2017 Advance Running Boards Install DIY
Since the Advance running board installation process has changed significantly for the 2017 models I thought I would add some photos and commentary to the steps provided by the official installation instructions. As someone who likes to perform routine maintenance at home, I thought I'd save $1000 and order the running boards to install them myself. It ended up being a larger job than expected, but it was a good challenge.
The overall process is very similar to the Sport running board installation started in another thread:
Recommended Tools
Other Tips and Thoughts
The final result: https://cimg0.ibsrv.net/gimg/acurazi...973f3bfc3f.jpg I can see why the dealer charges so much. Hope someone finds this helpful! |
FWIW, I posted more pictures in my Flickr album.
1 Attachment(s)
Excellent, helpful post. After reading the instructions that Acura had for their dealers on installation, I decided to let them do it. It, as you illustrate, is not a simple 30 min. bolt on. Still, the results are fantastic. I also added the splashguards which really tie everything together nicely...I think.
Attachment 46010 |
Originally Posted by vicbastige
(Post 15841786)
https://i85.photobucket.com/albums/k...psinzt8nei.jpg Appreciate the kind words. Looks like I may get the splash guards as well. |
OMG, I installed the wrong year running board to my 2017. I ordered the advanced runningboard from Amazon, and I guess it is for 2016, but the good news is that installation is the same as for 2016 and it actually fits. The only difference is that the existing side sill panel with the chrome remains intact. My wife, who loves bling bling actually loves I, lol. I'll post some pictures of it later if anyone is interested. It only took me about 45 minutes for the install.
Originally Posted by vincentesq
(Post 15842005)
1 Attachment(s)
Here is a picture of my 2017 with the 2016 runningboard.
(Post 15842033)
I feel like a fool because I thought they would be the same since it's the same car, only a couple minor facelift. But it doesn't matter. Happy wife, happy life, right? :)
Quick question, is it Advance or Chrome Advance running board? Can't figure out the differences on ACURA website.
Originally Posted by eddielin
(Post 15849029)
LOL - looking at Acura's website I see where the confusion is. The link to the non-chrome version says "Chrome trim with custom step plate provides added eye appeal" and clearly shows a chrome strip on the board in the detail image. The chrome version duplicates that description twice and has a broken image link. Acura's web team needs to get their act together. I'll see if there is a Site Feedback link anywhere... |
Both Advance running boards have a chrome stripe on the side, but the "chrome" version has the chrome step surface, while the non-chrome version has a black step surface. $26 difference. The Sport ones are basically the same as the 14-16 sport boards, albeit with a slightly different rocker portion look and it is missing now the chrome stripe.
Originally Posted by neoshi
(Post 15850660)
Originally Posted by TLXinTX
(Post 15851828)
Very good to know! With this difference in mind I can see the difference now on the Acura website but they really should have done a better job to show the running boards. Thanks for the information. Glad I got the Chrome version -- even though it's more of a silver with black diamond skid material.
(Post 15853323)
Wait, so is the step surface actually more like a painted plastic surface than a metallic one? Acura has this weird aversion to real metallic trims, but I hope it didn't happen here...
(Post 15853379)
Pretty much right on. Im ok as I wouldn't want the glare of chrome. Bottom line is it looks really good to my eye.
(Post 15853765)
Hmm I'm just concerned about that surface lasting. Pebbles caught in soles would ruin that finish, wouldn't it?
Will the 2017 Chrome Advance boards fit on 2016 MDX ? It's not available for 2016...
Originally Posted by mdxrebel
(Post 15921569)
If I were you I would check underneath the vehicle to confirm the bolt holes are present. There should be 6 total: a pair near each wheel and one pair in the middle. |
(Post 15921575)
I don't see why not. The Sport boards for the 2016 also require removing the side sills, where there appear to be the same cutouts and holes in the body.
(Post 15921569)
(Post 15921575)
(Post 15921664)
Those 6 you mention are indeed present on the 2014-2016. They are the only attachment points for the Advance boards and the 2014-2016 Sport boards attach to them as well. There is a 2017 around here that has 2014-2016 Advance boards on it.
Originally Posted by Texas325
(Post 15925862)
Ditto on this. From what I look at the installation guides between the 2014-2016 Sport Board and 2017 Advance Boards, the mounting are the same. I'm hoping someone can confirm this with their 2014-2016. I have a 2016 and don't like the 2014-2016 Advance Boards. The 2017 seem more integrated than an add-on.
