2014 Acura MDX Fog Lights
#41
I installed the Xpel Headlight protectors for my 2014 headlights and they are great! It was pretty easy to do, especially considering it was my first time. They don't offer protectors for the fog lights (yet) though.
#42
For those of you wishing to see the before and after view of the Acura 2014 MDX with installed accessories, Acura has an app called the Acura Accessories. You can view the vehicle from different angles and with a simple swipe you can see the vehicle with all the accessories or stock.
Just got my 2014 SH-AWD, Advance Tech with 19" chrome wheels, black on black. Still waiting on the LED Fog lights. The wheels really stand out with the subtle chrome details on black.
Luis
Luis
#44
2G TLX-S
The factory connection is such that the foglights can only be turned on (using the foglight switch on the steering column stick) when the low-beam headlight is on.
#46
2G TLX-S
Are you planning to do the installation by yourself ?
#47
Im Broke But Im Ok
#50
The fog lights are LED and the light is white, not yellow. So its much closer to color of headlight, but its not exact. According to instruction, if the light goes out, have to get a new light assembly. Does not appear you can change out the light. If anyone found out different, chime in.
#51
2G TLX-S
#55
I put on a clear film on my fog light to protect it from stone chips. Its basically clearbra 3M material that I had a guy do. He even did it for free because it was basically a small light. Window tinting places should be able to put on the material or you could do it yourself. Here is a video:
#56
Thanks on the suggestions to do yellow film. I tried that on my current 2gen and it didn't come out so well. I will try it on new one once I get it. I still have some yellow film from last time so it won't me anything to experiment. Thanks again and I'll post a pic once I get it done.
#57
#60
Awesome looking car. Congratulations......enjoy.
#61
I think your question was misread. I don't think its a problem if they go on the same time you switch on your headlights.
Leave the fog light switch on all the time. When you switch on the headlights, the fog lights will turn on at the same time.
Fog lights can only light up with headlights on.
For me, I don't want them on all the time, until I want them on.
#63
Someone took the pictures of the before and after the installation of the LED fog lights. Apparently the kit comes with the brand new control stick by the steering column (with the knob to turn on the fog lights).
#65
LED Fog Lights
The kit will arrive to me on Wednesday, cannot wait to see how they will look
#68
By federal regulation Fog lights have to have a switch that turns them off automatically if high beams are activated.
Most if not all manufacturers slave the foglights to the regular lights, thus its impossible to turn them on without turning on the headlights.
If you ever see a car with fogs activated separately from the headlamps its aftermarket. If they stay on when the highbeams are on, its not only aftermarket, its jerry-rigged to bypass the obligatory switch they must all have.
If you want to pay for it its in SAE J583 which is the standard the government uses in this regard
#71
#72
Yes, $385 shipped and yes they are legal. This setup works as prescribed by law. The only work with headlights on. They do not work by themselves, DRL, or highbeam. Go to Amazon and search for fog light 2014 mdx.
#73
2G TLX-S
Only if the factory LED foglights are installed exactly as instructed in the corresponding factory installation sheets; then YES, it will be legal.
#74
All fog light have that chance. When you look at the diagram they have separate #'s so I think you can order them separately.
FOGLIGHTS (LED)/FOGLIGHT (LED) for 2014 Acura MDX
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
08v31tz5200, 2014, acura, fog, foglights, install, installation, instructions, led, light, lights, mdx, oem, rlx, tsx
