3G MDX Technical Service Bulletins by Model Year (Links Inside) - AcuraZine - Acura Enthusiast Community
Go Back  AcuraZine - Acura Enthusiast Community > Acura MDX Community > 3G MDX Discussion (2014+)
Reload this Page >
Notices
Old 03-11-2014, 01:13 AM
csmeance's Avatar
Follow these instructions. Exactly!
PLEASE CLEAR YOUR CACHE BEFORE PROCEEDING. IF YOU DON'T, AND HAVE A PROBLEM, CLEAR YOUR CACHE.
1. Open this link .
2. Open any one of the listings.
3. You can now open the below listed links.
2013:
TSB 13-022: 2014 MDX: TQI of the Navigation System
TSB 13-023: 2014 MDX: TQI Information
TSB 13-024: MIL Comes On With DTCs P0300 Thru P0306 (2013 MDX, 2013 TL SH-AWD, 2013 ZDX)
TSB 13-028: Safety Recall: Accessory Trailer Harness Wires Mislabeled (2014 MDX)
TSB 13-039: Ticking From the Dashboard or Front Damper (2014 MDX)
TSB 13-042: Safety Recall: Propeller Shaft Bolts May Be Loose or Missing(2014 MDX SH-AWD)
2014 Acura MDX Technical Service Bulletins
https://acurazine.com/forums/3g-mdx-...letins-947745/
2015 Acura MDX Technical Service Bulletins
https://acurazine.com/forums/3g-mdx-...letins-947741/
2016 Acura MDX Technical Service Bulletins
https://acurazine.com/forums/3g-mdx-...letins-947739/
2017 Acura MDX Technical Service Bulletins
https://acurazine.com/forums/3g-mdx-...letins-947743/
2018 Acura MDX Technical Service Bulletins
https://acurazine.com/forums/3g-mdx-...letins-962250/
2019 Acura MDX Technical Service Bulletins
https://acurazine.com/forums/3g-mdx-...letins-971626/
Last edited by EE4Life; 08-03-2018 at 05:51 PM. Reason: Added link for 2019 Acura MDX Technical Service Bulletins
csmeance is offline
The Following 5 Users Say Thank You to csmeance For This Useful Post:
808tesh (04-16-2014), alkus77 (05-11-2014), erg69 (01-20-2016), sockr1 (11-16-2016), victorber (02-01-2018)
Old 03-11-2014, 09:11 AM
Registered Member
You are not authorized to view the content on this page.
If you believe you have received this message in error, please contact the Support Center.
Please go back or return to the home page.
jzhu625 is offline
Old 03-11-2014, 11:28 AM
Registered Member
I hope he edited in the bright red and blue text AFTER you posted this. Otherwise, epic fail.
syntax53 is offline
Old 03-11-2014, 02:33 PM
Registered Member
Tried on Chrome, Firefox, and IE still no luck even after cleared.
jzhu625 is offline
Old 03-11-2014, 02:34 PM
Registered Member
Works for me (firefox).
syntax53 is offline
Old 03-12-2014, 02:35 PM
Registered Member
Works fine for me (Mac + Chrome)
ryanful is offline
Old 03-12-2014, 06:03 PM
Registered Member
Works for me in Chrome.
Also there is a new TSB for vibration noise on the driver area which involves the plastic engine covers under the hood. Could you add it into the list?
hadokenuh is offline
Old 03-12-2014, 08:24 PM
Registered Member
Isn't there one with the waterpump pulley also? thanks!!! this should be sticky'd
krazienluv10 is offline
Old 03-13-2014, 09:38 AM
Registered Member
does not work on me, sigh. can someone be kind enough pull the PDF down and host it somewhere else?
jzhu625 is offline
Old 03-13-2014, 03:41 PM
Registered Member
I have a mac and it doesnt work on safari or Chrome.
SinCityTLX is offline
Old 03-15-2014, 07:34 AM
Registered Member
Why are these alerts not showing up in the Acura Link app? That's what the app was designed for...
