2017 MDX - no power from OBD2
I am trying to install BlackVue dashcam using BlackVue Power Magic EZ () on 2017 MDX w/tech.
- When I connect the dashcam using Power Magic EZ to MDX OBD2, there is NO power to the dashcam with car on or off. - When I connect same Power Magic EZ to my 2007 TL OBD2, there is NO power with car on or off. - When I connect OBD2 code reader to either MDX or TL, there IS power to the reader ! - When I connect same Power Magic EX to Tesla S, there IS power to dashcam - When I connect dashcam via cig. lighter adapter on MDX, there IS power to dashcam I have done lots of reading but unable to find a solution. Anyone experiencing similar problem? I am tempted to check the OBD2 port's pin 16 (+12V battery) and pin 4/5 (ground) directly using multi-meter to see if there is power. https://cimg6.ibsrv.net/gimg/acurazi...bf88f79d5a.jpg |
Common sense says it's the power magic adapter.. Maybe there's a jumper you can move.
Break out the multimeter, however, I suspect you'll have 12v at the obdii port |
Do you have your dip switches set properly?
Dip switches are currently set to 12v cut-off. There is a switch to simply turn off the parking mode, so it would turn ON only when car is ON. This didn't help. Strangely it worked in Tesla, so I am little puzzled.
Sounds like it's time to get the multimeter out.
:werd:
update...
After messing with this for a while.. I finally decided to check voltage directly coming out of OBD2. Pin 16 (+12v) and Pin 4 (GND) showed 11.8V on MDX and TL. Tesla showed 13.6V. So, I guess now it makes sense why Magic EZ didn't work, it cuts off power if less than 12v... this is the lowest setting Magic EZ has... sucks.
Car is about 1 year old.. is it normal for it to have 11.8V coming out of battery? |
Strange thing is, cig. Lighter tested 12.1v, battery terminals were 12.1v as well. Obd2 was 11.8. |
