2019 Acura MDX Technical Service Bulletins
2019 Acura MDX Technical Service Bulletins:
TSB 18-037 - 2019 MDX: TQI and New Model Service Information Applies To: 2019 MDX - 2WD - Base, with Technology Package, with Technology Package And Entertainment Package, with Advance Package, with Advance Package And Entertainment Package 2019 MDX - SH-AWD - Base, with Technology Package, with Technology Package And Entertainment Package, with A-Spec Package, with Advance Package, with Advance Package And Entertainment Package http://www.urvi.net/forumfiles/SB/B18-037.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-037.PDF TSB 18-038 - 2019 MDX: TQI of the Navigation System Applies To: 2019 MDX - ALL http://www.urvi.net/forumfiles/SB/B18-038.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-038.PDF TSB 18-042 - 2019 MDX Sport Hybrid: TQI Information Applies To: 2019 MDX Sport Hybrid - With Technology Package, With Advance Package http://www.urvi.net/forumfiles/SB/B18-042.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-042.PDF TSB 18-043 - 2019 MDX Sport Hybrid: TQI of the Navigation System Applies To: 2019 MDX Sport Hybrid - With Technology Package, With Advance Package http://www.urvi.net/forumfiles/SB/B18-043.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-043.PDF TSB 14-025 - Timing Belt Chirps Applies To: 2014-18 MDX - ALL - ALL 2019 MDX - 2WD - From VIN 5J8YD3...KL000001 thru 5J8YD3...KL005096 2019 MDX - AWD - From VIN 5J8YD4...KL000001 thru 5J8YD4...KL011104 2019 MDX Sport Hybrid - From VIN 5J8YD7...KL000001 thru 5J8YD7...KL000483 http://www.urvi.net/forumfiles/SB/B14-025.PDF http://techinfo.honda.com/rjanisis/p...nu/B14-025.PDF TSB 15-039 - Transmission End Cover Leaks (9-Speed A/T) Applies To: 2016-17 MDX - ALL with 9-speed A/T - ALL 2018 MDX - AWD - From VIN 5J8YD4H..JL000001 thru 5J8YD4H..JL028339 2019 MDX - 2WD - From VIN 5J8YD3H..KL000008 thru 5J8YD3H..KL000552 http://www.urvi.net/forumfiles/SB/B15-039.PDF http://techinfo.honda.com/rjanisis/p...nu/B15-039.PDF TSB 18-045 - Service Manual Update: F-CAN Bus Connected Unit Check Applies To: 2019 MDX Sport Hybrid - ALL http://www.urvi.net/forumfiles/SB/B18-045.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-045.PDF TSB 18-061 - Safety Recall: Soft or Low Brake Pedal Applies To: 2017-19 MDX - ALL - Check the iN VIN status for eligibility 2017-18 MDX Sport Hybrid - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B18-061.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-061.PDF TSB 18-073 - Fuel Fill Door Rear Edge Does Not Line Up Applies To: 2017-19 MDX - ALL - VINs that start with 5J8YD 2017-19 - MDX Sport Hybrid - ALL - VINs that start with 5J8YD http://www.urvi.net/forumfiles/SB/B18-073.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-073.PDF TSB 19-004 - 2014-19 RLX Sport Hybrid and 2017-19 MDX Sport Hybrid: Transmission Judders, Shudders, or Surges While Driving Applies To: 2017-19 MDX Sport Hybrid - ALL - ALL http://www.urvi.net/forumfiles/SB/B19-004.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-004.PDF TSB 19-005 - Multiple Indicators On and Option Fuse (E21 or B7) Blown Applies To: 2016-19 MDX - ALL - ALL 2017-19 MDX Sport Hybrid - ALL - ALL http://www.urvi.net/forumfiles/SB/B19-005.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-005.PDF TSB 19-017 - Buzzing or Whining When Adjusting Front Seat Forward and Backward Applies To: 2014-19 MDX - ALL - ALL 2017-19 MDX Sport Hybrid - ALL - ALL http://www.urvi.net/forumfiles/SB/B19-017.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-017.PDF TSB 19-019 - Safety Recall: 2014-19 MDX Inner Lights Applies To: 2014-19 MDX - ALL - Check the iN VIN status for eligibility 2017-19 MDX Sport Hybrid - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B19-019.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-019.PDF TSB 19-026 - Safety Recall: 3.5L V6 Timing Belt Applies To: 2018-19 MDX - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B19-026.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-026.PDF TSB 19-027 - Service Manual Update: 2014-19 MDX and 2017-19 MDX Sport Hybrid Inner Taillight Sub Harness Applies To: 2014-19 MDX - ALL 2017-19 MDX Sport Hybrid - ALL http://www.urvi.net/forumfiles/SB/B19-027.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-027.PDF TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram Applies To: 2005-20 MDX 2017-20 MDX Sport Hybrid http://www.urvi.net/forumfiles/SB/B19-059.