Luisito is offline
Old 03-15-2014, 08:12 AM
Registered Member
Generally manufactures do not notify customers for general TSBs as TSBs aren't mandatory nor are they a right for repair. Recalls are a different story. These links are all old anyway, though.
syntax53 is offline
Old 04-27-2014, 05:53 PM
Registered Member
Latest Service Bulletin 14-014
File Type: pdf
Kirill is offline
The Following 2 Users Say Thank You to Kirill For This Useful Post:
alkus77 (05-11-2014), jlkdoh (04-28-2014)
Old 05-13-2014, 01:39 PM
Registered Member
Please sticky and attach the files to this thread. This is very good information that all MDX owners should know.
markpaco is offline
Old 05-20-2014, 05:41 PM
Registered Member
...had these lying around...
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
808tesh is offline
Old 05-20-2014, 07:20 PM
Forum Contributor
EE4Life's Avatar
Adding new TSBs.
TSB 14-010 - 2015 MDX: TQI Information
Applies To: 2015 MDX - All
http://www.urvi.net/forumfiles/SB/B14-010.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B14-010.PDF
TSB 14-011 - 2015 MDX: TQI of the Navigation System
Applies To: 2015 MDX - All with Navigation
http://www.urvi.net/forumfiles/SB/B14-011.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B14-011.PDF
EE4Life is offline
Old 07-16-2014, 07:03 PM
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 14-026 - MID Reads "12 Volt Battery Charging System Problem"
Applies To: 2014 MDX - 2WD - From VIN 5FRYD3H..EB000001 thru 5FRYD3H..EB016054
2014 MDX - SH-AWD - From VIN 5FRYD4H..EB000001 thru 5FRYD3H..EB032792
http://www.urvi.net/forumfiles/SB/B14-026.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B14-026.PDF
EE4Life is offline
Old 07-31-2014, 05:23 PM
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 14-025 - Timing Belt Chirps
Applies To: 2014 MDX ALL
http://www.urvi.net/forumfiles/SB/B14-025.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B14-025.PDF
EE4Life is offline
The Following User Says Thank You to EE4Life For This Useful Post:
Smalleyeqq168 (07-31-2014)
Old 08-29-2014, 10:36 PM
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 14-033 - Oil Filter Is Hard to Remove
Applies To: 2014 MDX - 2WD - From VIN 5FRYD3...EB000001 thru 5FRYD3...EB017889
2014 MDX - SH-AWD - From VIN 5FRYD4...EB000001 thru 5FRYD4...EB039646
http://www.urvi.net/forumfiles/SB/B14-033.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B14-033.PDF
EE4Life is offline
Old 08-30-2014, 02:10 AM
Registered Member
Thanks for the oil filter TSB. Hope it does not apply to 2015.
tman is offline
Old 10-08-2014, 04:31 PM
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 14-038 - Safety Recall: Front Seatbelts Will Not Extend or Retract Properly in Extremely Cold Weather
Applies To: 2014-15 MDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B14-038.PDF
http://techinfo.honda.com/Rjanisis/pubs/SB/AH/B14-038/enu/B14-038.PDF
EE4Life is offline
Old 10-30-2014, 04:10 PM
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 14-037 - Client Satisfaction Improvement Campaign: Update for 2015 MDX and TLX ODMD (Vehicles with Navigation)
Applies To: 2015 MDX - All with Navigation - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B14-037.PDF
http://techinfo.honda.com/Rjanisis/pubs/SB/AH/B14-037/enu/B14-037.PDF
EE4Life is offline
Old 10-30-2014, 04:59 PM
Registered Member
They better release one of those for the 2014 owners. Wtf.
syntax53 is offline
The Following User Says Thank You to syntax53 For This Useful Post:
9SpeedTran (02-25-2015)
Old 10-31-2014, 04:01 AM
4G TL-Elilte, 3G MDX
Agree. WTF !
