2015 MDX Mirror Housing Replacement
Anyone replaced just the mirror housing on gen 3 MDX? Everything is working on the inside and mirror is just fine. The driver side mirror (painted part) is scuffed and have already attempted to repair once. The colored housing is available for sale so I need some step by step guidance to exchange it.
I don't have the MDX manuals, but here are the 2016 Pilot version of the instructions. It should be very similar. Usually you need to pop the mirror off first, then you can work the casing off the mirror.
Optional: Power Mirror Removal if you want to work on it off the vehicle
1) Mirror Holder Removal
2) Mirror Housing Cover Removal
3) Do the reverse to re-install.
There's no adhesive. You have to be careful, and it helps to tilt the mirror to the inside IIRC to expose the point you need to pry away at (it's clipped). See this youtube for an example on an older MDX but don't be as rough as the video lol:
Peregrine
06-16-2017 05:14 PM
boorah623
11-21-2016 01:51 PM
Muski_G
10-19-2016 08:56 AM
Peregrine
10-15-2016 06:38 PM
Yehaman
3G RLX (2013+)
10-13-2016 12:26 PM
