2018 transmission problems and dealership messed my car 🤬😡
2018 transmission problems and dealership messed up my car 🤬😡
Hey was sup everyone. I just bought a brand new 2018 MDX in August. So about a month ago I got into my MDX and put it into reverse and it didn’t want to move. Then I put it into drive and it didn’t want to move. I had to rev the car up to 4000 rpm and then it finally moved. As i pull out the parking space I heard a loud noise as if I cracked/broke something. I came out to check and make sure everything was good and I didn’t notice anything. While driving I was hearing a grind/click noise. When I got home the noise wasn’t as loud. The next day I took it to Acura and they said that the transmission is over filled with transmission oil. Then drain it and said I should be good. I now hear a wind noise on deceleration up to 40mph. I took it back to Acura and they said its my transmission but they cant not work on my car bc I did not buy the car from them. I took it back to where I bought it and they said they can not duplicate the problem. But they change the VSA module and said everything is good. They kept my car for over 3 weeks. Now when they dropped my car off to me I notice some damages. So pissed right now😡. The problem started at a little under 1900 miles. I keep my cars clean and now it looks so dirty.
Dent and rip the metal and bumper
Chip on my door
Scuff with some scratches
Chip on my door
Hope things work out for you, the dealer should take care of you for the all issues
Seems strange this would happen at a legit Acura dealership, or any dealership for that matter. Hopefully they will correct your issues. You just have to be prepared for the finger pointing . . . . . the we didn't do it syndrome. Good luck!
Cajun Gumbo Man
I would file a complaint right away with Acura Corporate in Southern California ! There is no excuse for the damages your vehicle took yet alone the transmission issue with so few miles!!!!!
I would have lost my mind. Go get them!
I hope they do but they still have not responded to me. I been calling them since Wednesday every day. Smh
I did but its like they don’t care. I contact Acura Corporate and the GM of the store and they don’t respond. Dont even know what else to do
Personally I think this issue would involve more than a phone call, unless you live far away from this dealership. I would have been there the very next business day after discovering the issues. Or would have not accepted the vehicle if I had discovered the issues when the work was completed. Time does nothing but create uncertainty and proof of responsibility becomes tougher. You'll need to make sure you have EVERYTHING documented, including who you talked to at the dealership This needs to include all pictures and anything else which might help you make your case.
Cajun Gumbo Man
Are you calling the correct phone number? I get someone every time I call.... https://www.acura.com/contact-us
This is why I always take pictures when I drop off the vehicle and when I pick up. I also do a walk around inspection before I even get in the car and I go straight back to the SAs with issues. Once you take the vehicle, you basically introduce the YOU factor, which allows the dealership to deny it happened under their care. Hope it works out for the best.
Cajun Gumbo Man
did you check your Acura receipt ? When I bring my cars, they walk around and make note of any scratches, dents etc.... and write it on your bill.... If they didn't do this, you are going to have a hard time convincing Corporate that your vehicle was damaged by service department. When you call Corp, remain calm, professional and have your facts (did they note any damage to vehicle when your brought it in for service?). You need to convince that messenger to contact a "case manager" to return your call for further investigation between them and that dealership.... It may take a day or two for a case manager to call you back.... Once upon a time, my RL SRS light came on... Dealership quoted me $2k to fix.... I drove home and called corporate. It took 1-2 months to get them down to $425.00.... patience, professionalism and facts are golden....
n1njai
2G TL Photograph Gallery
17
12-06-2010 06:31 PM