Edward'TLS is offline
Old 11-01-2014, 09:16 AM
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 14-035 - Second Row Seats Stained by Acura Genuine Accessory Second Row Seat Covers
Applies To: 2014 MDX - ALL
http://www.urvi.net/forumfiles/SB/B14-035.PDF
http://techinfo.honda.com/Rjanisis/pubs/SB/AH/B14-035/enu/B14-035.PDF
EE4Life is offline
Old 11-01-2014, 11:22 AM
Registered Member
I may have the answer,,,
Originally Posted by EE4Life View Post
Adding new TSB.
For those of you with a 2014 MDX are saying why not have this upgrade for you?? I would have asked the same question. I just checked the Acura Customer Experience site on my 2015 MDX, correct VIN Number, and it DOES show the software upgrade... Note this upgrade is for the 2015 MDX and 2015 TLX, NOT the RLX. The RLX looks like the interior of the MDX and TLX.. Acura uses similar parts across model Ines. I am assuming that the TLX NAV-ENT module used for the first year 2015, is also the same unit that is used in the 2015 MDX, so I am saying that the 2015 MDX is different than the 2014. The changes in the Hardware-Firmware allows for these upgrades to be made, where that is NOT the case in the 2014 MDX.. This is something I have seen on my brothers Lexus, and that was confirmed by the Lexus dealer. The nave system in his GL-330 looked exactly the same but in fact was changed after only 2 years of production. You may not be aware of this but the TLX has one added feature in the audio system, SIRI. I would love to see a software upgrade to add SIRI to the MDX. Who Knows, that may be next. OK, now only by you talking to your dealer and asking them the question about your 2014 will we know for sure. We know the TLX has 8 speed Auto, has 5 setting of IDS Vs our 6 speed and 3 IDS, however I would NOT trade that for the comfortable ride of the MDX vs the more Firm ride of the TLX..My wife has a 2009 TLX with a 6 CD changer, in 2011 they removed it and put in the Hard Drive for storing songs, also made upgrades to the NAV screen, sharper contrast.. These changes and upgrades made year after year has been something that seems routine. When I purchased my 2004 Honda Pilot, fully loaded, they DID NOT offer a Sun Roof even with the LX Leather trim level and NAV. The very next year, 2005, they had the identical car, but added a Sun Roof, and the price only went up by $175... This stuff drives us crazy as buyers.. Think of those that purchased a 2013 MDX in September of 2012, only to find out that if they waited another month could have purchased a 2014 total re-designed MDX for the same price.. Just need to do your homework..
RSLTSX09XMNAVWX is offline
Old 11-01-2014, 08:43 PM
Registered Member
You have very good points about different model years and upgrades. However the 14 and 15 are identical. I have driven several 15 loaners and it is a twin of my 14. I called Acura customer service on Friday and voiced my concerns. They stated I had a valid complaint, they had received other complaints, and are forwarding to upper management. So, I guess we will see if the 14's will be included in the near future. 14 owners...CALL ACURA and voice your opinion!
Stu's2004TL is offline
Old 11-02-2014, 01:06 AM
Blue color text is very difficult to read, especially everything in one paragraph, with no break in between.
The Following User Says Thank You to Edward'TLS For This Useful Post:
honda_nut (12-18-2014)
Old 11-15-2014, 07:57 AM
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 14-045 - Power Steering Buzz or Grunt After Shifting From Reverse
2015 MDX - 2WD - From VIN 5FRYD3H4.FB000001 thru 5FRYD3H4.FB006937 and 5FRYD3H8.FB000001 thru 5FRYD3H8.FB007398
2015 MDX - SH-AWD - From VIN 5FRYD4H4.FB000001 thru 5FRYD4H4.FB016167 and 5FRYD4H8.FB000001 thru 5FRYD4H8.FB016387
http://www.urvi.net/forumfiles/SB/B14-045.PDF
http://techinfo.honda.com/Rjanisis/pubs/SB/AH/B14-045/enu/B14-045.PDF
EE4Life is offline
The Following 3 Users Say Thank You to EE4Life For This Useful Post:
808tesh (01-26-2015), dismali (11-17-2014), Smalleyeqq168 (11-15-2014)
Old 12-17-2014, 07:26 PM
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 14-048 - New Warranty Instructions for TPMS-Related Repairs
Applies To: 2014-15 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B14-048.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B14-048.PDF
EE4Life is offline
Old 01-21-2015, 04:12 PM
Forum Contributor
EE4Life's Avatar
Adding new TSBs.
