2016 MDX Tire Pressure
I have a Acura MDX 2016, on the side the door recommend tire psi pressure says 35 for both front and back tires. Is that correct ? I thought one was suppose to be higher then the other. What your tire psi for front and back ?
RLX Advanced #3606
MDX Tier Pressure
My 20118 MDX Advance shows 35, all the way around, But in thee past I have had good luck using Nitrogen..
mrgold35
My TSX had different PSI on the door for the front and rear tires (32/30 PSI). My RDX and MDX always had the same PSI all around.
More pressure in the rear will help with oversteer.
More pressure in the front will induce more understeer.
Higher pressure all around will help with fuel mileage.
In essence, what you want the vehicle to do, you play with tire pressure.
If you want all around balance, all four tires should be equal.
If you find yourself in some sand, deflate all four, until you can grab traction
BigJLM1 (03-12-2018)
