles/SB/B14-031.PDF
http://techinfo.honda.com/Rjanisis/pubs/SB/AH/B14-031/enu/B14-031.PDF
EE4Life is offline
neoshi (06-14-2016)
Old 07-19-2016, 09:40 PM
  #76
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 16-035 - Rattle or Clunk from the Rear Suspension
Applies To: 2014-16 MDX - ALL with 2WD - ALL
2014-16 MDX - ALL with 4WD - ALL
http://www.urvi.net/forumfiles/SB/B16-035.PDF
http://techinfo.honda.com/Rjanisis/pubs/SB/AH/B16-035/enu/B16-035.PDF
EE4Life is offline
neoshi (07-19-2016)
Old 07-19-2016, 11:40 PM
  #77
Registered Member
Finally a fix to that clunk. Only took them 3 yrs to fix it too!
mondster is offline
Old 07-21-2016, 05:11 PM
  #78
4G TL-Elilte, 3G MDX
The most important point is that there is a fix to the rear suspension clunk.
Edward'TLS is offline
Old 09-08-2017, 10:34 AM
  #79
Registered Member
TSX69's Avatar
Received 1,169 Likes on 552 Posts
Exclamation Recall
https://www.carcomplaints.com/news/2...el-leaks.shtml
Acura MDX Sport Hybrid SUVs Recalled Over Fuel Leaks
Acura MDX Sport Hybrid engine fuel feed hoses and fuel purge hoses may have been misrouted.
By David A. Wood, CarComplaints.com
Posted in Recalls
September 7, 2017 — Acura is recalling nearly 200 model year 2017 Acura MDX Sport Hybrid SUVs to fix fuel leaks that may cause the vehicles to catch on fire.
Acura says the engine fuel feed hoses and fuel purge hoses may have been misrouted by assembly employees.
The crossed hoses can contact other components and damage the hoses, possibly causing the hoses to leak gas.
Acura doesn't know when the recall will begin, but dealers will inspect the routing of the fuel feed hoses and the fuel purge hoses and if misrouted, the hoses will be replaced.
If you own a 2017 Acura MDX Sport Hybrid and have questions about the recall, please call 888-234-2138 and use recall number KF8.
CarComplaints.com has complaints about the Acura MDX and many other Acura vehicles.
TSX69 is offline
EE4Life
Fifth Generation TLX (2015+)
02-21-2019 09:50 AM
notfast
1G & 2G MDX Discussion (2001-2013)
10-21-2015 01:16 PM
09-17-2015 10:16 AM
mossman77
18
09-16-2015 12:21 PM
09-14-2015 10:09 PM
Quick Reply: 3G MDX Technical Service Bulletins by Model Year (Links Inside)
