2016 MDX oil change
2016 MDX oil change
Hi,
i changed the oil and i am a bit confused on the oil stick reading, i used a 5 quartz and a little bit more to get it to 5.7, is the .7 that i am having a hard time, see the picture, the oil stick is not fully covering above the recommended but there is some oil over the cover mark, did it put too much, i keep putting it in and i keep reading the same, the car has not ran since yesterday, i would think if i added more oil that the whole stick will be cover but it is not, half way is covered, what are your thoughts?
justnspace (01-31-2017)
Make sure that when you are reading the oil level the engine has had time to drain the oil back into the oil pan. If you read it immediately after shutting the engine off, it will read a below the 1/2 way mark.
Lorraines TLX
New Member Introductions
01-31-2017 09:39 AM
Carbon Legend
11-25-2016 01:50 AM
dganesar
10-27-2016 07:49 PM
