Notices
2014 Acura MDX Jerky Acceleration
Old 06-28-2017, 03:40 PM
Registered Member
Kevin17112's Avatar
I've been driving my Dad's MDX for about a week now and I noticed this jerky acceleration mainly going from stop to go. The acceleration feels jerky at low RPMs. This is a FWD and NOT AWD, it has about 85K miles. Also on idle, I hear little chirp noise, so I'm guessing one of the belts needs replacing, but I doubt this has anything to do with the acceleration.
Kevin17112 is offline
Old 07-05-2017, 03:46 PM
Registered Member
Kevin17112's Avatar
I'm guessing nobody has experienced this with their MDX...
Old 07-08-2017, 11:16 AM
New Member
Hard to diagnose your problem without getting hands on the car. At 85,000 miles I would consider a transmission fluid and filter change. You may also want to make sure the neutral safety switch circuit on the transmission has good connections.
UTMDXER is offline
Old 07-10-2017, 01:39 PM
Registered Member
look up tsb 16-044. As stated you might need some fresh transmission fluid. There is a software update.
3.2cls6speedmt is offline
Old 07-10-2017, 08:31 PM
Registered Member
My 14 mdx was jerking brought it to dealer had transmission fluid changed it drives like new now!
Zestys1 is offline
Old 07-11-2017, 03:51 PM
Registered Member
Kevin17112's Avatar
How much do the dealer charge to change transmission fluid? is it possible to do it myself?
Old 07-11-2017, 07:25 PM
Registered Member
neoshi's Avatar
You should call your regional dealers because costs vary by location, but generally I've seen it around $200 al la carte. They usually try to throw other crap in to inflate the price, so be careful. It is totally doable DIY. As easy as a motor oil change, especially on the 6 speed. http://www.mdxers.org/forums/94-thir...15-models.html
neoshi is offline
Old 03-13-2019, 10:15 PM
Registered Member
Mine is Jerky as well 2014 FWD MDX 108k miles
Mine is jerky when start to go at low speed.
Also, same issue when slowing down at low speed. I clearly feel the car is applying brake itself when I take leg off the accelerator pedal.
Mine is 2014 FWD MDX 108 k miles. Anyone else has same or similar issue?
2002acuramdx is offline
Old 03-13-2019, 11:00 PM
Registered Member
the symptom of car decel when coasting at random is the transmission judder. I had it and TSB service fixed it... at least for now.
shenofjo is offline
Old 03-14-2019, 12:43 PM
Registered Member
That's exactly what i am experiencing in my 15 MDX, and dealer did the TBS tranny flush for me, doesn't change much, I also did the transmission service. The jerking from low speed is very noticeable when driving in traffic, I think there is something to do with the shifting point, and the vcm, but if I drive it over the weekend where no traffic involved, the car is smooth if i give it enough gas to start.
Michael2NB is offline
Old 03-14-2019, 12:49 PM
Registered Member
I had the same experience in the 15 MDX when driving in the stop and go traffic, but if i drive it in sport mode or going up hill, the jerking will be likely to reduce 90%, I am assuming it has something to do with the shifting point, cuz I did a test drive with the master merchanic in the dealership cuz they can't find any problem with my MDX, they replaced the TC, did the flush, all under warranty, so I show him the jerking in the stop and go traffic, he told me because I left off the gas at the point the transmission is shifting to the second gear, that cause the jerk, and since sport mode change the shfiting point, so that helps.
EE4Life
3G MDX Discussion (2014+)
05-03-2019 07:02 AM
EE4Life
05-03-2019 07:02 AM
EE4Life
05-03-2019 07:02 AM
TSX69
Third Generation RLX (2013+)
1406
01-11-2019 10:57 PM
jody.orlandoCL
New Member Introductions
07-10-2017 09:01 PM
Quick Reply: 2014 Acura MDX Jerky Acceleration