This guy seems to have installed the rocker at least from a 17 onto a 14-16, so I think it's reasonable to assume that 17+ boards will work on 14-16s. |
(Post 15925868)
Just sharing - Acura MDX Forum : Acura MDX SUV Forums
Would these Advance Running Boards fit a 2013 rdx? Oem acura parts website lists that these are compatible for models 2016 and up, but aren't the bodies of the 2016 models pretty much the same as the 2013 one?
Erm.. you might be in the wrong forum if you're asking about the RDX using MDX boards. MDX boards seem to be cross compatible from 2014 up to current, or at least the rockers from a 17 fit a 16 fine, so the boards should work too but hasn't been verified yet.
Hi,
I'm in the middle of doing this install, working on the left side of the vehicle, and have a question: Step 19: install Left Bracket A and Left Bracket C, loosely, onto the car frame. Step 20: install Support Bracket A to Left Bracket A Step 21: install Support Bracket B to Left Bracket C. so far so good Step 22: torque down the Support Bracket A and Support Bracket B Step 23: this is where I got confused. Instructions say to REMOVE the Left Bracket A and Left Bracket C. These were installed (loosely) in Step 19 above. Why installed at Step 19 and remove now? Step 24: install the running board. Step 25: install Left Bracket A, Left Bracket B, Left Bracket C. So these 3 brackets get put on AFTER the running board? Is this correct directions? Thanks! |
(Post 15842005)
Originally Posted by 17X
(Post 16100969)
pictures please
Originally Posted by Annona
(Post 16100620)
Hi,
I'm in the middle of doing this install, working on the left side of the vehicle, and have a question: Step 19: install Left Bracket A and Left Bracket C, loosely, onto the car frame. Step 20: install Support Bracket A to Left Bracket A Step 21: install Support Bracket B to Left Bracket C. so far so good Step 22: torque down the Support Bracket A and Support Bracket B Step 23: this is where I got confused. Instructions say to REMOVE the Left Bracket A and Left Bracket C. These were installed (loosely) in Step 19 above. Why installed at Step 19 and remove now? Step 24: install the running board. Step 25: install Left Bracket A, Left Bracket B, Left Bracket C. So these 3 brackets get put on AFTER the running board? Is this correct directions? Thanks! The directions are correct. IIRC, you put the brackets on first to get the support brackets lined up correctly, then remove the brackets to make room for attaching the running boards. Once the boards are on, put the support brackets on underneath the boards and tighten the bolts through both brackets. |
TLXinTX,
Thanks for the confirmation! After much more body aches and pain, I was able to finish everything: roof rails, cross bars, and the advance chrome running boards. The posts on this board have been super helpful. There was 1 spot on each running board that I had to use zip ties: at the front, on the inside, the black flabby plastic part did not line up with anything else. |
(Post 15842033)
:thumbsup: Hello I have the 2017. Same color. And I like the look. Can you show me more picture and I guess you don't have take out the side sill too. I'mean glad to show this. It's very nice. And you have intrusion to install. |
So recently installed aftermarket RBs on our MDX and they fit great. Company is called Vangaurd and got them on EBay for $200.
Was very to install just bolt down on the brackets provided. No removal of the chromed side strip required and def. not as complicated as some posts here have mentioned https://cimg8.ibsrv.net/gimg/acurazi...b910e6165.jpegDriver side installed |
Originally Posted by like2ace
(Post 16117589)
Originally Posted by the red bull
(Post 16118352)
Can you post some pictures with the running board installed? Thanks.
(Post 16118408)
Have posted the driver’s side pic, passenger side looks exactly the same 😜
My 2017 MDX SHAWD with Advance Runningboard.https://cimg8.ibsrv.net/gimg/acurazi...0e7283792.jpeghttps://cimg0.ibsrv.net/gimg/acurazi...3ec64f0d9.jpeg
(Post 15854081)
I guess any material used for a step can/will wear. What is not so evident from the pictures is that the edge and the diamonds are raised significantly from the metal surface below meaning that unless you plan on jogging on the running boards, your sole will not touch the finished surface below. From how I get in and out of mine so far, I'm mostly stepping on the rubber edge.
https://cimg8.ibsrv.net/gimg/acurazi...ae235d5c7.jpeg https://cimg9.ibsrv.net/gimg/acurazi...6da29ddbe.jpeg |
Originally Posted by Inspire08
(Post 16120000)
These boards suit a White MDX however. I see that you had to remove the side chrome strip. Our boards just bolted on without the chrome strip removal, we just had to remove out the three cutouts in each side where the supports go. |
Another advantage of having running boards installed is that you can stand on them and reach the roof. Great help and realized this when I washed and waxed my X today. Used the board to stand and reach the middle roof areas.
So glad to have done this. |
(Post 16120000)
There are 2 different parts with different part numbers and no one seems to have good enough pics to tell the difference. |
