2018 Acura MDX Technical Service Bulletins
2018 Acura MDX Technical Service Bulletins:
TSB 17-036 - 2018 MDX: TQI and New Model Service Information Applies To: 2018 MDX - 2WD 2018 MDX - 2WD with Technology Package 2018 MDX - 2WD with Technology and Entertainment Packages 2018 MDX - 2WD with Advance Package 2018 MDX - 2WD with Advance and Entertainment Packages 2018 MDX - SH-AWD 2018 MDX - SH-AWD with Technology Package 2018 MDX - SH-AWD with Technology and Entertainment Packages 2018 MDX - SH-AWD with Advance Package 2018 MDX - SH-AWD with Advance and Entertainment Packages http://www.urvi.net/forumfiles/SB/B17-036.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-036.PDF TSB 17-037 - 2018 MDX: TQI of the Navigation System Applies To: 2018 MDX - All with Navigation http://www.urvi.net/forumfiles/SB/B17-037.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-037.PDF TSB 18-005 - 2018 MDX Sport Hybrid: TQI Information Applies To: 2018 MDX Sport Hybrid - With Technology Package, With Advance Package http://www.urvi.net/forumfiles/SB/B18-005.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-005.PDF TSB 18-006 - 2018 MDX Sport Hybrid: TQI of the Navigation System Applies To: 2018 MDX Sport Hybrid - With Technology Package, With Advance Package http://www.urvi.net/forumfiles/SB/B18-006.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-006.PDF TSB 14-025 - Timing Belt Chirps Applies To: 2014-18 MDX - ALL - ALL 2019 MDX - 2WD - From VIN 5J8YD3...KL000001 thru 5J8YD3...KL005096 2019 MDX - AWD - From VIN 5J8YD4...KL000001 thru 5J8YD4...KL011104 2019 MDX Sport Hybrid - From VIN 5J8YD7...KL000001 thru 5J8YD7...KL000483 http://www.urvi.net/forumfiles/SB/B14-025.PDF http://techinfo.honda.com/rjanisis/p...nu/B14-025.PDF TSB 15-039 - Transmission End Cover Leaks (9-Speed A/T) Applies To: 2016-17 MDX - ALL with 9-speed A/T - ALL 2018 MDX - AWD - From VIN 5J8YD4H..JL000001 thru 5J8YD4H..JL028339 2019 MDX - 2WD - From VIN 5J8YD3H..KL000008 thru 5J8YD3H..KL000552 http://www.urvi.net/forumfiles/SB/B15-039.PDF http://techinfo.honda.com/rjanisis/p...nu/B15-039.PDF TSB 16-008 - High Pressure Fuel Pump Chirps Applies To: 2014-18 MDX - ALL - ALL http://www.urvi.net/forumfiles/SB/B16-008.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-008.PDF TSB 18-007 - Shutter Set for Capless Fuel Filler (Mis-Fuel Inhibit Device) Is Frozen Applies To: 2017 MDX - ALL - ALL 2017 MDX Sport Hybrid - ALL - ALL 2018 MDX - ALL - ALL http://www.urvi.net/forumfiles/SB/B18-007.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-007.PDF TSB 18-014 - Clicking from the Power Seat While Using the Height or Tilt Adjustment Applies To: 2014-18 MDX - ALL - ALL 2017-18 MDX Sport Hybrid - ALL - ALL http://www.urvi.net/forumfiles/SB/B18-014.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-014.PDF TSB 18-015 - Safety Recall: Driver's Seat Frame Rivets Applies To: 2018 MDX - Tech, Tech SH-AWD - Check the iN VIN status for eligibility. (Only 7 vehicles are affected) http://www.urvi.net/forumfiles/SB/B18-015.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-015.PDF TSB 18-060 - Audio Unit Restarts On Its Own or CarPlay Does Not Work after iPhone Update Applies To: 2018 MDX - ALL - ALL 2018 MDX Sport Hybrid - ALL - ALL http://www.urvi.net/forumfiles/SB/B18-060.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-060.PDF TSB 18-061 - Safety Recall: Soft or Low Brake Pedal Applies To: 2017-19 MDX - ALL - Check the iN VIN status for eligibility 2017-18 MDX Sport Hybrid - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B18-061.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-061.PDF TSB 18-073 - Fuel Fill Door Rear Edge Does Not Line Up Applies To: 2017-19 MDX - ALL - VINs that start with 5J8YD 2017-19 - MDX Sport Hybrid - ALL - VINs that start with 5J8YD http://www.urvi.net/forumfiles/SB/B18-073.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-073.PDF TSB 19-004 - 2014-19 RLX Sport Hybrid and 2017-19 MDX Sport Hybrid: Transmission Judders, Shudders, or Surges While Driving Applies To: 2017-19 MDX Sport Hybrid - ALL - ALL http://www.urvi.net/forumfiles/SB/B19-004.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-004.PDF TSB 19-005 - Multiple Indicators On and Option Fuse (E21 or B7) Blown Applies To: 2016-19 MDX - ALL - ALL 2017-19 MDX Sport Hybrid - ALL - ALL http://www.urvi.net/forumfiles/SB/B19-005.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-005.PDF TSB 19-011 - Safety Recall: 2016-18 MDX and 2015-19 TLX V6 Fuel Pump Applies To: 2016-18 MDX - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B19-011.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-011.PDF TSB 19-017 - Buzzing or Whining When Adjusting Front Seat Forward and Backward Applies To: 2014-19 MDX - ALL - ALL 2017-19 MDX Sport Hybrid - ALL - ALL http://www.urvi.net/forumfiles/SB/B19-017.