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF TSB 20-013 - Navigation Display Distorts After 1 or More Hours of Driving Applies To: 2018-20 MDX - Tech Advance, Hybrid Tech, Hybrid Advance, A-Spec - ALL http://www.urvi.net/forumfiles/SB/B20-013.PDF http://techinfo.honda.com/rjanisis/p...nu/B20-013.PDF http://techinfo.honda.com/rjanisis/p...enu/B14162.PDF (Link works, but is wrong) TSB 20-015 - 9-Speed A/T Hard Upshift with Steady Acceleration Applies To: 2016-19 MDX - ALL - ALL 2020 MDX - AWD - From VIN 5J8YD4...LL000001 thru 5J8YD4...LL011456 2020 MDX - 2WD - From VIN 5J8YD3...LL000001 thru 5J8YD3...LL003798 http://www.urvi.net/forumfiles/SB/B20-015.PDF http://techinfo.honda.com/rjanisis/p...nu/B20-015.PDF TSB 20-019 - Driver's and Front Passenger's Seat-Back Clicks or Pops Applies To: 2019-2020 MDX - ALL - ALL 2019-2020 MDX Sport Hybrid - ALL - ALL http://www.urvi.net/forumfiles/SB/B20-019.PDF http://techinfo.honda.com/rjanisis/p...nu/B20-019.PDF TSB 20-022 - Service Manual Update: Second-Row Seat Frame Replacement Applies To: 2014-20 MDX 2017-20 MDX Sport Hybrid http://www.urvi.net/forumfiles/SB/B20-022.PDF http://techinfo.honda.com/rjanisis/p...nu/B20-022.PDF TSB 20-039 - Emissions Recall: 2017-20 MDX Sport Hybrid Odd Gear Monitor Software Update Applies To: 2017-20 MDX Sport Hybrid - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B20-039.PDF http://techinfo.honda.com/rjanisis/p...nu/B20-039.PDF TSB 20-041 - Rear Engine Mount Chirps Applies To: 2018 MDX 2WD - ALL - From VIN 5J8YD3.....000303 and later 2018 MDX AWD - ALL - 5J8YD4.....000186 and later 2019 MDX - ALL - ALL http://www.urvi.net/forumfiles/SB/B20-041.PDF http://techinfo.honda.com/rjanisis/p...nu/B20-041.PDF TSB 21-013 - Safety Recall: 2019-20 MDX and MDX Sport Hybrid Fuel Pump Motor Applies To: 2019-20 MDX - ALL - Check the iN VIN status for eligibility 2019-20 MDX Sport Hybrid - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B21-013.PDF http://techinfo.honda.com/rjanisis/p...nu/B21-013.PDF TSB 21-016 - Safety Recall: Multi-Model Fuel Pump Motor Applies To: 2019-20 MDX - 2WD - ALL - Check the iN VIN status for eligibility 2019-20 MDX - SH-AWD - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B21-016.PDF http://techinfo.honda.com/rjanisis/p...nu/B21-016.PDF TSB 23-001 - Product Update: 2016-23 MDX PGM-FI Idle Stop Software Update Applies To: 2016-20 MDX - All (except Hybrid) - Check the iN VIN status for eligibility 2022-23 MDX - All (except Hybrid & Type S) - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B23-001.PDF http://techinfo.honda.com/rjanisis/p...nu/B23-001.PDF TSB 23-002 - Warranty Extension: Engine Does Not Auto Restart After Entering Auto Idle Stop Applies To: 2016-20 MDX (with 9A/T) - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B23-002.PDF http://techinfo.honda.com/rjanisis/p...nu/B23-002.PDF TSB 23-009 - Engine Does Not Crank Applies To: 2016-20 MDX - ALL (except Hybrid) - ALL http://www.urvi.net/forumfiles/SB/B23-009.PDF http://techinfo.honda.com/rjanisis/p...nu/B23-009.PDF TSB 23-024 - 2019-20 MDX A/C Compressor Shaft Seal Leak Applies To: 2019-20 MDX - A-SPEC, ADV, BASE, TECH - ALL http://www.urvi.net/forumfiles/SB/B23-024.PDF http://techinfo.honda.com/rjanisis/p...nu/B23-024.PDF TSB 23-035 - MIL Comes on with DTC P0441 Applies To: 2018-20 MDX - ALL - ALL http://www.urvi.net/forumfiles/SB/B23-035.PDF http://techinfo.honda.com/rjanisis/p...nu/B23-035.PDF TSB 23-036 - Safety Recall: 2015-20 Multi-Model Connecting Rod Bearing Stop Sale Applies To: 2016-20 MDX - ALL (except Hybrid) - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B23-036.PDF http://techinfo.honda.com/rjanisis/p...nu/B23-036.PDF TSB 24-001 - Safety Recall: 2016–20 MDX Connecting Rod Bearing Applies To: 2016-20 MDX - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B24-001.PDF http://techinfo.honda.com/rjanisis/p...nu/B24-001.PDF TSB 24-006 - Safety Recall: 2014–20 MDX and 2018–20 MDX Sport Hybrid Fuel Pump Motor Applies To: 2014-20 MDX - ALL - Check the iN VIN status for eligibility 2018-20 MDX Sport Hybrid - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B24-006.PDF http://techinfo.honda.com/rjanisis/p...nu/B24-006.PDF http://techinfo.honda.com/rjanisis/p...B24-006 v2.PDF (Link works, but is wrong) Version 2 |