TSB 15-004 - 2016 MDX: TQI and New Model Service Information
Applies To: 2016 MDX - All
http://www.urvi.net/forumfiles/SB/B15-004.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15-004.PDF
TSB 15-005 - 2016 MDX: TQI of the Navigation System
Applies To: 2016 MDX - All with Navigation
http://www.urvi.net/forumfiles/SB/B15-005.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15-005.PDF
EE4Life is offline
Old 01-21-2015, 04:44 PM
Registered Member
2016!!!!!!
Adding new TSBs.
LinkDeny
LinkDeny
Looks like the 2016 gets some new features including a 8 speed automatic.
Old 01-21-2015, 06:09 PM
Registered Member
hondu's Avatar
You mean 9-speed. Looks like all V6 Acuras are going to the ZF 9-speed.
hondu is offline
Old 01-21-2015, 07:32 PM
Registered Member
And cross traffic alert along with some kind of auto parking feature according to that document..............
pcaddict66 is offline
Old 01-21-2015, 08:15 PM
Registered Member
That seems unfair!!!
Wait, I just purchased my 2015, and now they add these extra features and upgrades. I hope Acura will take mine back and give me a 2016!!! OK, sounds like some folks who can't get the Nav Software Upgraded in their 2014.. As I stated before you can just keep waiting and waiting to get a new car expecting changes along the way, but you will never get that new car waiting...
Again, sounds like they want the ILX, TLX and MDX, RLX all to have a single transmission, makes everything easier from a manufacturing point of view and of course profitability and price stabilization..
Acura needs to continue to differentiate themselves from the competition, so all this is to be expected. The 2017 will get a refresh, so who know, Tilting Side mirrors as well for USA customers....
Old 01-21-2015, 08:40 PM
Registered Member
Tigmd99's Avatar
So, 2014-2015 MDX have 2nd gen SH-AWD?
Tigmd99 is offline
Old 01-23-2015, 06:38 PM
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 15-009 - Rattle from the Second Row Passenger Seat on Rough Roads
Applies To: 2014 MDX - ALL with 2WD - From VIN 5FRYD3H..EB000001 thru 5FRYD3H..EB009288
2014 MDX - ALL with SH-AWD - From VIN 5FRYD4H..EB000001 thru 5FRYD4H..EB019090
http://www.urvi.net/forumfiles/SB/B15-009.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15-009.PDF
EE4Life is offline
Old 02-04-2015, 06:48 PM
Forum Contributor
EE4Life's Avatar
Adding new TSB.
TSB 15-007 - MIL Comes On With DTC P0134 /P0154
http://www.urvi.net/forumfiles/SB/B15-007.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15-007.PDF
EE4Life is offline
Old 02-24-2015, 08:06 PM
Registered Member
Hidden Menu
I can't recall what two buttons you push and hold for 2 seconds that bring up the hidden menus, in particular the GPS satellite information?
Old 02-24-2015, 08:28 PM
Registered Member
Found It
OK, I located the information,,
Free 30 Second Audio Upgrade
I recently purchased a Hybrid Honda Accord and came across this radio mod on the driveaccord.net forum that worked on my 2014 Acura MDX. It'll make your audio sound right!
Steps:
Press Nav + Menu + Back 3 seconds
The 2 screens will display debug menus you should not have access normally
Press return on the touch screen one (you don't need it)
Press Menu for 3 seconds
You will be in the developer menu
Scroll down to DSP/AMP settings
Scroll to 'Flat' set it to 'On'
Enjoy!
Quick Reply: 3G MDX Technical Service Bulletins by Model Year (Links Inside)