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-017.PDF TSB 19-019 - Safety Recall: 2014-19 MDX Inner Lights Applies To: 2014-19 MDX - ALL - Check the iN VIN status for eligibility 2017-19 MDX Sport Hybrid - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B19-019.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-019.PDF TSB 19-026 - Safety Recall: 3.5L V6 Timing Belt Applies To: 2018-19 MDX - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B19-026.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-026.PDF TSB 19-027 - Service Manual Update: 2014-19 MDX and 2017-19 MDX Sport Hybrid Inner Taillight Sub Harness Applies To: 2014-19 MDX - ALL 2017-19 MDX Sport Hybrid - ALL http://www.urvi.net/forumfiles/SB/B19-027.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-027.PDF TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram Applies To: 2005-20 MDX 2017-20 MDX Sport Hybrid http://www.urvi.net/forumfiles/SB/B19-059.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF TSB 20-013 - Navigation Display Distorts After 1 or More Hours of Driving Applies To: 2018-20 MDX - Tech Advance, Hybrid Tech, Hybrid Advance, A-Spec - ALL http://www.urvi.net/forumfiles/SB/B20-013.PDF http://techinfo.honda.com/rjanisis/p...nu/B20-013.PDF http://techinfo.honda.com/rjanisis/p...enu/B14162.PDF (Link works, but is wrong) TSB 20-015 - 9-Speed A/T Hard Upshift with Steady Acceleration Applies To: 2016-19 MDX - ALL - ALL 2020 MDX - AWD - From VIN 5J8YD4...LL000001 thru 5J8YD4...LL011456 2020 MDX - 2WD - From VIN 5J8YD3...LL000001 thru 5J8YD3...LL003798 http://www.urvi.net/forumfiles/SB/B20-015.PDF http://techinfo.honda.com/rjanisis/p...nu/B20-015.PDF TSB 20-018 - MIL Comes On with DTC P061B Applies To: 2017-18 MDX Sport Hybrid - ALL - ALL http://www.urvi.net/forumfiles/SB/B20-018.PDF http://techinfo.honda.com/rjanisis/p...nu/B20-018.PDF TSB 20-022 - Service Manual Update: Second-Row Seat Frame Replacement Applies To: 2014-20 MDX 2017-20 MDX Sport Hybrid http://www.urvi.net/forumfiles/SB/B20-022.PDF http://techinfo.honda.com/rjanisis/p...nu/B20-022.PDF TSB 20-039 - Emissions Recall: 2017-20 MDX Sport Hybrid Odd Gear Monitor Software Update Applies To: 2017-20 MDX Sport Hybrid - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B20-039.PDF http://techinfo.honda.com/rjanisis/p...nu/B20-039.PDF TSB 20-041 - Rear Engine Mount Chirps Applies To: 2018 MDX 2WD - ALL - From VIN 5J8YD3.....000303 and later 2018 MDX AWD - ALL - 5J8YD4.....000186 and later 2019 MDX - ALL - ALL http://www.urvi.net/forumfiles/SB/B20-041.PDF http://techinfo.honda.com/rjanisis/p...nu/B20-041.PDF TSB 23-001 - Product Update: 2016-23 MDX PGM-FI Idle Stop Software Update Applies To: 2016-20 MDX - All (except Hybrid) - Check the iN VIN status for eligibility 2022-23 MDX - All (except Hybrid & Type S) - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B23-001.PDF http://techinfo.honda.com/rjanisis/p...nu/B23-001.PDF TSB 23-002 - Warranty Extension: Engine Does Not Auto Restart After Entering Auto Idle Stop Applies To: 2016-20 MDX (with 9A/T) - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B23-002.PDF http://techinfo.honda.com/rjanisis/p...nu/B23-002.PDF TSB 23-008 - LKAS, ACC, or CMBS Indicators On with DTC U3000-49 Applies To: 2017-18 MDX - ALL 2017-18 MDX Sport Hybrid - ALL http://www.urvi.net/forumfiles/SB/B23-008.PDF http://techinfo.honda.com/rjanisis/p...nu/B23-008.PDF TSB 23-009 - Engine Does Not Crank Applies To: 2016-20 MDX - ALL (except Hybrid) - ALL http://www.urvi.net/forumfiles/SB/B23-009.PDF http://techinfo.honda.com/rjanisis/p...nu/B23-009.PDF TSB 23-035 - MIL Comes on with DTC P0441 Applies To: 2018-20 MDX - ALL - ALL http://www.urvi.net/forumfiles/SB/B23-035.PDF http://techinfo.honda.com/rjanisis/p...nu/B23-035.PDF TSB 23-036 - Safety Recall: 2015-20 Multi-Model Connecting Rod Bearing Stop Sale Applies To: 2016-20 MDX - ALL (except Hybrid) - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B23-036.PDF http://techinfo.honda.com/rjanisis/p...nu/B23-036.PDF TSB 24-001 - Safety Recall: 2016–20 MDX Connecting Rod Bearing Applies To: 2016-20 MDX - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B24-001.PDF http://techinfo.honda.com/rjanisis/p...nu/B24-001.PDF TSB 24-006 - Safety Recall: 2014–20 MDX and 2018–20 MDX Sport Hybrid Fuel Pump Motor Applies To: 2014-20 MDX - ALL - Check the iN VIN status for eligibility 2018-20 MDX Sport Hybrid - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B24-006.PDF http://techinfo.honda.com/rjanisis/p...nu/B24-006.PDF http://techinfo.honda.com/rjanisis/p...B24-006 v2.PDF (Link works, but is wrong) Version 2 |
